    How to clean a very large H2 Database
    27 Posts 2 Posters 15.5k Views 2 Watching
    • E Offline
      etantonio
      This post is deleted!
      • E Offline
        etantonio
        I used this query to search for datapoints to reduce:
        SELECT count(*) as totale, dataPointId, d.name FROM pointValues p, dataPoints d
        where p.dataPointID = d.id
        group by p.dataPointId , d.name order by totale desc;
        I will tune the results of this query,
        I also founded 8500000 records in PointValueAnnotations all like the following row
        TEXTPOINTVALUESHORT | TEXTPOINTVALUELONG | SOURCEMESSAGE
                            |                    | scripting.annotation|
        are these rows useful for something or I can delete it?
        Who produce these rows?
        Thanks, Antonio
          That is a consequence of a Scripting data source setting points that belong to other data sources, so that those values can be seen to have come from elsewhere after the fact. Yes you could delete those rows, you may possibly have to do a backup and a restore to reclaim the disk space.
          • E Offline
            etantonio
            Thanks, I will delete such rows but I think other similar rows will be created in the future, there's a way to avoid this?
            Antonio
              Our solution was to code up the NoSQL module so that people wouldn't have trouble with their pointValues tables. That's the surefire way to avoid it.
              • E Offline
                etantonio
                At the end tuning datapoints purge I'm arrived to a reasonable size for H2 database, about 1.5GB, now I'm testing the mysql porting of this database. I've 2 troubles:
                1. backupMysqlWithOutDatabase:442) - java.io.IOException: Cannot run program "mysqldump"
                the mysql setting on env.properties is the following:
                # MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
                db.type=mysql
                db.url=jdbc:mysql://127.0.0.1:3306/mango
                db.username=solergy
                db.password=secret
                db.mysqldump=
                db.mysql=
                what is required in "db.mysqldump" and "db.mysql" fileds?
                1. When using excel reports purge I've the following exception
                what's the problem and how to solve it?
                WARN  2018-11-06 10:23:35,344 (com.infiniteautomation.mango.web.mvc.rest.v1.exce
                lreports.ExcelReportRestController.purge:547) -
                java.lang.NullPointerException
                        at java.io.File.<init>(Unknown Source)
                        at com.infiniteautomation.mango.excelreports.ExcelReportsCommon.getRepor
                t(ExcelReportsCommon.java:172)
                        at com.infiniteautomation.mango.excelreports.dao.ExcelReportDao.purgeRep
                ortsBefore(ExcelReportDao.java:190)
                        at com.infiniteautomation.mango.web.mvc.rest.v1.excelreports.ExcelReport
                RestController.purge(ExcelReportRestController.java:543)
                RestController.purgeUsingSettings(ExcelReportRestController.java:509)
                        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                        at java.lang.reflect.Method.invoke(Unknown Source)
                        at org.springframework.web.method.support.InvocableHandlerMethod.doInvok
                e(InvocableHandlerMethod.java:221)
                        at org.springframework.web.method.support.InvocableHandlerMethod.invokeF
                orRequest(InvocableHandlerMethod.java:137)
                        at org.springframework.web.servlet.mvc.method.annotation.ServletInvocabl
                eHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)
                        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingH
                andlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:806)
                andlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:729)
                        at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapt
                er.handle(AbstractHandlerMethodAdapter.java:85)
                        at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
                erServlet.java:959)
                        at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
                rServlet.java:893)
                        at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
                workServlet.java:970)
                        at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkSe
                rvlet.java:894)
                        at javax.servlet.http.HttpServlet.service(HttpServlet.java:713)
                        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkSer
                vlet.java:846)
                        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
                        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808
                        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
                Handler.java:1669)
                        at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.j
                ava:83)
                        at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:300)
                Handler.java:1652)
                        at org.springframework.web.filter.CharacterEncodingFilter.doFilterIntern
                al(CharacterEncodingFilter.java:85)
                        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerR
                equestFilter.java:107)
                Handler.java:1652)
                        at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterIntern
                al(ShallowEtagHeaderFilter.java:87)
                        at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterIn
                ternal(MangoShallowEtagHeaderFilter.java:47)
                Handler.java:1652)
                        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.
                doFilter(FilterChainProxy.java:317)
                        at org.springframework.security.web.access.intercept.FilterSecurityInter
                ceptor.invoke(FilterSecurityInterceptor.java:127)
                ceptor.doFilter(FilterSecurityInterceptor.java:91)
                doFilter(FilterChainProxy.java:331)
                        at org.springframework.security.web.access.ExceptionTranslationFilter.do
                Filter(ExceptionTranslationFilter.java:115)
                        at org.springframework.security.web.session.SessionManagementFilter.doFi
                lter(SessionManagementFilter.java:137)
                        at org.springframework.security.web.authentication.AnonymousAuthenticati
                onFilter.doFilter(AnonymousAuthenticationFilter.java:111)
                        at org.springframework.security.web.servletapi.SecurityContextHolderAwar
                eRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169)
                        at org.springframework.security.web.savedrequest.RequestCacheAwareFilter
                .doFilter(RequestCacheAwareFilter.java:63)
                        at org.springframework.security.web.authentication.logout.LogoutFilter.d
                oFilter(LogoutFilter.java:121)
                        at com.serotonin.m2m2.web.mvc.spring.security.CsrfHeaderFilter.doFilterI
                nternal(CsrfHeaderFilter.java:41)
                        at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(Csr
                fFilter.java:124)
                        at org.springframework.security.web.header.HeaderWriterFilter.doFilterIn
                ternal(HeaderWriterFilter.java:66)
                        at org.springframework.security.web.context.SecurityContextPersistenceFi
                lter.doFilter(SecurityContextPersistenceFilter.java:105)
                        at org.springframework.security.web.context.request.async.WebAsyncManage
                rIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56)
                        at org.springframework.security.web.FilterChainProxy.doFilterInternal(Fi
                lterChainProxy.java:214)
                        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChai
                nProxy.java:177)
                        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(D
                elegatingFilterProxy.java:346)
                        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(Delegat
                ingFilterProxy.java:262)
                Handler.java:1652)
                        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java
                :585)
                        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.j
                ava:143)
                        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.jav
                a:577)
                        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandl
                er.java:223)
                        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandl
                er.java:1127)
                        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:
                515)
                        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandle
                r.java:185)
                        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandle
                r.java:1061)
                ava:141)
                        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(Cont
                extHandlerCollection.java:215)
                        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper
                .java:97)
                        at org.eclipse.jetty.server.Server.handle(Server.java:499)
                        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
                        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.jav
                a:257)
                        at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java
                :540)
                        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPoo
                l.java:635)
                        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool
                .java:555)
                        at java.lang.Thread.run(Unknown Source)
                Thanks, Antonio
                  The path to invoke the mysqldump or mysql programs (or just the executables if they're on the Mango user's $Path). The error,
                  Indicates mysqldump is not on the path.
                  That issue appears to have been solved in version 3.1.3 of the excel reports module. You will probably needs to work around it by manually deleting from the excelReports table and deleting from Mango/web/modules/excelReports/web/report-data/ as appropriate. It may only be one report with a null filename, you could perhaps investigate the excelReports SQL table to see.
