    Add point value to amCharts
    16 Posts 4 Posters 8.7k Views 4 Watching
    • L Offline
      leoboeng
      How do I get values from the data point and put it inside the amCharts code?
      Follow the code of the graph that I would like to add but I am not able to put the values of the data points that I would like.
      I wanted Bullet to get the value of the variable.
      <!-- Styles -->
          <style>
      body { background-color: #30303d; color: #fff; }
      #chartdiv {
        width: 100%;
        height: 500px;
      </style>
      <!-- Resources -->
          <script src="https://www.amcharts.com/lib/3/amcharts.js"></script>
          <script src="https://www.amcharts.com/lib/3/serial.js"></script>
          <script src="https://www.amcharts.com/lib/3/plugins/export/export.min.js"></script>
          <link rel="stylesheet" href="https://www.amcharts.com/lib/3/plugins/export/export.css" type="text/css" media="all">
          <script src="https://www.amcharts.com/lib/3/themes/dark.js"></script>
      <!-- Chart code -->
          <script>
      var chart = AmCharts.makeChart( "chartdiv1", {
        "type": "serial",
        "theme": "dark",
        "autoMargins": false,
        "marginTop": 30,
        "marginLeft": 80,
        "marginBottom": 30,
        "marginRight": 50,
        "dataProvider": [ {
          "category": "Tensão Fase A",
          "critica_baixa": 191,
          "precaria_baixa": 11,
          "adequada": 30,
          "precaria_alta": 2,
          "critica_alta": 67,
          "bullet": 224
        "valueAxes": [ {
          "maximum": 260,
          "minimum": 180,
          "stackType": "regular",
          "gridAlpha": 0
        "startDuration": 1,
        "graphs": [ {
          "fillAlphas": 0.8,
          "lineColor": "#ff0000",
          "showBalloon": false,
          "type": "column",
          "valueField": "critica_baixa"
          "fillAlphas": 0.8,
          "lineColor": "#fff100",
          "type": "column",
          "valueField": "precaria_baixa"
          "fillAlphas": 0.8,
          "lineColor": "#0aff00",
          "type": "column",
          "valueField": "adequada"
          "fillAlphas": 0.8,
          "type": "column",
          "valueField": "precaria_alta"
          "fillAlphas": 0.8,
          "type": "column",
          "valueField": "critica_alta"
          "clustered": false,
          "columnWidth": 0.3,
          "fillAlphas": 1,
          "lineColor": "#000000",
          "stackable": false,
          "type": "column",
          "valueField": "bullet"
          "columnWidth": 0.5,
          "lineThickness": 3,
          "noStepRisers": true,
          "stackable": false,
          "type": "step",
          "valueField": "limit"
        "rotate": true,
        "columnWidth": 1,
        "categoryField": "category",
        "categoryAxis": {
          "gridAlpha": 0,
          "position": "left"
      </script>
      <!-- HTML -->
          <div class="chart-block">
         <div id="chartdiv1" style="width: 100%; height: 220px;"></div>
      </div>
      • L Offline
        leoboeng
        Could you paste an example? I am trying to put a graph of the amchart but I am not able to add a data point inside the code
        • R Offline
          rshah
          @leoboeng said in How I use chart from AmCharts:
          Have you tried using the dashboard designer? It's a pretty easy way to do what you want.
          Otherwise, you can look:
          1. Examples -> Charts
          or
          2) API Docs -> Components -> maSerialChart
          L 1 Reply Last reply Reply Quote 0
            @leoboeng
            You may need to enable these menu items.
              Hi leoboeng, welcome to the forum!
              I wonder, have you explored the API docs and examples yet? There are examples of creating charts! rshah and I provided information about where to find those in response to your other post: https://forum.infiniteautomation.com/topic/3355/how-i-use-chart-from-amcharts
              • L Offline
                leoboeng @rshah
                @rshah Yes, you can make the chart type that is not quite what I need, I do not have www.amcharts.com website and I booked one. So I copied the code and put it in the dashboard designer, but I can not assign a variable to that code.
                • L Offline
                  leoboeng @phildunlap
                  @phildunlap Thanks, but I've seen this and found nothing that can help me put the value of a data point into the code I copied here. The types of graphics that mango does not meet what I like, so I created in the site www.amcharts.com but I can not put the value of the data point inside the code.
                  • L Offline
                    leoboeng
                    Thank you, I have seen, but the graphics that you can create does not suit what I would like. I created one in AmChart but I can not add the value of a variable in the code.
                    • L Offline
                      leoboeng
                      the type of chart I'm trying to add is this:
                      <!-- Styles -->
                          <style>
                      #chartdiv {
                        width: 100%;
                        height: 500px;
                      </style>
                      <!-- Resources -->
                      <!-- Chart code -->
                          <script>
                        "type": "serial",
                        "theme": "dark",
                        "marginTop": 30,
                        "marginLeft": 80,
                        "marginBottom": 30,
                        "marginRight": 50,
                        "dataProvider": [ {
                          "adequada": 30,
                          "precaria_alta": 2,
                          "critica_alta": 67,
                          "bullet":
                        "valueAxes": [ {
                          "maximum": 260,
                          "minimum": 180,
                          "gridAlpha": 0
                        "startDuration": 1,
                        "graphs": [ {
                          "fillAlphas": 0.8,
                          "type": "column",
                          "fillAlphas": 0.8,
                          "type": "column",
                          "fillAlphas": 0.8,
                          "type": "column",
                          "fillAlphas": 0.8,
                          "type": "column",
                          "fillAlphas": 0.8,
                          "type": "column",
                          "clustered": false,
                          "columnWidth": 0.3,
                          "fillAlphas": 1,
                          "stackable": false,
                          "type": "column",
                          "columnWidth": 0.5,
                          "lineThickness": 3,
                          "stackable": false,
                          "type": "step",
                        "rotate": true,
                        "columnWidth": 1,
                        "categoryAxis": {
                          "gridAlpha": 0,
                          "position": "left"
                      </script>
                      <!-- HTML -->
                         <div id="chartdiv1" style="width: 100%; height: 220px;" point-xid="DP_866585"></div>
                      </div>
                      In the variable Bullet wanted to enter with the value of the data point
                        @leoboeng please do not post in multiple threads about the same issue.
                        You cannot use just paste code into the dashboard designer and expect it to work. You can't load scripts in that manner and expect them to interface with our AngularJS components. The amCharts libraries are already loaded by our application.
                        Please look at the examples and read the API documentation thoroughly before asking any more questions.
                        Hint, you can set any of the AmCharts options via the options attribute, e.g. <ma-serial-chart options="{...your options...}"></ma-serial-chart>
                        • R Offline
                          rshah
                          Not 100% sure what you are trying to do, but you can reference data points by using ma-get-point-value -- the details about this are available in the API docs, this would pull the latest value for a data point which you can then reference in your code.
                          I recommend you look at the Examples -> Basics section for further detail, Particularly the "Live Value" section
                          • L Offline
                            leoboeng @Jared Wiltshire
                            @jared-wiltshire I apologize for duplicating the questions and options that can be made through the Serial Graphics option function. But I'm not getting the information I'd like. Follow the code you would like to:
                             <script>
                              "type": "serial",
                              "theme": "dark",
                              "marginTop": 30,
                              "marginLeft": 80,
                              "marginBottom": 30,
                              "marginRight": 50,
                              "dataProvider": [ {
                              "valueAxes": [ {
                                "maximum": 260,
                                "minimum": 180,
                                "gridAlpha": 0
                              "startDuration": 1,
                              "graphs": [ {
                                "fillAlphas": 0.8,
                                "type": "column",
                                "fillAlphas": 0.8,
                                "type": "column",
                                "fillAlphas": 0.8,
                                "type": "column",
                                "fillAlphas": 0.8,
                                "type": "column",
                                "fillAlphas": 0.8,
                                "type": "column",
                                "clustered": false,
                                "columnWidth": 0.3,
                                "fillAlphas": 1,
                                "lineColor": "rgba(1, 1, 1, 0.6)",
                                "stackable": false,
                                "type": "column",
                                "columnWidth": 0.5,
                                "lineThickness": 3,
                                "stackable": false,
                                "type": "step",
                              "rotate": true,
                              "columnWidth": 1,
                              "categoryAxis": {
                                "gridAlpha": 0,
                                "position": "left"
                            </script>
                            I'm trying this way but it's not going:
                                <ma-serial-chart id="de1c751e-164b-4927-84d8-56c55399010b" style="position: absolute; width: 400px; height: 200px; left: 0px; top: 220px;" series-1-values="DP_866585Values" series-1-point="DP_866585" series-1-type="line" series-1-color="#ffaa00" legend="false" balloon="true" export="false" options="{ valueAxes:[{maximum:260, minimum:180}], graphs:[{type:column, valueField:191, lineColor:#ff0000},{type:column,valueField:11},{type:column, valueField:30},{type:column, valueField:30},{type:column, valueField:2},{type:column, valueField:2}]}"></ma-serial-chart>
                            Was there somewhere that would better explain that part of the option?
                              Jared Wiltshire @leoboeng
                              @leoboeng said in Add point value to amCharts:
                              What do you mean "not going"? You are going to have to be more descriptive if you want me to help you.
                              What are you trying to achieve that is not working?
                              The options attribute literally just passes the options through to amCharts. Check their documentation as linked to from ours!
                              • L Offline
                                @jared-wiltshire when I try to write the code in the format ma serial option is not appearing the columns of colors in the background. The graphic I'm trying to do is this:
                                his original code is this:
                                <script>
                                  "type": "serial",
                                  "theme": "dark",
                                  "marginTop": 30,
                                  "marginLeft": 80,
                                  "marginBottom": 30,
                                  "marginRight": 50,
                                  "dataProvider": [ {
                                  "valueAxes": [ {
                                    "maximum": 260,
                                    "minimum": 180,
                                    "gridAlpha": 0
                                  "startDuration": 1,
                                  "graphs": [ {
                                    "fillAlphas": 0.8,
                                    "type": "column",
                                    "fillAlphas": 0.8,
                                    "type": "column",
                                    "fillAlphas": 0.8,
                                    "type": "column",
                                    "fillAlphas": 0.8,
                                    "type": "column",
                                    "fillAlphas": 0.8,
                                    "type": "column",
                                    "clustered": false,
                                    "columnWidth": 0.3,
                                    "fillAlphas": 1,
                                    "stackable": false,
                                    "type": "column",
                                    "columnWidth": 0.5,
                                    "lineThickness": 3,
                                    "stackable": false,
                                    "type": "step",
                                  "rotate": true,
                                  "columnWidth": 1,
                                  "categoryAxis": {
                                    "gridAlpha": 0,
                                    "position": "left"
                                </script>
                                I'm trying the following way but nothing is showing up, you do not sew it in the bottom, nor value of variable, nothing, just a transparent square.
                                this is what appears:
                                And on the documentation I have read it but she talks a little about how to work on the Option part, not helping me much to put the configuration of the original code of the graph in a way that the software understands
                                What I could do was look at the other tickets and get an idea of how I could do
                                • L Offline
                                  leoboeng
                                  Hello, I was trying to see other graphics and I could verify that some graphs of example also do not appear, I add values but nevertheless does not appear image.
                                  Already add values to the Pie Chart and no picture appears.
                                    This was a bug in the UI module which was fixed in the latest release.
