    Getting remote device by using device IP Address and not sending broadcast??
    4 Posts 2 Posters 2.9k Views 2 Watching
    • E Offline
      ealebie
      I have the device Id's and ip addresses for all the devices I need to retrieve data from. My machine sits on the same network as all the bacnet devices I need to access.
      getRemoteDeviceBlocking(int, int) sends a broadcast with the device ID to find the remote device, This is currently not working for me. in my wireshark capture I can see the broadcast being sent out, but I never get a response back.
      Since I have the IP wouldn't it be better to just query the ip no to unnecessarily flood the network. I don't see a method allowing me to do so.
      Maybe I'm not using this the right way, Could it be that I have to use localDevice since I have the IP for all devices I need?
      Here in my sample test code:
      Thank you!
         int instance = Integer.parseInt(args[0]);
         int timeout = Integer.parseInt(args[1]);
          Integer deviceId = 1234;
          int port = 0xBAC0;
      	String localBindAddress = "10.116.189.90";
          IpNetworkBuilder builder = new IpNetworkBuilder();
          builder.withPort(port);
          builder.withLocalBindAddress(localBindAddress);
          builder.withBroadcast("10.116.189.127", 26);
          IpNetwork network = builder.build();
          LocalDevice localDevice = new LocalDevice(deviceId, new DefaultTransport(network));
          try {
              localDevice.initialize();
          } catch (Exception e) {
          	System.out.println("Unable to initialize localDevice");
              e.printStackTrace();
          //Get Superior conference room
          RemoteDevice rd = null;
      	try {
      		rd = localDevice.getRemoteDeviceBlocking(instance, timeout);
      	} catch (BACnetException e) {
      		// TODO Auto-generated catch block
      		System.out.println("Unable to find device: "+ instance);
      		System.exit(1);
          System.out.println("Vendor: " + rd.getVendorName());
          RemoteObject ro = rd.getObject(new ObjectIdentifier(19,8));
          Encodable value = ro.getProperty(PropertyIdentifier.presentValue);
          System.out.println("Device: " + rd.getInstanceNumber()+  " present value =" + value);
        Hi ealebie,
        The current BACnet4J library does not permit you to forgo having broadcasts properly configured, it's part of the BACnet spec to have them working. If you have BBMDs involved you may need to register as a foreign device with them, In wireshark you suggest they are not being responded to, so I would wonder if you have some successful broadcast packets with which to compare. I would also wonder if binding a sink address (looks like 10.116.189.64 on your network) instead of your actual IP may help (but, not if devices aren't responding)
        Here's a thread where such a registration is performed from within Mango.
        https://forum.infiniteautomation.com/topic/3099/bacnet4j-3-2-and-bbmd-foreign-device-support
        • E Offline
          ealebie
          Hi Phildunlap,
          Thanks, that helped. I ran different tests. There are devices from different vendors in the Bacnet network, I realised all the other Vendor devices except the ones I was interest in, Lutron, would respond to the broadcast. But I needed to register as a foreign device for the Lutron devices to respond back, but it only resonds 50% of the time, other 50 it times out.
          This is the output I get now when it works:
          RemoteDevice(instanceNumber=1761053, address=Address [networkNumber=3004, macAddress=[0,0,0,1a,df,1d]], maxAPDULengthAccepted=1476, segmentationSupported=no-segmentation, vendorId=176, vendorName=null, name=Superior Conference Room 1761053, servicesSupported=[false, false, false, false, false, true, false, false, false, false, false, false, true, false, true, true, true, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, true, true, false, false, false, false, false])
          I'm supposed to be printing out the present value for the Occupancy state Object, but the getObject returns null. looks like I'm using the right objectype and instance. Not sure what I'm doing wrong, any hints or help would be appriciated.
          Thanks!
          /Alex
          Here is the Device info from BQT:
          	        int port = 0xBAC0;
          	        try {
          	            network.registerAsForeignDevice(new java.net.InetSocketAddress(localBindAddress, 0xBAC0), 60);
          		try {
          			System.exit(1);
          		System.out.println("");
          		System.out.println(rd.toExtendedString());
          	        if (ro != null)
          	        	System.out.println(ro.getObjectName() +  " present value = " + value);
          	        System.exit(0);
            Great!
            Hmm, I'm not sure. You could try doing a ReadPropertyRequest for the present value, instead of trying to get the whole Object.
