    Convert from H2 to mySQL Database guidelines
    7 Posts 3 Posters 5.4k Views 3 Watching
    • pierjsapP Offline
      pierjsap
      Hello everyone,
      I followed the guidelines on this page. But I could not create the mySQL database.
      I downloaded "Mango Automation 3.4.3 Free", I started it, I accepted the license and then I closed mango and proceeded to modify the env.properties file.
      convert.db.type=mysql
      convert.db.url=${ma.home}/databases/mySQLMango
      convert.db.username=admin
      convert.db.password=admin
      When I restart mango, the page loading stops and a H2 db is generated even though I had deleted it before starting the application
      Could you explain the procedure step by step?
      Thanks in advance
        Jared Wiltshire @pierjsap
        @pierjsap said in Convert from H2 to mySQL Database guidelines:
        Which env.properties file? There should be two, one in ${MA_HOME}/classes and another in ${MA_HOME}/overrides/properties which is the one you should be modifying.
        • pierjsapP Offline
          pierjsap
          @jared-wiltshire said in Convert from H2 to mySQL Database guidelines:
          ${MA_HOME}/overrides/properties I modified this, only that I would need explicit help because I have no idea how to port mysql. I did various tests without results.
          Thanks @Jared-Wiltshire
            Hi pierjsap,
            You need to have installed a MySQL server for Mango to connect to, and created a database with a properly privileged user, before you can convert your existing H2 database.
            Once you have that, you will use this section of the env.properties to connect to MySQL (you need to remove the # before the property or it is a comment!):
            # MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
            #db.type=mysql
            #db.url=jdbc:mysql://localhost:3306/<your mysql schema name>
            #db.username=<your mysql username>
            #db.password=<your mysql password>
            #db.mysqldump=<location/command for mysqldump executable for backups>
            #db.mysql=<location/command for mysql executable for restore>
            "mysql schema name" == "database name" there, with this MySQL server installed on the same machine Mango is on.
            and then in the convert properties you have shown you need to use your H2 settings to identify the database to convert. It's a good idea to comment these lines back out after the conversion, but it will not convert it twice by itself. Probably,
            convert.db.type=h2
            convert.db.url=jdbc:h2:${ma.home}/databases/mah2
            • pierjsapP Offline
              pierjsap
              @phildunlap said in Convert from H2 to mySQL Database guidelines:
              @phildunlap for created database do you mean to create an empty database? or do I have to run some script for the generation of the db with mySQL Server?
                mysql -u root -p
                <enter password>
                create database mango;
                create user mangoUser;
                grant all privileges on mango.* to 'mangoUser'@'%' identified by 'mangoUserPassword';
                db.type=mysql
                db.url=jdbc:mysql://localhost:3306/mango
                db.username=mangoUser
                db.password=mangoUserPassword
                db.mysqldump=/usr/bin/mysqldump
                db.mysql=/usr/bin/mysql
                Note that your URL may be influenced by the MySQL server's bind address.
                • pierjsapP Offline
                  pierjsap
                  Thank so much @Jared-Wiltshire and @phildunlap ;)
