    RequestUtils.readProperties Bacnettimeoutexception
    4 Posts 2 Posters 2.8k Views 2 Watching
    • C Offline
      cenk
      We are reading present value each 1 second periodically in the thread.
      refs3 = new PropertyReferences();
      refs3.add(oid, PropertyIdentifier.presentValue);
      PropertyValues pvs3 = RequestUtils.readProperties(ld, rd, refs3, null);
      Sometimes Bacnettimeoutexception error occurred.
      com.serotonin.bacnet4j.exception.BACnetTimeoutException
      at com.serotonin.bacnet4j.transport.ServiceFutureImpl.result(ServiceFutureImpl.java:74)
      	at com.serotonin.bacnet4j.transport.ServiceFutureImpl.get(ServiceFutureImpl.java:63)
      	at com.serotonin.bacnet4j.util.RequestUtils.readProperties(RequestUtils.java:313)
      When LocalDevice terminated and initial again error looking up
      ld.terminate();
      try {
      	ld.initialize();
      } catch (Exception e) {
          e.printStackTrace();
      What is the problem. How can I find a solution?
      Thank you
        Hi cenk,
        Have you tried increasing your Transport's timeout to a longer value? There is also some caching in the local device where it won't try to find a device again for 30 seconds (a member variable of local device) if its first attempt failed, timeoutDeviceRetention
        • C Offline
          cenk
          I increased time out
          ld.withAPDUTimeout(new UnsignedInteger(30000));
          But result is same.
          We are not using remotedevice cach of local device. Remotedevice is a variable in our class.
            Then you should be able to drop a breakpoint in the ServiceFutureImpl method and see where that BACnet timeout exception is coming from.
            But result is same.
            Does it at least take longer to timeout? I do not believe the actual sending of the property request is present in the code you have shared. Nor is the configuration of the local device there. That's not a lot of information to work with.
