    Installation stops at 40 percent
    5 Posts 3 Posters 2.5k Views 3 Watching
    • N Offline
      N8Hart
      I'm trying to install the free version 3.6.4 Mango on a windows 7 desktop, the installation stops at database initialization the web browser reads 40%.
      The batch file can be terminated normally and I don't see any errors in the log file
        Hi N8Hart, welcome to the forum!
        The batch file should open a CMD window which stays open until closed (a hard kill to the process running in it) or Ctrl+C to tell Mango to shut down. If it opens and closes quickly there was some error during startup.
        To check what the error is, if it's going to stderr and not into the log file, you can open a command prompt and
        cd C:\Path\To\Mango\bin
        ma-start.bat
        and then it will not close the window when it experiences the error and you can post the output or search if it has already been answered.
        • N Offline
          N8Hart
          I have not had any of the rapid open close conditions mentioned in the video or installation instructions
          I don't see any warnings or errors, only some info messages: "document manifest file not found" for several XML files. I read the posts regarding the NoSQL errors taking a long time to correct, so I left it running overnight last night however it was the same as it is now.
          I had assumed that the XML files were missing because there isn't a database available (ie new install) was this an incorrect assumption?
          C:\Users\HVAC>cd C:/program files/mango automation/bin
          C:\Program Files\Mango Automation\bin>ma-start.bat
          Using C:\Program Files\Mango Automation as MA_HOME
          C:\Program Files\Mango Automation\overrides\classes;C:\Program Files\Mango Autom
          ation\classes;C:\Program Files\Mango Automation\overrides\properties;C:\Program
          Files\Mango Automation\overrides\lib\*;C:\Program Files\Mango Automation\lib\*
          Using Java at C:\Program Files\Java\jdk1.8.0_231\bin\java
          INFO  2019-10-16T17:26:09,972 (com.serotonin.m2m2.Main.main:105) - Starting Mang
          o 3.6.4 with Schema Version: 28
          INFO  2019-10-16T17:26:10,736 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'advancedScheduler', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,752 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'asciiFile', v3.6.1 by Infinite Automation Systems Inc.
          g module 'BACnet', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,768 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'cloudConnect', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,768 (com.serotonin.m2m2.util.DocumentationManifest.par
          seManifestFile:60) - Documentation manifest file not found: C:\Program Files\Man
          go Automation\web\modules\cloudConnect\web\dox\manifest.xml
          g module 'controlcore', v3.6.1 by Infinite Automation Systems Inc.
          g module 'dashboardDesigner', v3.6.0 by Infinite Automation Systems Inc.
          go Automation\web\modules\dashboardDesigner\web\dox\manifest.xml
          g module 'dataFile', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,799 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'dataImport', v3.6.0 by Infinite Automation Systems Inc.
          g module 'deviceConfig', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,799 (com.serotonin.m2m2.util.DocumentationManifest.par
          go Automation\web\modules\deviceConfig\web\dox\manifest.xml
          g module 'dnp3', v3.6.0 by Infinite Automation Systems Inc.
          g module 'egauge', v3.6.0 by Infinite Automation Systems Inc.
          g module 'envcands', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,814 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'excelReports', v3.6.2 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,846 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'graphicalViews', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,861 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'Haystack', v3.6.0 by Infinite Automation Systems Inc.
          g module 'http', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,877 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'jsonFileImport', v3.6.0 by Infinite Automation Systems Inc.
          g module 'log4jDS', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,892 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'log4JReset', v3.6.0 by Infinite Automation Systems Inc.
          g module 'loggingConsole', v3.6.0 by Infinite Automation Systems Inc.
          g module 'maintenanceEvents', v3.6.0 by Infinite Automation Systems Inc.
          g module 'mangoApi', v3.6.3 by Infinite Automation Systems Inc.
          g module 'mangoUI', v3.6.6 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,892 (com.serotonin.m2m2.util.DocumentationManifest.par
          go Automation\web\modules\mangoUI\web\dox\manifest.xml
          INFO  2019-10-16T17:26:10,924 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'mbus', v3.6.0 by Infinite Automation Systems Inc.
          g module 'meta', v3.6.2 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,939 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'modbus', v3.6.4 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,955 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'mqttClientDataSource', v3.6.0 by Infinite Automation Systems Inc.
          g module 'onewire', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,970 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'opcda', v3.6.0 by Infinite Automation Systems Inc.
          g module 'pakbus', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:10,986 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'pointLinks', v3.6.0 by Infinite Automation Systems Inc.
          g module 'pop3', v3.6.2 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,002 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'reports', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,017 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'scheduledEvents', v3.6.0 by Infinite Automation Systems Inc.
          g module 'scripting', v3.6.2 by Infinite Automation Systems Inc.
          g module 'serial', v3.6.0 by Infinite Automation Systems Inc.
          g module 'slackPublisher', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,033 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'snmp', v3.6.0 by Infinite Automation Systems Inc.
          g module 'sqlConsole', v3.6.0 by Infinite Automation Systems Inc.
          g module 'sqlds', v3.6.1 by Infinite Automation Systems Inc.
          g module 'ssh', v3.6.0 by Infinite Automation Systems Inc.
          g module 'sstGlobalScripts', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,048 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'sstGraphics', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,064 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'TCPIP', v3.6.0 by Infinite Automation Systems Inc.
          g module 'templateConfig', v3.6.0 by Infinite Automation Systems Inc.
          g module 'twilio', v3.6.1 by Infinite Automation Systems Inc.
          g module 'virtualDS', v3.6.1 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,080 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'vmstat', v3.6.0 by Infinite Automation Systems Inc.
          g module 'watchlists', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:11,095 (com.serotonin.m2m2.Main.loadModules:586) - Loadin
          g module 'internal', v3.6.0 by Infinite Automation Systems Inc.
          INFO  2019-10-16T17:26:13,794 (com.serotonin.m2m2.Lifecycle.loadLic:611) - Check
          ing license...
          INFO  2019-10-16T17:26:13,794 (com.serotonin.m2m2.Lifecycle.loadLic:698) - Licen
          se file not found
          INFO  2019-10-16T17:26:13,856 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:61)
          - Initializing H2 connection manager
          INFO  2019-10-16T17:26:14,685 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgr
          ade:38) - Starting instance with core version 3.6.4, schema v28
          INFO  2019-10-16T17:26:16,916 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'runtimeContext' refr
          eshed: org.springframework.context.annotation.AnnotationConfigApplicationContext
          @4ce94d2f
          ontextConfiguration.contextStarted:139) - Spring context 'runtimeContext' starte
          d: org.springframework.context.annotation.AnnotationConfigApplicationContext@4ce
          94d2f
          INFO  2019-10-16T17:26:17,010 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.
          initialize:77) - Initializing 1 NORMAL priority data sources in 8 threads.
          INFO  2019-10-16T17:26:17,103 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initiali
          zeDataSourceStartup:408) - Data source Mango Internal took 105ms to start
          INFO  2019-10-16T17:26:17,119 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.
          initialize:109) - Initialization of 1 NORMAL priority data sources took 109ms
          INFO  2019-10-16T17:26:17,135 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initiali
          ze:176) - Starting 0 Publishers...
          ze:188) - 0 Publisher's started in 0ms
          WARN  2019-10-16T17:26:17,790 (org.eclipse.jetty.webapp.StandardDescriptorProces
          sor.addServletMapping:1220) - Duplicate mapping from *.jsp to jsp
          INFO  2019-10-16T17:26:18,117 (com.serotonin.m2m2.web.M2M2ContextListener.contex
          tInitialized:32) - Mango Automation context starting
          tInitialized:40) - Mango Automation context started
          INFO  2019-10-16T17:26:19,163 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'rootWebContext' refr
          eshed: Root WebApplicationContext
          INFO  2019-10-16T17:26:19,833 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'jspDispatcherContext
          ' refreshed: WebApplicationContext for namespace 'JSP_DISPATCHER-servlet'
          INFO  2019-10-16T17:26:20,021 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'rootRestDispatcherCo
          ntext' refreshed: WebApplicationContext for namespace 'ROOT_REST_DISPATCHER-serv
          let'
          INFO  2019-10-16T17:26:21,362 (com.serotonin.m2m2.web.mvc.rest.v1.BacnetDiscover
          yRestController.<init>:54) - Creating Discovery Rest Controller
          INFO  2019-10-16T17:26:21,643 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'restV1DispatcherCont
          ext' refreshed: WebApplicationContext for namespace 'restV1DispatcherServlet-ser
          vlet'
          INFO  2019-10-16T17:26:23,733 (com.infiniteautomation.mango.spring.MangoRuntimeC
          ontextConfiguration.contextRefreshed:125) - Spring context 'restV2DispatcherCont
          ext' refreshed: WebApplicationContext for namespace 'restV2DispatcherServlet-ser
          vlet'
          INFO  2019-10-16T17:26:23,733 (com.serotonin.m2m2.Lifecycle.configureDwr:1274) -
           Added DWR definition for: EnvCanEditDwr
           Added DWR definition for: HttpDataSourceDwr
          INFO  2019-10-16T17:26:23,749 (com.serotonin.m2m2.Lifecycle.configureDwr:1274) -
           Added DWR definition for: TcpIpDataSourceEditDwr
           Added DWR definition for: Pop3EditDwr
           Added DWR definition for: HaystackDataSourceDwr
          INFO  2019-10-16T17:26:23,749 (com.serotonin.m2m2.Lifecycle.configureDwr:1267) -
           Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpData
          SourceDwr
           Added DWR definition for: DataFileDataSourceEditDwr
           Added DWR definition for: OPCDAEditDwr
           Added DWR definition for: BACnetMSTPEditDwr
           Added DWR definition for: PakBusEditDwr
           Added DWR definition for: MBusEditDwr
           Duplicate definition of DWR class ignored: com.infiniteautomation.mango.pakbus.
          dwr.PakBusEditDwr
          INFO  2019-10-16T17:26:23,765 (com.serotonin.m2m2.Lifecycle.configureDwr:1274) -
           Added DWR definition for: SNMPEditDwr
           Added DWR definition for: InternalEditDwr
           Added DWR definition for: SerialEditDwr
           Added DWR definition for: MetaEditDwr
           Added DWR definition for: DnpEditDwr
           Added DWR definition for: ModbusEditDwr
           Added DWR definition for: Log4jEditDwr
           Added DWR definition for: ScriptingEditDwr
          INFO  2019-10-16T17:26:23,780 (com.serotonin.m2m2.Lifecycle.configureDwr:1274) -
           Added DWR definition for: SshDataSourceEditDwr
           Added DWR definition for: AsciiFileEditDwr
          INFO  2019-10-16T17:26:23,780 (com.serotonin.m2m2.Lifecycle.configureDwr:1267) -
          SourceDwr
           Added DWR definition for: OneWireEditDwr
           Added DWR definition for: SqlEditDwr
           Added DWR definition for: VMStatEditDwr
           Added DWR definition for: MqttClientEditDwr
           Added DWR definition for: EgaugeDataSourceDwr
          SourceDwr
           Added DWR definition for: BACnetIPEditDwr
           Duplicate definition of DWR class ignored: br.org.scadabr.dnp3.dwr.DnpEditDwr
           Added DWR definition for: ControlCoreEditDwr
           Duplicate definition of DWR class ignored: com.serotonin.m2m2.modbus.dwr.Modbus
          EditDwr
          SourceDwr
           Added DWR definition for: VirtualEditDwr
          • terrypackerT Offline
            terrypacker
            @N8Hart that output looks fine to me and it is showing that Mango is fully starting up. I would make sure you are using Chrome as the browser and perhaps clear the cache in the browser. At some point once Mango starts the startup screen will re-direct you to the Login Page but it is possible that you have old code cached and that part is not working properly.
            Also worth confirming that you have the UI module. If it is installed this folder will exist: <MA_HOME>/web/modules/mangoUI
            • N Offline
              N8Hart
              The UI was being launched in IE, I knew it was something simple that I was missing. I installed the same downloads on a pi 3 b+ that I have and it ran without a hitch. Since windows 7 EOS is coming up I'm going to Change the OS on the desktop to Linux.
              Thank you both for your help!
