    Excel export to JSON
    2 Posts 2 Posters 1.0k Views 2 Watching
      psysak
      Hey everyone, I was just wondering if anyone here might have an Excel workbook already done that allows creating points, specifically META in my case, and then exports that to JSON? If you'd be willing to share I'd appreciate that.
        Hi psysak,
        It's not exactly what you requested, but it's a similar gist for an option. There may be more excel based options - but I like the python based options so that's the main angle I'd come at it from.
        Here's a CSV of modbus points (Excel --> Export as CSV, or you can export using another separator you don't use in the data):
        Modbus Register,# of Modbus Registers,Description,Format,Properties
        43012,2,Record Number (x),UINT32,Read
        43014,2,UTC Seconds,UINT32,Read
        43016,2,UTC MicroSeconds,UINT32,Read
        43018,2,Source 1 Input Data,FLOAT,Read
        43020,2,Source 2 Input Data,FLOAT,Read
        43022,2,Source 3 Input Data,FLOAT,Read
        43024,2,Source 4 Input Data,FLOAT,Read
        43026,2,Source 5 Input Data,FLOAT,Read
        43028,2,Source 6 Input Data,FLOAT,Read
        43030,2,Source 7 Input Data,FLOAT,Read
        43032,2,Source 8 Input Data,FLOAT,Read
        43034,2,Source 9 Input Data,FLOAT,Read
        43036,2,Source 10 Input Data,FLOAT,Read
        43038,2,Source 11 Input Data,FLOAT,Read
        43040,2,Source 12 Input Data,FLOAT,Read
        43042,2,Source 13 Input Data,FLOAT,Read
        43044,2,Source 14 Input Data,FLOAT,Read
        43046,2,Source 15 Input Data,FLOAT,Read
        43048,2,Source 16 Input Data,FLOAT,Read
        43088,2,Record Number (x+2),UINT32,Read
        43090,2,UTC Seconds,UINT32,Read
        43092,2,UTC MicroSeconds,UINT32,Read
        43094,2,Source 1 Input Data,FLOAT,Read
        43096,2,Source 2 Input Data,FLOAT,Read
        43098,2,Source 3 Input Data,FLOAT,Read
        43100,2,Source 4 Input Data,FLOAT,Read
        And here's my python script that consumes it:
        import re
        modbusDataTypes = {"FLOAT":"FOUR_BYTE_FLOAT", "UINT32":"FOUR_BYTE_INT_UNSIGNED"}
        xidPrefix = "SJ3_"
        baseModbusPoint = """{
                 "xid":"%(xid)s",
                 "name":"%(name)s",
                 "enabled":true,
                 "loggingType":"INTERVAL",
                 "purgeType":"YEARS",
                 "pointLocator":{
                    "range":"HOLDING_REGISTER",
                    "modbusDataType":"%(modbusDataType)s",
                    "writeType":"NOT_SETTABLE",
                    "additive":0.0,
                    "bit":0,
                    "charset":"ASCII",
                    "multiplier":1.0,
                    "offset":%(offset)s,
                    "registerCount":2,
                    "slaveId":1,
                    "slaveMonitor":false
                 "eventDetectors":[
                 "plotType":"SPLINE",
                 "unit":"",
                 "templateXid":"Numeric_Default",
                 "chartColour":"black",
                 "chartRenderer":{
                    "type":"IMAGE",
                    "timePeriodType":"DAYS",
                    "numberOfPeriods":1
                 "dataSourceXid":"DS_849061",
                 "defaultCacheSize":1,
                 "deviceName":"test_mod 502",
                 "discardExtremeValues":false,
                 "intervalLoggingPeriod":1,
                 "purgeOverride":false,
                 "purgePeriod":1,
                 "readPermission":"",
                 "setPermission":"",
                 "textRenderer":{
                    "type":"ANALOG",
                    "useUnitAsSuffix":true,
                    "unit":"",
                    "renderedUnit":"",
                    "format":"0.00"
                 "tolerance":0.0
        modbusRegisterMap = open("simpleModbusCSV.csv")
        outputFile = open("modbusGeneratorOut.json", "w+")
        outputFile.write("{")
        outputFile.write("\"dataPoints\":[")
        for line in modbusRegisterMap :
        	fields = line.split(",")
        	if not len(fields) > 1 or re.search("^4",fields[0]) is None :
        		continue
        	holdingOffset = re.search("4([0-9]+)", fields[0]).group(1)
        	outputFile.write(baseModbusPoint % {"name": fields[2],"xid": xidPrefix+fields[2].replace(" ", "_"), "offset": holdingOffset, "modbusDataType":modbusDataTypes[fields[3]],})
        outputFile.write("]}")
        outputFile.close()
        modbusRegisterMap.close()
        You can see all i'm doing is setting the name, xid, offset, and modbusDataType for the points and writing out a {"dataPoints":[ ... ]} list to modbusGeneratorOut.json
