    Password encountered during installation on MacOS
    14 Posts 4 Posters 8.1k Views 4 Watching
    • cwangvC Offline
      cwangv
      I am trying to install MA on my iMac with Mojave. I have been asked to supply a password.
      Below is the screenshot.
      Does anyone know what this password is?
      Thanks for your help in advance.
      V.W
        Hi cwangv, welcome to the forum!
        That looks like it'd be the sudo password for your computer that it is asking for, as you are sudo'ing. You should be able to run Mango as a lesser privileged user in the majority of cases, so no need to sudo.
        • cwangvC Offline
          cwangv @phildunlap
          @phildunlap
          Hi, Phil
          Thanks for the reply.
          So the syntax will be './ma.sh start'?
          By the way, what version of Java SDK i should have? I have installed the latest 8 version.
          • cwangvC Offline
            cwangv
            Just an update - I. managed to put in the password. But the next error is that the command can not be found.
            See below screenshot
            Any assistance is appreciated!
            On a side note, I have the MangoES software running my windows laptop.
              That would suggest to me that the ma.sh file is not set to be executable. You'll want to run sudo chmod +x ma.sh from the same directory.
                Also note that the video here says Java 7 is required, but currently Java 8 or above is required.
                https://help.infiniteautomation.com/mac-installation
                • cwangvC Offline
                  cwangv
                  Good news! Phil.
                  After reading your reply, I tried what you suggested with 'sudo chmod +x ma.sh'. I was met with a permission denied error message.
                  Then I did a bit of web research on the file permission issues and I did a listing of the access rights on the files under 'bin' (I got the idea from a post on Stack Overflow).
                  below is what I found initially:
                  I saw the ma-start.sh and ma-stop.sh don't have executable permission but ma.sh does. Since ma-start.sh is called by ma.sh but due to the fact ma-start.sh does not have the executable permission, it errors on 'permission denied'.
                  To test it out my theory, I added the executable permission to both ma-start.sh and ma-stop.sh. And boom, it works.
                  Please let me know if my theory is not right.
                  Thanks again for pointing me at the right direction.
                    Hmm. You are correct that those shells scripts need also be executable. I do think the ma.sh needed it based on the error output I responded to, but that doesn't matter. Glad you got it working! When Mango's scripts perform an upgrade, they chmod +x Mango/bin/*.sh but it should also come packaged that way from the store.
                    Those scripts should come with the executable flag set to true. It may be that however you unzipped it didn't maintain the file permissions, or perhaps there is an issue there. I'll check it out.
                    • CraigWebC Offline
                      CraigWeb
                      I find I always need to run chmod +x Mango/bin/*.sh on my Mac when unzipping mango.
                      • cwangvC Offline
                        cwangv
                        Thanks Phil and Craig.
                        I will remember to do that from now on.
                        • CraigWebC Offline
                          CraigWeb
                          I believe/presume it is a Mac OS safety feature.
                          • terrypackerT Offline
                            terrypacker
                            @CraigWeb @cwangv I also use OSX and have found that if you use the Finder to unzip a Mango core it will not preserve the executable bit for the *.sh files inside the zip and it also adds a quarantine attribute to every file.
                            You can manually remove these and then set the executable via chmod but I find that just unzipping the file from the command line will retain the executable bit. So I usually execute unzip <core-file>.zip. This still leaves all the files quarantined though. See the @ on the end of the attributes:
                            -rwxr-xr-x@ 1 mango staff 1089 Jul 8 22:15 ma.sh
                            xattr -l ma.sh
                            com.apple.quarantine: 0083;5d26502d;Safari;2F8BDDE1-3098-4B0D-A0B5-316BD592EFBF
                            You can remove the quarantine attribute for all the files recursively if you execute this in your MA_HOME folder.
                            sudo xattr -dr com.apple.quarantine . (Note the dot to mean from this directory)
                            The quarantine attributes don't seem to matter much as they are used by the launcher when you double click a file to execute it, which won't happen since you need to execute ma.sh start at the command line to run Mango.
                            • cwangvC Offline
                              cwangv @terrypacker
                              @terrypacker
                              Hi, Terry
                              thanks for the recommendation.
                              After reading your post, I re-downloaded the install file and found out that in Safari, at the end of the downloading, the zip file was unzipped by Safari and only the folder was shown and the original zip file was discarded in the recycle bin!!!!
                              There is got to be a setting somewhere to stop this from happening.
                              Cheers!
                                terrypacker
                                Ah yes I forgot about that setting. Using the menu: Safari --> Preferences --> General then uncheck:
                                Open "safe" files after downloading
