    Java update to 1.8 162 has caused Mango ES 3.2.2 to become unreachable.
    13 Posts 2 Posters 8.9k Views 2 Watching
    • raylatbasixR Offline
      raylatbasix
      Just tried performing a Java update after uploading the 32-bit ARM version of the java update using the following recommended commands:
      tar -xvzf jdk-*.tar.gz
      cp -rf jdk1.8.0_162/* java-8-oracle/
      rm -r jdk1.8.0_162
      rm jdk-*.tar.gz
      All seemed to go ok, I rebooted system from Webmin, and not I cannot access the Mango UI. Webmin is still accessible though. Thinking there was an issue with this version of Java, I used the same above procedure to put it back to Java 1.8 131 as it was before, rebooted via webmin, and I am still not able to access the Mango UI. Any assistance would be appreciated.
        Hi raylatbasix,
        Things to check,
        1. Is there an error in your /opt/mango/logs/ma.log file?
        2. What does java -version say when run on the command line (you can do this in the Command Shell in Webmin)?
        3. What happens if you SSH and cd /opt/mango/bin; ./ma.sh start ?
        4. Could it be the Mango user doesn't have executable privileges to the new Java? (this could be tested by running java -version after SSH'ing as the mango user)
          raylatbasix
          Hi Phil,
          > java -version
          java version "1.8.0_131"
          Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
          Java HotSpot(TM) Client VM (build 25.131-b11, mixed mode)
          I put it back to 1.8 131 thinking there was an issue.
          Appears to start the service ok, I am now able to access the Mango UI.
          Is this because I tried to restart via Webmin using the mango user account?
          I am trying to solve a Java memory leak issue by updating java from 1.8 131 to something newer. What did I miss on performing the java update?
            raylatbasix
            ma.log file error:
            ERROR 2018-02-13T10:48:32,418 (com.serotonin.m2m2.Main.main:129) - Error during initialization
            java.lang.RuntimeException: java.net.SocketException: Permission denied
            	at com.serotonin.m2m2.Lifecycle.webServerInitialize(Lifecycle.java:922) ~[ma-priv-3.2.2.jar:?]
            	at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:199) ~[ma-priv-3.2.2.jar:?]
            	at com.serotonin.m2m2.Main.main(Main.java:125) [ma-priv-3.2.2.jar:?]
            Caused by: java.net.SocketException: Permission denied
            	at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_131]
            	at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_131]
            	at sun.nio.ch.Net.bind(Net.java:425) ~[?:1.8.0_131]
            	at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:1.8.0_131]
            	at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) ~[?:1.8.0_131]
            	at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:317) ~[jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721]
            	at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80) ~[jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721]
            	at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235) ~[jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721]
            	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721]
            	at org.eclipse.jetty.server.Server.doStart(Server.java:390) ~[jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721]
            	at com.serotonin.m2m2.Lifecycle.webServerInitialize(Lifecycle.java:919) ~[ma-priv-3.2.2.jar:?]
            	... 2 more
            INFO  2018-02-13T10:48:32,431 (com.serotonin.m2m2.Lifecycle.terminate:361) - Mango Lifecycle terminating...
            ERROR 2018-02-13T10:48:32,447 (com.serotonin.m2m2.Lifecycle.terminate:436) - com.serotonin.provider.InputStreamEPollProvider
            ERROR 2018-02-13T10:48:32,449 (com.serotonin.m2m2.Lifecycle.terminate:444) - com.serotonin.provider.ProcessEPollProvider
            FATAL 2018-02-13T10:48:32,459 (com.infiniteautomation.zwave.rt.ZwaveControlCenter.<init>:62) - Z-Wave Device configuration directory at:  does not exist!
            FATAL 2018-02-13T10:48:32,459 (com.infiniteautomation.zwave.rt.ZwaveControlCenter.<init>:68) - Z-Wave user data directory at:  does not exist, Mango will shutodwn.!
            INFO  2018-02-13T10:48:32,466 (com.serotonin.m2m2.Lifecycle.terminate:480) - Mango Lifecycle terminated.
            So it was some sort of permission issue. How do you recommend updating java ??
              I will go add a step to those directions. Those were written originally when Mango ran under the root user, and since the default port in a MangoES is 80 that's a privileged port for a lesser user, and one need give it permissions somehow. We chose to solve that by giving the java executable cap_net_bind_service privileges.
              So, after the cp -rf newJdk/* java-8-oracle/ overwrite, you need to sudo setcap 'cap_net_bind_service=+ep' java-8-oracle/bin/java to give the new Java executable permissions to open the port.
              Thanks for bringing those instruction being out of date to our attention.
                raylatbasix
                Thanks Phil,
                So I should be safe to attempt a java update back to 1.8 162, and perform you additional steps??
                Also, it seems all of my licensing on the modules page shows as "Unlicensed" or free mode now. Any Idea how to fix that? I'm guessing in this mode, I'm limited on my point count to 300, and I am well over that.
                Thanks.
                  Yes, that extra step is what was missing. I just upgraded Java on an ES I have to confirm.
                  I would suspect you ran it under the root user, and that's why your license isn't appearing. You may need to chown -R mango:mango /opt/mango to get all the files back to the mango user's ownership, and then start mango as the mango user or through the service.
                    raylatbasix
                    @phildunlap said in Java update to 1.8 162 has caused Mango ES 3.2.2 to become unreachable.:
                    sudo setcap 'cap_net_bind_sevice=+ep' java-8-oracle/bin/java
                    Just upgraded to 1.8 162. Having an issue with the:
                    Throws an invalid argument error for setcap:
                    fatal error: Invalid argument
                    usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
                     Note <filename> must be a regular (non-symlink) file.
                    Any ideas?
                      Try the absolute path if you weren't in the parent directory of java-8-oracle, /usr/lib/jvm/java-8-oracle/bin/java
                        raylatbasix
                        I was in the parent directory for the java-8-oracle. Tried it both ways, still no luck.
                        > cd /usr/lib/jvm/
                        > sudo setcap 'cap_net_bind_sevice=+ep' /usr/lib/jvm/java-8-oracle/bin/java
                          We connected and resolved the issue with a few extra steps...
                          1. sudo setcap 'cap_net_bind_service=+ep' java-8-oracle/bin/java I missed the R in service when writing that! D'oh.
                          2. sudo setcap 'cap_net_bind_service=+ep' java-8-oracle/jre/bin/java
                          3. For some reason we also had to chown -R mango:mango java-8-oracle as, despite appearing to have permissions in an ls -l, his Mango user was not able to travel into the java-8-oracle directory. There are no downsides to chowning that directory to the mango user, but it shouldn't have been necessary and wasn't on my test system.
                          The license issue was resolved once the mango user was launching Mango.
                            raylatbasix
                            Thanks for the excellent support today Phil!!
                              You are most welcome!
