    Library compiled succesfully but some packages are missing.
    4 Posts 2 Posters 3.5k Views 2 Watching
      Milo
      I found this packages here
      https://github.com/mlohbihler/various
      sero-warp package also refers to
      lohbihler.scheduler from
      https://github.com/mlohbihler/sero-scheduler
      but I'm unable to compile them, I can see that they are gradle projects but the compiler returns and error: (I'm using Eclipse)
      "A problem occurred evaluating root project 'sero-warp'.
      Could not get unknown property 'bintrayUser' for object of type com.jfrog.bintray.gradle.BintrayExtension."
      When I try to call initialize on LocalDevice I get exception:
      "java.lang.NoClassDefFoundError: lohbihler/warp/WarpScheduledExecutorService"
      I'm pretty new to Java. Did I miss something? Can you provide binaries of my missing packages.
      Milo
      • terrypackerT Offline
        terrypacker
        Milo,
        BACnet4J can be compiled using Maven OR Gradle. I use Maven and have no problems as the pom references our Maven repository at maven.mangoatuomation.net.
        You have 2 options. If you are using Maven in the project that requires BACnet4J then you can review the pom in the git repo here:
        https://github.com/infiniteautomation/BACnet4J/blob/master/pom.xml
        That should show you how to include all the necessary libraries (note the repository and pluginRepository configuration)
        The other option is to download what you need directly from the bintray and maven.mangoautomation.net repositories online.
          Milo
          1. download from: https://github.com/infiniteautomation/BACnet4J
          2. Open Project Directory from Eclipse. Project BACnet4J-master Is now opened.
          3. Open POM, check dependencies: Dependencies:
            • sero-scheduler
            • sero-warp
            • commons-lang3
            • jssc: 2.8.0
            • slf4j-api
            • junit
            • mockito-core
          4. Right-click Project->Run As->(m2)BAcnet4j-master, Goals: clean install->Run
          Build process doesn't show any of the external dependencies being built or included.
          When trying to compile basic app:
          Exception in thread "main" java.lang.NoClassDefFoundError: org/slf4j/LoggerFactory
          Did I miss something during during building? As I said, Java,eclipse maven... is still pretty new environment for me.
            Milo
            I manually downloaded all the missing jars from the repo you provided and it seems to be working now apart from
            SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
            But I get no exceptions when calling
            dev.initialize();
            Thanks for the help.
