    Trying to trigger different colors, with color indicator, in Dashboard, using string type data.
    User help
    3
    3
    948
    • B
      Bela Toth
      Greetings. I would appreciate some help on this. I'm ripping my hair out trying to figure this out.
      I have an MQTT device, which mango is subscribing Alphanumeric (string) data. In Dashboard, how do I make "color indicator" change state based on the string data (not boolean type). Example: "ON" would trigger color1, "OFF" would trigger color2?
      I threw the kitchen sink at "Element specific"... nada.
      also, how do I use the "value" and "render-value" in "Element specific"... the help section omitted that part...
      Thank you :)
      • ThomasEinastoT
        ThomasEinasto
        Hi Bela,
        I assume you are trying to use the new UI dashboards?
        If so take a look at /ui/examples/basics/style-via-value
        Following is there:
        <style>
            .default {
                background-color: black;
                color: white;
            .good {
                background-color: green;
            .warn {
                background-color: orange;
            .bad {
                background-color: red;
        </style>
        <ma-filtering-point-list ng-model="myPoint" auto-init="true" data-type="NUMERIC"></ma-filtering-point-list>
        <h3>CSS class based on range (numeric points)</h3>
        <div class="default" ng-class="{'good': myPoint.value < 100, 'warn': myPoint.value >= 100 &amp;&amp; myPoint.value < 200, 'bad': myPoint.value >= 200}">
            <label>Point value:</label>
            <ma-point-value point="myPoint"></ma-point-value>
        </div>
        <h3>CSS class based on exact value (multistate/binary points)</h3>
        <div class="default" ng-class="{'good': myPoint.value === 0, 'warn': myPoint.value === 1, 'bad': myPoint.value === 2}">
        </div>
        <h3>Hide/show based on value</h3>
        <div class="default good" ng-show="myPoint.value === 0">
        </div>
        <div class="default bad" ng-hide="myPoint.value === 0">
        </div>
        <h3>Switch based on value</h3>
        <div ng-switch="myPoint.value">
            <div ng-switch-when="0">Point is zero</div>
            <div ng-switch-when="1">Point is one</div>
            <div ng-switch-default>Point has other value</div>
        </div>
        Here is documentation about the directive used in example. https://docs.angularjs.org/api/ng/directive/ngClass
        Example about your case.
        <style>
            .default {
                color: white;
            .ONclass{
            .OFFclass {
        </style>
        <!-- Get our point from Mango -->
        <ma-get-point-value point-xid="MQTTdeviceXID" point="MQTTdevice"></ma-get-point-value>
        <div class="default" ng-class="{'ONclass': MQTTdevice.value === 'ON', 'OFFclass': MQTTdevice.value === 'OFF'}">
            <ma-point-value point="MQTTdevice"></ma-point-value>
        </div>
        One can also do it another way without using class but using ngStyle i.e https://docs.angularjs.org/api/ng/directive/ngStyle
        <!-- if ON then green else red -->
        <div class="default" ng-style="{ background-color: MQTTdevice.value == 'ON' ? 'green' : 'red' }">
        </div>
        • Jared WiltshireJ
          Jared Wiltshire @Bela Toth
          @bela-toth said in Trying to trigger different colors, with color indicator, in Dashboard, using string type data.:
          From the <ma-indicator> documentation - "Only for use with binary and multistate points."
          @ThomasEinasto has provided an alternative method above. Thank you Thomas.
          There is also another relavent example at this Mango URL -
          /ui/examples/single-value-displays/led-indicator
          Have you also tried setting the data point type to binary instead of alpha-numeric? I would think that should work for the MQTT data source.
