    Upgrade from 3.4 to 3.7.3 hangs with mysql connect
    2 Posts 2 Posters 1.4k Views 2 Watching
    • B Offline
      Balistar
      I have upgraded all modules from 3.4 to 3.7.4.
      Loading system hangs at "Initializing pooled connection manager"
      INFO  2019-12-10T11:01:47,493 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'internal', v3.7.0 by Infinite Automation Systems Inc.
      INFO  2019-12-10T11:01:50,104 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
      INFO  2019-12-10T11:01:50,252 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection manager
      mySQL only gets one hit from mango:
      2019-12-10T03:01:50.888382Z         8 Connect   root@localhost on mango using SSL/TLS
      When I comment-out all mysql enteries in overrides/properties env.properties and remove the h2 comments, systems loads OK (with obliviously very old settings before we moved to mysql.)
      Ubuntu 19:10
      mysql 8:0.18
      • terrypackerT Offline
        terrypacker
        @Balistar that isn't enough information to go on. Can you review your logs from the upgrade and see if anything went wrong? Each time Mango starts it should create a new log file so I would start by reviewing the log from the time you started and did the upgrade. Also check the com.serotonin.m2m2.db.upgrade.UpgradeXX.logs to see if any SQL commands failed that were not logged in the normal log file.
        Thanks.
