    How to clean a very large H2 Database
    27 Posts 2 Posters 15.9k Views 2 Watching
    • E Offline
      etantonio
      The db convertion from H2 to mysql is running (10 hours just to convert table pointValues) but I think there's something strange, at the moment I have only data from last 80 days concerning about 100 variables stored at 1 sample/minute, so I think 80x100x60x24=11,5Million rows in table pointValues, instead the table is around 40Million points, corresponding to an H2 database of 3.5GB corresponding also to a mysql pointValues table using 3.5GB.
      To delete data before last 80 days (originally 5 months) I used the datasource purge for each used datasource. The purge from admin settings seems not to work on a big H2 database or in any case it tooks a very long time.
      • E Offline
        etantonio
        I'm searching for the reason why my H2 database is growing so fast,
        I think that this "Logging TYpe = All Data" could be an error:
        but, looking at the data, it seems that it takes a new value each minute
        according to Data Source logging
        so, it seems, it is not a problem, is it right?
          If you are not using the NoSQL database, yes pointvalues are a contributing factor to the database expansion (and in some people's cases probably the only factor). But, the issue is here: https://github.com/infiniteautomation/ma-core-public/issues/1344
          The likelihood is that sometime (probably sooner than later, maybe 3.6?) we will have a DB upgrade that does the necessary side work to upgrade an PageStore H2 database created in 196 to 197, as referenced in the issues referenced in that issue. In version 197 of H2 the problem of saving a LOB not reusing space has been resolved.
          But, if something like your pointValues pointValueAnnotations or events tables are just very full, the next version of the database may not help in your case.
          • E Offline
            etantonio
            This post is deleted!
            • E Offline
              etantonio
              I used this query to search for datapoints to reduce:
              SELECT count(*) as totale, dataPointId, d.name FROM pointValues p, dataPoints d
              where p.dataPointID = d.id
              group by p.dataPointId , d.name order by totale desc;
              I will tune the results of this query,
              I also founded 8500000 records in PointValueAnnotations all like the following row
              TEXTPOINTVALUESHORT | TEXTPOINTVALUELONG | SOURCEMESSAGE
                                  |                    | scripting.annotation|
              are these rows useful for something or I can delete it?
              Who produce these rows?
              Thanks, Antonio
                That is a consequence of a Scripting data source setting points that belong to other data sources, so that those values can be seen to have come from elsewhere after the fact. Yes you could delete those rows, you may possibly have to do a backup and a restore to reclaim the disk space.
                • E Offline
                  etantonio
                  Thanks, I will delete such rows but I think other similar rows will be created in the future, there's a way to avoid this?
                  Antonio
                    Our solution was to code up the NoSQL module so that people wouldn't have trouble with their pointValues tables. That's the surefire way to avoid it.
                    • E Offline
                      etantonio
                      At the end tuning datapoints purge I'm arrived to a reasonable size for H2 database, about 1.5GB, now I'm testing the mysql porting of this database. I've 2 troubles:
                      1. backupMysqlWithOutDatabase:442) - java.io.IOException: Cannot run program "mysqldump"
                      the mysql setting on env.properties is the following:
                      # MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
                      db.type=mysql
                      db.url=jdbc:mysql://127.0.0.1:3306/mango
                      db.username=solergy
                      db.password=secret
                      db.mysqldump=
                      db.mysql=
                      what is required in "db.mysqldump" and "db.mysql" fileds?
                      1. When using excel reports purge I've the following exception
                      what's the problem and how to solve it?
                      WARN  2018-11-06 10:23:35,344 (com.infiniteautomation.mango.web.mvc.rest.v1.exce
                      lreports.ExcelReportRestController.purge:547) -
                      java.lang.NullPointerException
                              at java.io.File.<init>(Unknown Source)
                              at com.infiniteautomation.mango.excelreports.ExcelReportsCommon.getRepor
                      t(ExcelReportsCommon.java:172)
                              at com.infiniteautomation.mango.excelreports.dao.ExcelReportDao.purgeRep
                      ortsBefore(ExcelReportDao.java:190)
                              at com.infiniteautomation.mango.web.mvc.rest.v1.excelreports.ExcelReport
                      RestController.purge(ExcelReportRestController.java:543)
                      RestController.purgeUsingSettings(ExcelReportRestController.java:509)
                              at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                              at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                              at java.lang.reflect.Method.invoke(Unknown Source)
                              at org.springframework.web.method.support.InvocableHandlerMethod.doInvok
                      e(InvocableHandlerMethod.java:221)
                              at org.springframework.web.method.support.InvocableHandlerMethod.invokeF
                      orRequest(InvocableHandlerMethod.java:137)
                              at org.springframework.web.servlet.mvc.method.annotation.ServletInvocabl
                      eHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)
                              at org.springframework.web.servlet.mvc.method.annotation.RequestMappingH
                      andlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:806)
                      andlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:729)
                              at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapt
                      er.handle(AbstractHandlerMethodAdapter.java:85)
                              at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
                      erServlet.java:959)
                              at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
                      rServlet.java:893)
                              at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
                      workServlet.java:970)
                              at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkSe
                      rvlet.java:894)
                              at javax.servlet.http.HttpServlet.service(HttpServlet.java:713)
                              at org.springframework.web.servlet.FrameworkServlet.service(FrameworkSer
                      vlet.java:846)
                              at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
                              at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808
                              at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
                      Handler.java:1669)
                              at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.j
                      ava:83)
                              at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:300)
                      Handler.java:1652)
                              at org.springframework.web.filter.CharacterEncodingFilter.doFilterIntern
                      al(CharacterEncodingFilter.java:85)
                              at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerR
                      equestFilter.java:107)
                      Handler.java:1652)
                              at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterIntern
                      al(ShallowEtagHeaderFilter.java:87)
                              at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterIn
                      ternal(MangoShallowEtagHeaderFilter.java:47)
                      Handler.java:1652)
                              at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.
                      doFilter(FilterChainProxy.java:317)
                              at org.springframework.security.web.access.intercept.FilterSecurityInter
                      ceptor.invoke(FilterSecurityInterceptor.java:127)
                      ceptor.doFilter(FilterSecurityInterceptor.java:91)
                      doFilter(FilterChainProxy.java:331)
                              at org.springframework.security.web.access.ExceptionTranslationFilter.do
                      Filter(ExceptionTranslationFilter.java:115)
                              at org.springframework.security.web.session.SessionManagementFilter.doFi
                      lter(SessionManagementFilter.java:137)
                              at org.springframework.security.web.authentication.AnonymousAuthenticati
                      onFilter.doFilter(AnonymousAuthenticationFilter.java:111)
                              at org.springframework.security.web.servletapi.SecurityContextHolderAwar
                      eRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169)
                              at org.springframework.security.web.savedrequest.RequestCacheAwareFilter
                      .doFilter(RequestCacheAwareFilter.java:63)
                              at org.springframework.security.web.authentication.logout.LogoutFilter.d
                      oFilter(LogoutFilter.java:121)
                              at com.serotonin.m2m2.web.mvc.spring.security.CsrfHeaderFilter.doFilterI
                      nternal(CsrfHeaderFilter.java:41)
                              at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(Csr
                      fFilter.java:124)
                              at org.springframework.security.web.header.HeaderWriterFilter.doFilterIn
                      ternal(HeaderWriterFilter.java:66)
                              at org.springframework.security.web.context.SecurityContextPersistenceFi
                      lter.doFilter(SecurityContextPersistenceFilter.java:105)
                              at org.springframework.security.web.context.request.async.WebAsyncManage
                      rIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56)
                              at org.springframework.security.web.FilterChainProxy.doFilterInternal(Fi
                      lterChainProxy.java:214)
                              at org.springframework.security.web.FilterChainProxy.doFilter(FilterChai
                      nProxy.java:177)
                              at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(D
                      elegatingFilterProxy.java:346)
                              at org.springframework.web.filter.DelegatingFilterProxy.doFilter(Delegat
                      ingFilterProxy.java:262)
                      Handler.java:1652)
                              at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java
                      :585)
                              at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.j
                      ava:143)
                              at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.jav
                      a:577)
                              at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandl
                      er.java:223)
                              at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandl
                      er.java:1127)
                              at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:
                      515)
                              at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandle
                      r.java:185)
                              at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandle
                      r.java:1061)
                      ava:141)
                              at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(Cont
                      extHandlerCollection.java:215)
                              at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper
                      .java:97)
                              at org.eclipse.jetty.server.Server.handle(Server.java:499)
                              at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
                              at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.jav
                      a:257)
                              at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java
                      :540)
                              at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPoo
                      l.java:635)
                              at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool
                      .java:555)
                      Thanks, Antonio
                        The path to invoke the mysqldump or mysql programs (or just the executables if they're on the Mango user's $Path). The error,
                        Indicates mysqldump is not on the path.
                        That issue appears to have been solved in version 3.1.3 of the excel reports module. You will probably needs to work around it by manually deleting from the excelReports table and deleting from Mango/web/modules/excelReports/web/report-data/ as appropriate. It may only be one report with a null filename, you could perhaps investigate the excelReports SQL table to see.
