    Using REST API to PUT point-values by Python code
    9 Posts 4 Posters 3.7k Views 4 Watching
    • T Offline
      thirawad
      Hi all,
      this is the first time for me to using REST API . i'm start learning from SWAGGER, everything in swagger page working good. i can get value or put value in to the data point via Xid, it easy to use and power full. in figure below show for detail of PUT point-values/{Xid} had success.
      after that i'm try to get and put value from point-values via Python code. The Cookie issue for request header are solve in help forum. i'm trying several time. so it working only for request get() value, but when using request put() i receive response of request status code is 403. maybe the code is not correct, i don't know how to declare the body content of payload. i wish someone help. i have the code in below
      import requests
      import json
      ## STEP [1]-------------------------------------------------------------------------
      s = requests.Session()
      s.headers.update({'Cookie':'MANGO8080=1mk606ffnwaxywwielclj4ck2; XSRF-TOKEN=dc1d54de-fab1-4405-8ccb-ea677aadf7ca','X-Xsrf-Token':'dc1d54de-fab1-4405-8ccb-ea677aadf7ca','Accept': 'application/json', 'Content-Length': '39', 'Accept-Encoding': 'gzip', 'Content-Type': 'application/json;charset=UTF-8'});
      url3 = 'http://localhost:8080/rest/v2/login'
      js = {'username': "admin", 'password': "admin"}
      r = s.post(url3, data=json.dumps(js));
      s.headers.update({'Cookie' : r.headers['Set-Cookie']})
      del s.headers["Content-Length"]
      del s.headers["Content-Type"]
      del s.headers["Cookie"]
      del s.headers["X-Xsrf-Token"]
      ## STEP [2]-- get device name -----------------------------------------------------------------------
      r = s.get('http://localhost:8080/rest/v1/device-names', timeout=5);
      print ('\n device name')
      print( r.text)
      ## STEP [3]-- get Point value by {Xid} ---------------------------------------------------------------
      r = s.get('http://localhost:8080/rest/v1/point-values/DP_6bcc108f-faa1-47fb-b310-1acc8b047fd2/latest?useRendered=false&unitConversion=false&limit=1&useCache=true', timeout=5);
      print ('\n Point value')
      print( r.text)
      ## STEP [4]------ put Point value by {Xid} ---------------------------------------------------------
      dd = {'dataType': "BINARY",  'value': "true",  'timestamp': 0,  'annotation': "rest by TST 12"}
      url2 = 'http://localhost:8080/rest/v1/point-values/DP_6bcc108f-faa1-47fb-b310-1acc8b047fd2?unitConversion=false'
      r = s.put(url2, data=json.dumps(dd));
      print ('\n post')
      print(r)
      print( r.text)
      the request status code in step 1 - 3 is <200> but step 4 is <403> please help !
      Best regard.
        Hi thirawad,
        You are very close!
        You need to set the X-Xsrf-Token header to the XSRF-TOKEN value in the Set-Cookie response, so instead of
        do
        s.headers["X-Xsrf-Token"] = s.cookies["XSRF-TOKEN"]
        and set the content type before that PUT request for setting the value,
        s.headers["Content-Type"] = "application/json"
        • T Offline
          thirawad @phildunlap
          @phildunlap , Hi phildunlap, Thank you for your reply.
          for now my request PUT still had code 403 (Forbidden). i found some content miss match in header about set-cookie, MANGO8080 and XSRF-TOKEN, there follow with Path=/;HttpOnly, , i'm not sure. please advice me for correcting the code.
          [my device: window10, 64bit , python2.7.14 and Mango REST API V3.2.2]
          #--- code
          print r.headers['Set-Cookie']
          #-- output
          MANGO8080=nq3nbgdw1qymm6btf374f6wb;Path=/;HttpOnly, XSRF-TOKEN=63164c0e-4353-40dc-9591-30d129580c87;Path=/
          import requests
          import json
          js = {"username": "admin", "password": "admin"}
          ##STEP [1]-----------------------------
          print "After post login the status code is:", r.status_code
          ###----- Renew Cookie Token generate in cookie content
          ##------ Renew X-Xsrf-Token
          dd = {"dataType":"BINARY","value":"false","timestamp": "","annotation":"Rest by admin"}
          ##STEP [2]-----------------------------
          print(r)
          print(s.headers)
          Best regard.
          Thirawad
            Hmm. I did test your script, here was what I had,
            import requests
            import json
            print( r.text)
            r = s.get('http://localhost:8080/rest/v1/point-values/DP_setme/latest?useRendered=false&unitConversion=false&limit=1&useCache=true', timeout=5);
            print( r.text)
            dd = {'dataType': "ALPHANUMERIC",  'value': "true",  'timestamp': 0,  'annotation': "rest by TST 12"}
            url2 = 'http://localhost:8080/rest/v1/point-values/DP_setme?unitConversion=false'
            print ('\n put')
            print(r)
            print( r.text)
            You may with to pass your "value" in the put as a boolean, like, "value": false instead of as a string, "value":"false"
            • T Offline
              @phildunlap Thank you very much for your code and advice.
              this is the result:
              1. i'm using your code by replace DP_setme to my Xid and
              2. change the data point type in data source from binary to alphanumeric,
              3. It done, i'm receive response code: <201>
              for the next i will try to change the way for put as a boolean.
              thank you again. you very please me.
                :D
                Glad you got it working!
                  For anyone reading this thread, if you use Mango v3.3 you can now generate JWT authentication tokens from the users page on the new UI and use these to authenticate instead of logging in from your script.
                  You do not need to use any CSRF/XSRF protection cookies/headers when using JWT authentication.
                  Just set the one header on every request -
                  Authorization: Bearer <token>
                  MattFoxM 1 Reply Last reply Reply Quote 1
                    MattFox @Jared Wiltshire
                    @jared-wiltshire Cannot seem to create a token, all I receive is a bad request. Is there any other way of creating one?
                      @MattFox See the post here -
                      https://forum.infiniteautomation.com/topic/3238/failed-to-create-authentication-token-bad-request/2
