    MangoES Factory reset
    11 Posts 5 Posters 5.8k Views 4 Watching
    • B Offline
      benaznbe
      Can I reset factory settings to a new mangoes. What should I do ?
      Thank you.
      • CraigWebC Offline
        CraigWeb
        Hi Benaznbe
        If you mean starting your mango up with a new database. you can ssh into your mangoES and do the following
        1.Stop Mango.
        2.mv Mango/databases/mah2.h2.db Mango/databases/old-mah2.h2.db
        3.Start Mango on a clean database, login admin/admin
          Hi benaznbe,
          CraigWeb's suggestion will get you started with a clean configuration, but it would put your Mango/databases/mangoTSDB at risk of having the old data purged or associated with the wrong, new points. To start Mango on a clean database, you could move the entire Mango/databases directory to Mango/old-databases or wherever, while Mango is off.
          What specifically prompted the question? What are you trying to reset? Something other than Mango?
          • AldoRamosA Offline
            AldoRamos
            I just received a MangoGT, and imported configuration data from a running Mango, and overwrote lots of system configuration I should not have overwritten. Is there a practical way to accomplish the equivalent of a "factory reset" and start over? And over? ;-)
            And part of the "oops" seems to have disabled ssh. Yeah, fun.
            Aldo
              When you say imported configuration, how on earth did you manage to take down the ssh daemon?
              That's in the /etc directory!
              To my knowledge you may be in a pickle as the units come readily configured, the boot image is more for starting linux and loading the kernel into RAM etc..
              I'll have to leave this one to infinite.
              • CraigWebC Offline
                CraigWeb
                I don't see how importing a config can disable ssh. What port are you using?
                  AldoRamos
                  @craigweb said in MangoES Factory reset:
                  My bad; I forgot to use port 2222 (thought I'd saved the configuration to match).
                  So, one mystery solved: ssh is working fine (once I fixed client config).
                  But still have all the system configurations overwritten. Is there a skeleton config file I can use to reset them? For example, all the directories are wrong.
                  Now that I am in the system, I see the backups start after I overwrote the settings, so I don't have something to fall back on. (Suggestion for the future: include at least one config backup as shipped.)
                  So again, I ask: Is a "factory default" config available?
                  Thanks for your patience, and apologies for mistakes I where should have known better.
                    If you're referring to the env.properties or similar files. You're best to download the core module and extract the properties files out of it.
                    It's called renaming your database directory to database.old then restarting mango. It'll create the new directories and files required to start a vanilla mango install.
                    Then you can start from scratch again.
                      AldoRamos
                      @mattfox said in MangoES Factory reset:
                      Nope, didn't break the files. ;-)
                      โ€œThere are no perfect idiots โ€” only some that come close.โ€ โ€” unknown
                      Just wanted to reset the system configuration portion.
                      I suppose I can do a clean reset as you suggested, and import just the configs I should import. I wanted to correct just the sections I regretted importing; but with a clean slate, I can have my "default" config file moving forward.
                      For the record, I intend to re-configure this unit a few times as we explore it in different installations, so the ability to do a "Factory Reset" is a practical step for re-deploying units in general.
                      • CraigWebC Offline
                        CraigWeb
                        Hi Aldo
                        Glad you were able to ssh into it. The mangoGT is running mango enterprise. So What you could have done is installed a fresh copy of Mango enterprise on your PC and then export the default configurations from that instance and import them into your MangoGT. I think that might be the best way forward as you try multiple configurations.
                        I personally do not believe that there should be a one-click factory reset process as this could lead to a disaster. The process should be left to a system admin.
                          AldoRamos
                          No, I agree it shouldn't be too easy; my concern was making sure it would restore the correct MangoES configuration, etc. That's the same concern I have with cloning the configuration from a fresh "Enterprise" install on a non-ES instance.
                          But I have my "default" config file now, so I can move forward simply.
                          Thanks!
                          With your input, this post could be even better ๐Ÿ’—
