NoSQL migration crashes mango with no log message
I've upgraded an instance to 3.x, and migrating historical data into NoSQL, but it will run about 2 minutes then crash, with no log messages whatsoever:
less $MA_HOME/logs/ma.out INFO 2017-12-11T12:58:02,348 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... INFO 2017-12-11T12:58:02,384 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... INFO 2017-12-11T12:58:02,443 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... INFO 2017-12-11T12:58:28,664 (com.infiniteautomation.jsonfileimporter.JSONFileImportJob.run:51) - Running JSON File Import Job. INFO 2017-12-11T12:58:28,666 (com.infiniteautomation.jsonfileimporter.JSONFileImportJob.run:97) - Finished JSON File Import Job. INFO 2017-12-11T12:59:02,335 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:151) - Migrated 217370 point values. INFO 2017-12-11T12:59:02,336 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:155) - Finished Data Migration, 217370 point values migrated to Time Series Datastore took 59.952s INFO 2017-12-11T12:59:02,339 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... INFO 2017-12-11T12:59:28,664 (com.infiniteautomation.jsonfileimporter.JSONFileImportJob.run:51) - Running JSON File Import Job. INFO 2017-12-11T12:59:28,665 (com.infiniteautomation.jsonfileimporter.JSONFileImportJob.run:97) - Finished JSON File Import Job. INFO 2017-12-11T13:00:00,596 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:151) - Migrated 1087343 point values. INFO 2017-12-11T13:00:00,597 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:155) - Finished Data Migration, 1087343 point values migrated to Time Series Datastore took 118.154s INFO 2017-12-11T13:00:00,604 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... ma-start: no restart flag found, not restarting MA ma-start: MA doneless $MA_HOME/logs/ma.err /var/opt/mango/bin/ma-start.sh: line 147: 11343 Killed $EXECJAVA $JPDA $JAVAOPTS -server -cp "$MA_CP" "-Dma.home=$MA_HOME" "-Djava.library.path=$MA_HOME/overrides/lib:$MA_HOME/lib:/usr/lib/jni/:$PATH" com.serotonin.m2m2.MainWhat else can I try to get more diagnostics?
Do you have an hs_err file in your Mango/ directory? Usually HotSpot will write out (unless you're on a different JDK) an error file to the root Mango directory if it was killed by the OOM killer or something like that. That would be my first guess - the OOM killer got it. That should also appear in the dmesg output.
Those files do exist, but they are dated last week.
$ cat hs_err_pid1026.log # # There is insufficient memory for the Java Runtime Environment to continue. # Native memory allocation (mmap) failed to map 7158300672 bytes for committing reserved memory. # Possible reasons: # The system is out of physical RAM or swap space # In 32 bit mode, the process size limit was hit # Possible solutions: # Reduce memory load on the system # Increase physical memory or swap space # Check if swap backing store is full # Use 64 bit Java on a 64 bit OS # Decrease Java heap size (-Xmx/-Xms) # Decrease number of Java threads # Decrease Java thread stack sizes (-Xss) # Set larger code cache with -XX:ReservedCodeCacheSize= # This output file may be truncated or incomplete. # # Out of Memory Error (os_linux.cpp:2640), pid=1026, tid=0x00007f92c42de700 # # JRE version: (8.0_144-b01) (build ) # Java VM: OpenJDK 64-Bit Server VM (25.144-b01 mixed mode linux-amd64 compressed oops) # Core dump written. Default location: /var/opt/mango/core or core.1026 # --------------- T H R E A D --------------- Current thread (0x00007f92bc00e000): JavaThread "Unknown thread" [_thread_in_vm, id=1029, stack(0x00007f92c41de000,0x00007f92c42df000)] Stack: [0x00007f92c41de000,0x00007f92c42df000], sp=0x00007f92c42dd4a0, free space=1021k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) V [libjvm.so+0xaa3d82] V [libjvm.so+0x4d85e7] V [libjvm.so+0x8e0be0] V [libjvm.so+0x8db29e] V [libjvm.so+0xaa01ec] V [libjvm.so+0x5dfde6] V [libjvm.so+0xa3c80a] V [libjvm.so+0x5e11ed] V [libjvm.so+0x5cb5df] V [libjvm.so+0xa6640a] V [libjvm.so+0xa666f5] V [libjvm.so+0x623f6f] V [libjvm.so+0xa49d5b] V [libjvm.so+0x6a3020] JNI_CreateJavaVM+0x60 C [libjli.so+0x2c53] C [libpthread.so.0+0x708a] start_thread+0xda --------------- P R O C E S S --------------- Java Threads: ( => current thread ) Other Threads: =>0x00007f92bc00e000 (exited) JavaThread "Unknown thread" [_thread_in_vm, id=1029, stack(0x00007f92c41de000,0x00007f92c42df000)] VM state:not at safepoint (not fully initialized) VM Mutex/Monitor currently owned by a thread: None GC Heap History (0 events): No events Deoptimization events (0 events): No events Internal exceptions (0 events): No events Events (0 events): No events Dynamic libraries: 540000000-615550000 rw-p 00000000 00:00 0 5558f48ce000-5558f48cf000 r-xp 00000000 ca:01 407084 /usr/lib/jvm/java-8-openjdk/jre/bin/java 5558f4ace000-5558f4acf000 r--p 00000000 ca:01 407084 /usr/lib/jvm/java-8-openjdk/jre/bin/java 5558f4acf000-5558f4ad0000 rw-p 00001000 ca:01 407084 /usr/lib/jvm/java-8-openjdk/jre/bin/java 5558f55b7000-5558f55d8000 rw-p 00000000 00:00 0 [heap] 7f92abbff000-7f92ac2aa000 rw-p 00000000 00:00 0 7f92ac2aa000-7f92acfff000 ---p 00000000 00:00 0 7f92acfff000-7f92ad000000 rw-p 00000000 00:00 0 7f92ad000000-7f92ad270000 rwxp 00000000 00:00 0 7f92ad270000-7f92bc000000 ---p 00000000 00:00 0 7f92bc000000-7f92bc038000 rw-p 00000000 00:00 0 7f92bc038000-7f92c0000000 ---p 00000000 00:00 0 7f92c0da6000-7f92c0db0000 rw-p 00000000 00:00 0 7f92c0db0000-7f92c1166000 ---p 00000000 00:00 0 7f92c1166000-7f92c116e000 r-xp 00000000 ca:01 427757 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libzip.so 7f92c116e000-7f92c136d000 ---p 00008000 ca:01 427757 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libzip.so 7f92c136d000-7f92c136e000 r--p 00007000 ca:01 427757 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libzip.so 7f92c136e000-7f92c136f000 rw-p 00008000 ca:01 427757 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libzip.so 7f92c136f000-7f92c137a000 r-xp 00000000 ca:01 396550 /usr/lib/libnss_files-2.26.so 7f92c137a000-7f92c1579000 ---p 0000b000 ca:01 396550 /usr/lib/libnss_files-2.26.so 7f92c1579000-7f92c157a000 r--p 0000a000 ca:01 396550 /usr/lib/libnss_files-2.26.so 7f92c157a000-7f92c157b000 rw-p 0000b000 ca:01 396550 /usr/lib/libnss_files-2.26.so 7f92c157b000-7f92c1581000 rw-p 00000000 00:00 0 7f92c1581000-7f92c158c000 r-xp 00000000 ca:01 396574 /usr/lib/libnss_nis-2.26.so 7f92c158c000-7f92c178b000 ---p 0000b000 ca:01 396574 /usr/lib/libnss_nis-2.26.so 7f92c178b000-7f92c178c000 r--p 0000a000 ca:01 396574 /usr/lib/libnss_nis-2.26.so 7f92c178c000-7f92c178d000 rw-p 0000b000 ca:01 396574 /usr/lib/libnss_nis-2.26.so 7f92c178d000-7f92c17a1000 r-xp 00000000 ca:01 396559 /usr/lib/libnsl-2.26.so 7f92c17a1000-7f92c19a1000 ---p 00014000 ca:01 396559 /usr/lib/libnsl-2.26.so 7f92c19a1000-7f92c19a2000 r--p 00014000 ca:01 396559 /usr/lib/libnsl-2.26.so 7f92c19a2000-7f92c19a3000 rw-p 00015000 ca:01 396559 /usr/lib/libnsl-2.26.so 7f92c19a3000-7f92c19a5000 rw-p 00000000 00:00 0 7f92c19a5000-7f92c19ac000 r-xp 00000000 ca:01 396547 /usr/lib/libnss_compat-2.26.so 7f92c19ac000-7f92c1bab000 ---p 00007000 ca:01 396547 /usr/lib/libnss_compat-2.26.so 7f92c1bab000-7f92c1bac000 r--p 00006000 ca:01 396547 /usr/lib/libnss_compat-2.26.so 7f92c1bac000-7f92c1bad000 rw-p 00007000 ca:01 396547 /usr/lib/libnss_compat-2.26.so 7f92c1bad000-7f92c1bdb000 r-xp 00000000 ca:01 427720 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libjava.so 7f92c1bdb000-7f92c1dda000 ---p 0002e000 ca:01 427720 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libjava.so 7f92c1dda000-7f92c1ddb000 r--p 0002d000 ca:01 427720 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libjava.so 7f92c1ddb000-7f92c1ddd000 rw-p 0002e000 ca:01 427720 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libjava.so 7f92c1ddd000-7f92c1dea000 r-xp 00000000 ca:01 427706 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libverify.so 7f92c1dea000-7f92c1fe9000 ---p 0000d000 ca:01 427706 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libverify.so 7f92c1fe9000-7f92c1feb000 r--p 0000c000 ca:01 427706 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libverify.so 7f92c1feb000-7f92c1fec000 rw-p 0000e000 ca:01 427706 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/libverify.so 7f92c1fec000-7f92c1ff3000 r-xp 00000000 ca:01 396587 /usr/lib/librt-2.26.so 7f92c1ff3000-7f92c21f2000 ---p 00007000 ca:01 396587 /usr/lib/librt-2.26.so 7f92c21f2000-7f92c21f3000 r--p 00006000 ca:01 396587 /usr/lib/librt-2.26.so 7f92c21f3000-7f92c21f4000 rw-p 00007000 ca:01 396587 /usr/lib/librt-2.26.so 7f92c21f4000-7f92c233f000 r-xp 00000000 ca:01 396580 /usr/lib/libm-2.26.so 7f92c233f000-7f92c253e000 ---p 0014b000 ca:01 396580 /usr/lib/libm-2.26.so 7f92c253e000-7f92c253f000 r--p 0014a000 ca:01 396580 /usr/lib/libm-2.26.so 7f92c253f000-7f92c2540000 rw-p 0014b000 ca:01 396580 /usr/lib/libm-2.26.so 7f92c2540000-7f92c31e3000 r-xp 00000000 ca:01 427760 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/server/libjvm.so 7f92c31e3000-7f92c33e3000 ---p 00ca3000 ca:01 427760 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/server/libjvm.so 7f92c33e3000-7f92c3477000 r--p 00ca3000 ca:01 427760 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/server/libjvm.so 7f92c3477000-7f92c349f000 rw-p 00d37000 ca:01 427760 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/server/libjvm.so 7f92c349f000-7f92c34d0000 rw-p 00000000 00:00 0 7f92c34d0000-7f92c367e000 r-xp 00000000 ca:01 396576 /usr/lib/libc-2.26.so 7f92c367e000-7f92c387d000 ---p 001ae000 ca:01 396576 /usr/lib/libc-2.26.so 7f92c387d000-7f92c3881000 r--p 001ad000 ca:01 396576 /usr/lib/libc-2.26.so 7f92c3881000-7f92c3883000 rw-p 001b1000 ca:01 396576 /usr/lib/libc-2.26.so 7f92c3883000-7f92c3887000 rw-p 00000000 00:00 0 7f92c3887000-7f92c388a000 r-xp 00000000 ca:01 396577 /usr/lib/libdl-2.26.so 7f92c388a000-7f92c3a89000 ---p 00003000 ca:01 396577 /usr/lib/libdl-2.26.so 7f92c3a89000-7f92c3a8a000 r--p 00002000 ca:01 396577 /usr/lib/libdl-2.26.so 7f92c3a8a000-7f92c3a8b000 rw-p 00003000 ca:01 396577 /usr/lib/libdl-2.26.so 7f92c3a8b000-7f92c3a99000 r-xp 00000000 ca:01 427763 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/jli/libjli.so 7f92c3a99000-7f92c3c98000 ---p 0000e000 ca:01 427763 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/jli/libjli.so 7f92c3c98000-7f92c3c99000 r--p 0000d000 ca:01 427763 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/jli/libjli.so 7f92c3c99000-7f92c3c9a000 rw-p 0000e000 ca:01 427763 /usr/lib/jvm/java-8-openjdk/jre/lib/amd64/jli/libjli.so 7f92c3c9a000-7f92c3cb0000 r-xp 00000000 ca:01 399898 /usr/lib/libz.so.1.2.11 7f92c3cb0000-7f92c3eaf000 ---p 00016000 ca:01 399898 /usr/lib/libz.so.1.2.11 7f92c3eaf000-7f92c3eb0000 r--p 00015000 ca:01 399898 /usr/lib/libz.so.1.2.11 7f92c3eb0000-7f92c3eb1000 rw-p 00016000 ca:01 399898 /usr/lib/libz.so.1.2.11 7f92c3eb1000-7f92c3eca000 r-xp 00000000 ca:01 396603 /usr/lib/libpthread-2.26.so 7f92c3eca000-7f92c40c9000 ---p 00019000 ca:01 396603 /usr/lib/libpthread-2.26.so 7f92c40c9000-7f92c40ca000 r--p 00018000 ca:01 396603 /usr/lib/libpthread-2.26.so 7f92c40ca000-7f92c40cb000 rw-p 00019000 ca:01 396603 /usr/lib/libpthread-2.26.so 7f92c40cb000-7f92c40cf000 rw-p 00000000 00:00 0 7f92c40cf000-7f92c40f4000 r-xp 00000000 ca:01 396592 /usr/lib/ld-2.26.so 7f92c41de000-7f92c41e1000 ---p 00000000 00:00 0 7f92c41e1000-7f92c42e1000 rw-p 00000000 00:00 0 7f92c42e7000-7f92c42ef000 rw-s 00000000 00:26 21873 /tmp/hsperfdata_mango/1026 7f92c42ef000-7f92c42f0000 rw-p 00000000 00:00 0 7f92c42f0000-7f92c42f1000 r--p 00000000 00:00 0 7f92c42f1000-7f92c42f3000 rw-p 00000000 00:00 0 7f92c42f3000-7f92c42f4000 r--p 00024000 ca:01 396592 /usr/lib/ld-2.26.so 7f92c42f4000-7f92c42f5000 rw-p 00025000 ca:01 396592 /usr/lib/ld-2.26.so 7f92c42f5000-7f92c42f6000 rw-p 00000000 00:00 0 7ffd25f1a000-7ffd25f3b000 rw-p 00000000 00:00 0 [stack] 7ffd25f7b000-7ffd25f7d000 r--p 00000000 00:00 0 [vvar] 7ffd25f7d000-7ffd25f7f000 r-xp 00000000 00:00 0 [vdso] VM Arguments: jvm_args: -Xms10g -Xmx10g -Dma.home=/var/opt/mango -Djava.library.path=/var/opt/mango/overrides/lib:/var/opt/mango/lib:/usr/lib/jni/:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl java_command: com.serotonin.m2m2.Main java_class_path (initial): /var/opt/mango/overrides/classes:/var/opt/mango/classes:/var/opt/mango/overrides/properties:/var/opt/mango/overrides/lib/*:/var/opt/mango/lib/xmlbeans-2.6.0.jar:/var/opt/mango/lib/commons-dbcp-1.4.jar:/var/opt/mango/lib/commons-beanutils-1.9.3.jar:/var/opt/mango/lib/asm-commons-5.0.1.jar:/var/opt/mango/lib/spring-context-4.3.7.RELEASE.jar:/var/opt/mango/lib/taglibs-standard-impl-1.2.5.jar:/var/opt/mango/lib/spring-webmvc-4.3.7.RELEASE.jar:/var/opt/mango/lib/jsr311-api-1.1.1.jar:/var/opt/mango/lib/commons-codec-1.6.jar:/var/opt/mango/lib/jta-1.1.jar:/var/opt/mango/lib/ma-shared-1.2.3.jar:/var/opt/mango/lib/spring-test-4.0.5.RELEASE.jar:/var/opt/mango/lib/jscience-4.3.1.jar:/var/opt/mango/lib/http2-common-9.3.11.v20160721.jar:/var/opt/mango/lib/jetty-util-ajax-9.3.11.v20160721.jar:/var/opt/mango/lib/jetty-util-9.3.11.v20160721.jar:/var/opt/mango/lib/jetty-alpn-server-9.3.11.v20160721.jar:/var/opt/mango/lib/log4j-jcl-2.8.1.jar:/var/opt/mango/lib/dom4j-1.6.1.jar:/var/opt/mango/lib/websocket-server-9.3.11.v20160721.jar:/var/opt/mango/lib/jetty-servlets-9.3.11.v20160721.jar:/var/opt/mango/lib/swagger-core_2.10-1.3.7.jar:/var/opt/mango/lib/backport-util-concurrent-3.1.jar:/var/opt/mango/lib/jetty-http-9.3.11.v20160721.jar:/var/opt/mango/lib/jdom-1.1.3.jar:/var/opt/mango/lib/spring-tx-4.3.7.RELEASE.jar:/var/opt/mango/lib/jackson-annotations-2.8.6.jar:/var/opt/mango/lib/websocket-api-9.3.11.v20160721.jar:/var/opt/mango/lib/hibernate-core-3.3.0.GA.jar:/var/opt/mango/lib/annotations-2.0.1.jar:/var/opt/mango/lib/jackson-module-jsonSchema-2.1.0.jar:/var/opt/mango/lib/spring-beans-4.3.7.RELEASE.jar:/var/opt/mango/lib/jetty-xml-9.3.11.v20160721.jar:/var/opt/mango/lib/commons-collections-3.2.2.jar:/var/opt/mango/lib/jcommon-1.0.23.jar:/var/opt/mango/lib/paranamer-2.6.jar:/var/opt/mango/lib/java-semver-0.9.0.jar:/var/opt/mango/lib/json4s-core_2.10-3.2.9.jar:/var/opt/mango/lib/httpmime-4.5.3.jar:/var/opt/mango/lib/joda-convert-1.6.jar:/var/opt/mango/lib/a Launcher Type: SUN_STANDARD Environment Variables: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl USERNAME=mango SHELL=/sbin/nologin Signal Handlers: SIGSEGV: [libjvm.so+0xaa46c0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGBUS: [libjvm.so+0xaa46c0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGFPE: [libjvm.so+0x8dc3d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGPIPE: [libjvm.so+0x8dc3d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGXFSZ: [libjvm.so+0x8dc3d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGILL: [libjvm.so+0x8dc3d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO SIGUSR1: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none SIGUSR2: [libjvm.so+0x8dc280], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO SIGHUP: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none SIGINT: SIG_IGN, sa_mask[0]=00000000000000000000000000000000, sa_flags=none SIGTERM: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none SIGQUIT: SIG_IGN, sa_mask[0]=00000000000000000000000000000000, sa_flags=none --------------- S Y S T E M --------------- OS:NAME="Arch Linux" PRETTY_NAME="Arch Linux" ID=arch ID_LIKE=archlinux ANSI_COLOR="0;36" HOME_URL="https://www.archlinux.org/" SUPPORT_URL="https://bbs.archlinux.org/" BUG_REPORT_URL="https://bugs.archlinux.org/" uname:Linux 4.9.65-1-ec2-lts #1 SMP Wed Nov 29 09:39:59 PST 2017 x86_64 libc:glibc 2.26 NPTL 2.26 rlimit: STACK 8192k, CORE infinity, NPROC 7931, NOFILE 4096, AS infinity load average:0.00 0.01 0.00 /proc/meminfo: MemTotal: 2046976 kB MemFree: 1639152 kB MemAvailable: 1771804 kB Buffers: 46116 kB Cached: 190884 kB SwapCached: 0 kB Active: 174148 kB Inactive: 128432 kB Active(anon): 65776 kB Inactive(anon): 616 kB Active(file): 108372 kB Inactive(file): 127816 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 2097148 kB SwapFree: 2097148 kB Dirty: 404 kB Writeback: 0 kB AnonPages: 65652 kB Mapped: 93208 kB Shmem: 744 kB Slab: 73184 kB SReclaimable: 56428 kB SUnreclaim: 16756 kB KernelStack: 2636 kB PageTables: 13808 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 3120636 kB Committed_AS: 3805300 kB VmallocTotal: 34359738367 kB VmallocUsed: 0 kB VmallocChunk: 0 kB HardwareCorrupted: 0 kB AnonHugePages: 2048 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB DirectMap4k: 12288 kB DirectMap2M: 2084864 kB CPU:total 1 (initial active 1) (1 cores per cpu, 1 threads per core) family 6 model 63 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, lzcnt, tsc, bmi1, bmi2 /proc/cpuinfo: processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 63 model name : Intel(R) Xeon(R) CPU E5-2676 v3 @ 2.40GHz stepping : 2 microcode : 0x3b cpu MHz : 2400.085 cache size : 30720 KB physical id : 0 siblings : 1 core id : 0 cpu cores : 1 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm constant_tsc rep_good nopl xtopology eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm fsgsbase bmi1 avx2 smep bmi2 erms invpcid xsaveopt bugs : bogomips : 4800.13 clflush size : 64 cache_alignment : 64 address sizes : 46 bits physical, 48 bits virtual power management: Memory: 4k page, physical 2046976k(1639152k free), swap 2097148k(2097148k free) vm_info: OpenJDK 64-Bit Server VM (25.144-b01) for linux-amd64 JRE (1.8.0_144-b01), built on Jul 28 2017 20:07:18 by "builduser" with gcc 7.1.1 20170630 time: Thu Dec 7 11:39:30 2017 elapsed time: 0 seconds (0d 0h 0m 0s)dmesg had no related information. :(
Were you redirecting stderr to ma.out? Perhaps there is an error escaping to stderr.
out.shis linked toext-enabledgenerating the 2 log files I posted above,$MA_HOME/logs/ma.outand$MA_HOME/logs/ma.errThat's what is so puzzling about all this, no error message output whatsoever.
I've noticed a few unexpected log messages, wonder if they give you any clues:
INFO 2017-12-12T12:11:37,696 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /var/opt/mango/web/modules/dashboardDesigner/web/dox/manifest.xml INFO 2017-12-12T12:11:37,505 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /var/opt/mango/web/modules/mangoUI/web/dox/manifest.xml WARN 2017-12-12T12:12:23,719 (org.springframework.web.servlet.handler.SimpleUrlHandlerMapping.registerHandlers:114) - Neither 'urlMap' nor 'mappings' set on SimpleUrlHandlerMapping INFO 2017-12-12T12:12:25,371 (com.serotonin.m2m2.Lifecycle.configureDwr:1169) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.modbus.dwr.ModbusEditDwr(edited to include only interesting entries)
The good news: I finally migrated the data. I think.
The bad news: I still don't know why java crashes
In frustration, I finally ran the migration with 1 low-priority thread, and in about 15 minutes, it finally completed — sort of.
I tried updating java to 1.8.0_152; no effect
Added 4GB swap (in addition to the 1GB already configured): no effect
I executed the migration on a VirtualBox VM: no problem, success in about 3 minutesFinally, migrated on the server in question with 1 low-priority thread, It executed for 923 seconds — then stopped. I feared it had crashed again, but I noticed mango was still alive, so I checked a few things.
That's when it got interesting.
The migration page was seemingly stalled at 19648161 of 38879054
But in the log file, it claimed to have successfully completed:INFO 2017-12-15T16:03:36,024 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:70) - Starting Data Migration, please wait... INFO 2017-12-15T16:18:59,072 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:151) - Migrated 19648161 point values. INFO 2017-12-15T16:18:59,072 (com.infiniteautomation.nosql.maint.MangoNoSqlMigrationWorkItem.execute:155) - Finished Data Migration, 19648161 point values migrated to Time Series Datastore took 923.048sEventually my eye caught that the 19648161 was (approximately) the same number I had seen in my successful simulation on the VirtualBox instance:
But a quick query on the original db shows:MariaDB [mango]> SELECT COUNT(*) FROM pointValues; +----------+ | COUNT(*) | +----------+ | 38879054 | +----------+Curiously, the “successful” migrations show about half the total. I also notice (especially on the actual server) that the total changes a few times during the migration.
So please help me understand: did the data migrate? Or only half? What am I not understanding?
The crashing seems obvious to be a java problem, but I can't glean any diagnostic information to pursue further. Note that this instance is running on an Arm architecture, so that might be a factor as well.
