    How to get data from java application ?
    11 Posts 2 Posters 7.1k Views 1 Watching
      preeti
      Hi ,
      This is Preeti from India .
      I have installed Mango on my machine . I have a simple java application running on another machine which is a client server program ( in Eclipse) which retrieves CPU details . I want to get output of this program in Mango which I installed on my machine . I click on 'datasource' , in 'Remote IP white list ' I mention the ip address of machine which runs this java application and I click on ' Listen for HTTP data ' . But I see no output .
      Can anyone tell me what I should do in order to receive the output of java application in Mango on my machine ?
      Many Thanks ,
      Preeti
        The HTTP Receiver data source has specific requirements regarding the formatting of incoming requests. Check the data source's documentation.
          preeti
          Yeah . I understand that there is certain format to be followed while delivering the request . I have read the documentation on Http receiver listener .
          I am following the ' Testing with HTTP receiver listener ' from the Http Receiver Listener datasource help documentation .
          When I mention ... in Remote IP white list and * in device id white list and click on Listen for HTTP data in HTTP receiver listener box , I still see no output . I should see the sites I have opened and stuff . But I can see nothing . Can you please tell me what is going wrong ?
            I'm not sure what you mean by that. Once the listener is started your client needs to actively send requests to Mango.
              preeti
              I was thinking , if I open several sites and then if i start HTTP Receiver Listener then the listener box should show the sites I am currently browsing as per ' Testing with the HTTP receiver listener ' documentation . But I see no data in the listener box . I have now figured out HTTP Receiver datasource " listens " data only when it is send in prescribed ( as prescribed in documentation format .
              Do you know any application which sends HTTP data in Mango's HTTP Receiver specific format ? It will be helpful for me for quick testing and also I can build my application to send data in that format .
              Any help ?
                Well, there's Mango... The HTTP publisher sends data in the format required for the data source. Also, as per the examples, you can use a browser to send test data to ensure receipt.
                  preeti
                  Thanks .
                    preeti
                    I am using Publisher feature on my machine . In HTTP sender properties I mention the GET method , in the URL , I mention the ip address of the machine where I am sending the data . In static parameters I mention key value as a and 10 resp . Then I click on ' send static parameters ' . I see the message ' ERROR: Connection refused: connect ' .
                    The machine where I am publishing this data, I configure HTTP Receiver datasource and give ip address of my machine from where I am using Publisher feature .
                    From the error message I think it is port problem . Are the ports where Mango publishes information hard-coded in some file ? I would like to see that file so that I can change the ports where it is publishing data ; in case those ports are blocked to receiving machine as per company policies
                      To specify a port, just add it to the url. E.g.:
                      http://<host>:<port>/<path>
                        preeti
                        Thanks Matthew .
                        I am using Publisher feature from one Mango instance running on my machine to send some static data ( a = 10) to another Mango instance using HTTP Receiver datasource running on my machine . Here both the publisher and receiver are on same ip address.
                        In HTTP sender properties I mention http://<ip address>:port/test/httpds . On HTTP Receiver side on clicking HTTP Receiver Listener I can see :
                        Source : ip address
                        Device id :
                        Time :
                        a= 10
                        b=10 .
                        I want the same data in tabular format ( a jsp file) . How can I do it ?
                        I can very well write a jsp page , but where in source code should I plug this page ? Also , data is received at httpds . Where is this httpds in source code ? Can I get it and simply put my jsp in its place ?
