    Dashboard refresh speed?
    21 Posts 3 Posters 15.5k Views 4 Watching
    • BGB Offline
      BG
      Hello,
      Mango Core: 3.5.6
      Mango API: 3.5.2
      Mango UI: 3.5.5
      Platform: Centos 7.4.1708
      Java Version: 1.8.0_161
      Browser: Chrome 70.0.3538.110 (Official Build) (64-bit)
      Browser: Firefox 61.0.2 (64bit)
      I am building a dashboard template that we will use as the basis for all of our other logging pages to simplify and standardise the displays.
      I am almost finished with Jared's excellent help earlier on another thread.
      I am seeing another problem now.
      I have a virtual data source set up to test the template and I can see the data points update every 60 seconds as it should. But the dashboard, when viewed will only update once or twice then it stops updating until the web browser is manually refreshed. Then the dashboard will update once or twice again and then stop.
      Any suggestions would be greatly appreciated. Let me know if you want to see the mark up.
      Cheers
      Brian
        Any errors in your browsers console? (Open the Chrome debugger)
        How do you know the data source is updating correctly? Can you see the point value continue to change on the Data Point Details page for example?
        • BGB Offline
          BG
          Hello Jared,
          Thank you for getting back to me. I can see the data points update while viewing the watchlist. The timestamp and values are changing every 60 seconds.
          In the chrome developer tools / console, I reloaded the page and got a lot of these messages:
          (247 actually)
          [Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
          mangoUi~ngMango~ngMangoServices.js?v=0f03d20f7b30b4a597f9:39 [Violation] Added non-passive event listener to a scroll-blocking 'touchmove' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
          Let me know if you need me to try something else.
          Cheers
          Brian
          • BGB Offline
            BG
            Hello,
            I have set up the permissions so that a user with only viewing permissions can see the template in the hopes that I may get a better idea of the problem here. With the new user logged in I actually get no errors on the chrome debugger for the dashboard page.
            I do still see the system stop updating the readings after a few minutes.
            Checking the ma.log file I see the following error message each time when the updates stop:
            ERROR 2018-12-06T13:19:25,087 (org.springframework.web.socket.handler.ExceptionWebSocketHandlerDecorator.tryCloseWithError:90) - Closing session due to exception for JettyWebSocketSession[id=62d19e47-0c62-2360-e522-c454977e1207, uri=ws://redacted:8080/rest/v1/websocket/point-value]
            java.lang.IllegalStateException: WebSocketHandler not found for JettyWebSocketSession[id=62d19e47-0c62-2360-e522-c454977e1207, uri=ws://redacted:8080/rest/v1/websocket/point-value]
            	at org.springframework.web.socket.handler.PerConnectionWebSocketHandler.getHandler(PerConnectionWebSocketHandler.java:113) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at org.springframework.web.socket.handler.PerConnectionWebSocketHandler.handleTransportError(PerConnectionWebSocketHandler.java:91) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at org.springframework.web.socket.handler.WebSocketHandlerDecorator.handleTransportError(WebSocketHandlerDecorator.java:80) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at org.springframework.web.socket.handler.LoggingWebSocketHandlerDecorator.handleTransportError(LoggingWebSocketHandlerDecorator.java:64) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at org.springframework.web.socket.handler.ExceptionWebSocketHandlerDecorator.handleTransportError(ExceptionWebSocketHandlerDecorator.java:68) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at org.springframework.web.socket.adapter.jetty.JettyWebSocketHandlerAdapter.onWebSocketError(JettyWebSocketHandlerAdapter.java:131) ~[spring-websocket-5.0.10.RELEASE.jar:5.0.10.RELEASE]
            	at sun.reflect.GeneratedMethodAccessor1039.invoke(Unknown Source) ~[?:?]
            	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_161]
            	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_161]
            	at org.eclipse.jetty.websocket.common.events.annotated.CallableMethod.call(CallableMethod.java:71) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.events.annotated.OptionalSessionCallableMethod.call(OptionalSessionCallableMethod.java:72) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.events.JettyAnnotatedEventDriver.onError(JettyAnnotatedEventDriver.java:157) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingError(AbstractEventDriver.java:96) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.WebSocketSession.incomingError(WebSocketSession.java:460) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.WebSocketSession.notifyError(WebSocketSession.java:521) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:573) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:391) ~[websocket-common-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) ~[jetty-io-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[jetty-io-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[jetty-io-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683) ~[jetty-util-9.4.12.v20180830.jar:9.4.12.v20180830]
            	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_161]
            This looks like a java problem, but I may be wrong. Do I need to upgrade my java version?
            Your Linux installation page says JDK 1.8 is required but not the build number.
            Cheers
            Brian
            • BGB Offline
              BG
              I am also seeing this in the threads:
              Cheers
              Brian
                OK that's interesting, can you download the thread dump and post it for me when you see the blocked thread again (I'm assuming you might have restarted Mango to clear it).
                @bg said in Dashboard refresh speed?:
                Its unlikely that this is related to your Java version. We do no recommend any particular build number, the latest is usually advisable.
                • BGB Offline
                  BG
                  Hello Jared,
                  I will send the thread dump as requested. It was taken immediately after a Mango restart.
                  I don't know if it is relevant but when I said I could see the virtual points update in the watchlist, I was referring to watchlist.shtm. I have also had a look at ui/watchlist and saw something strange there, the chart along the bottom continues to update but the list above the chart stops updating.
                  Here is a screen shot of what I mean:
                  Cheers
                  Brian
                    OK thanks for the additional details, that makes sense. The old watchlist page does not use websockets, the chart on the new watchlist page also does not. The table does.
                    • BGB Offline
                      BG
                      Hello Jared,
                      The length of time before the web sockets close seems to be random. I have seen the updates stop as soon as 2 minutes after logging in and as long as 7 minutes after logging in.
                      Is there any way to prevent the web sockets closing? Maybe a setting in a file that can be saved in overrides? I don't see anything in the env.properties file that would solve this.
                      Cheers
                      Brian
                        @BG we are still looking into it. Could you also send your env.properties file from overrides (reply to the same support email where you sent the thread dump). I want to check a couple of setttings. Also include the type of processor you are using and how many CPU cores.
                        • terrypackerT Offline
                          terrypacker
                          Brian,
                          You could try adding this line to the classes/log4j2.xml file to enlighten us as to why/when they are closing. There is a debug log message anytime a point value web socket is closed explaining why.
                          In the <Loggers> ... </Loggers> section add this logger:
                          <AsyncLogger includeLocation="true" name="com.serotonin.m2m2.web.mvc.rest.v1.websockets.pointValue" level="debug"/>
                          You will need to either reload the log4j configuration from the system setting page or restart Mango for the changes to take effect.
                          • BGB Offline
                            BG
                            Hello Jared,
                            Thank you. I have sent the details as requested. I have also followed Terry's advice and edited the line. I have also put the edited log4j2.xml file in the overrides/classes folder.
                            Cheers
                            Brian
                              terrypacker
                              Brian,
                              Please Post/Send some of the DEBUG log messages generated when the websocket stops updating the page.
                              In terms of settings you can change, the defaults in your env properties seem fine:
                              # Ping timeout for response from browser
                              web.websocket.pingTimeoutMs=10000
                              #Time socket can be idle before being closed (ms)
                              web.socketIdleTimeout=70000
                              Basically the socket will ping/pong back and forth every 10s so that the 70s idle timeout is never hit. However if the ping/pong messages are lost the connection may be closed. That information should come out in the DEBUG messages.
                              • BGB Offline
                                BG
                                Hello Terry,
                                Thank you for your reply. I won't send the entire ma.log for today since it is 157 pages long, Unless you rally wan it of course. :)
                                There are a lot of logged events from my template creations and normal run of the mill log entries.
                                I did look through though and found the following items that may help:
                                2 occasions of:
                                (com.serotonin.m2m2.web.mvc.rest.v1.websockets.pointValue.PointValueWebSocketHandler.afterConnectionClosed:72) - Websocket connection closed, status code: 1006, reason: WebSocket Read EOF
                                28 occasions of:
                                (com.serotonin.m2m2.web.mvc.rest.v1.websockets.pointValue.PointValueWebSocketHandler.afterConnectionClosed:72) - Websocket connection closed, status code: 4500, reason: Didn't receive Pong from Endpoint within 10000 ms.
                                17 ocasions of:
                                (com.serotonin.m2m2.web.mvc.rest.v1.websockets.pointValue.PointValueWebSocketHandler.afterConnectionClosed:72) - Websocket connection closed, status code: 1001, reason: null
                                1 occasion of this after the Mango restart this morning:
                                ERROR 2018-12-12T09:18:00,593 error.tryCloseWithError:90) - Closing session due to exception for JettyWebSocketSession[id=26978505-c5f1-2ae3-3372-ec1cdbe0b184, uri=ws://redacted.extension:8080/rest/v1/websocket/events]
                                java.lang.IllegalStateException: WebSocketHandler not found for JettyWebSocketSession[id=26978505-c5f1-2ae3-3372-ec1cdbe0b184, uri=ws://redacted.extension:8080/rest/v1/websocket/events]
                                	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_161]
                                	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_161]
                                These were the ones i found searching through the log for: closed or error.
                                Please let me know if you want more information or if you need me to search through the logs for specific strings.
                                Cheers
                                Brian
                                Edited by Phil for host scrubbing and formatting triple backticks, ```
                                • BGB Offline
                                  BG
                                  Hello Terry,
                                  I also just wanted to add that since I have been working from home tonight on my templates, I have not seen the dashboards stop updating.
                                  Cheers
                                  Brian
                                    terrypacker
                                    Thanks Brian,
                                    It looks like the ping/pong failure is the problem. The other messages are expected during normal operation.
                                    FYI on the status code meanings:
                                    Status Code 1001 (Going Away) - This is normal behavior when a page is navigated away from
                                    Status Code 1006 (No Close Frame) - Connection was terminated in an unclean way, it appears the socket was broken.
                                    I find it odd that 10s is not long enough to send/receive the messages so I'm thinking you have a network with packet loss. If you can I would suggest pinging the Mango server to see if that is correct. If not then perhaps increasing the env.properties value of
                                    will help.
                                    • BGB Offline
                                      BG
                                      Hello Terry,
                                      Thank you (and your team) for looking into this. Your explanation makes sense now. Our office is on an industrial estate that has a fairly dodgy broadband connection and my home broadband is fine. The packet loss will explain why I am seeing this issue at work. I don't often work on this from home but am making a push to get our Mango 3 implemented.
                                      I will do some ping tests from home and from work to confirm that is the problem. and make the recommended changes to the timeouts.
                                      Again, thank you.
                                      Cheers
                                      Brian
                                      p.s. I wish you all a Merry Christmas.
                                      • BGB Offline
                                        BG
                                        Hello Terry,
                                        Unfortunately that has not solved my problem. I have checked the ping and packet loss on our broadband here at work and while it shows some delays there is not packet loss between my desktop and the Mango 3 server.
                                        I have increased the timeout to 30 seconds but am still seeing the page stop updating after a few minutes.
                                        I can't roll this out to our customers until I am sure the connection to the Mango server is reliable and robust.
                                        Any other suggestion would be greatly appreciated.
                                        Cheers
                                        Brian
                                        • BGB Offline
                                          BG
                                          Here is the last log entry at the time of the last disconnect we had:
                                          ```DEBUG 2018-12-13T15:23:14,983 (com.serotonin.m2m2.web.mvc.rest.v1.websockets.pointValue.PointValueWebSocketHandler.afterConnectionClosed:72) - Websocket connection closed, status code: 4500, reason: Didn't receive Pong from Endpoint within 30000 ms.
                                          ERROR 2018-12-13T15:23:15,063 (org.springframework.web.socket.handler.ExceptionWebSocketHandlerDecorator.tryCloseWithError:90) - Closing session due to exception for JettyWebSocketSession[id=28f6a996-f2fd-ee33-ddea-d87d7d51f60e, uri=ws://dataloggersonline.uk:8080/rest/v1/websocket/point-value]
                                          java.lang.IllegalStateException: WebSocketHandler not found for JettyWebSocketSession[id=28f6a996-f2fd-ee33-ddea-d87d7d51f60e, uri=ws://dataloggersonline.uk:8080/rest/v1/websocket/point-value]
                                          • BGB Offline
                                            BG
                                            Hello Terry,
                                            I think I finally found the culprit. Our anti-virus is causing the drop outs. I turned it off and have run now for 30 minutes with no connection issues.
                                            I am sorry to have bugged you guys about it but thank you for your help and patience.
                                            Cheers
                                            Brian
