    How to Publisher data point type HTTP Image to another mango.
    12 Posts 3 Posters 6.5k Views 2 Watching
    • T Offline
      thirawad
      what the idea of send out data point type HTTP Image from one mango to another mango in the normally way. i can't find them.
      some idea is setup inside config of the camera about FTP and send data direct to another place by itself. but i don't know the solution to get the image from the place to data point or show in dashboard by refresh the new coming image every time.
      I hope somebody need to know or need help like me.
      Thank you for read, help and share.
        Hi thirawad,
        Have you looked into the Mango Persistent Data Source and the Mango Persistent publisher? This mechanism is capable of publishing image data.
        • T Offline
          thirawad
          Hi Phildunlap
          Mango Persistent, it available in mango license version.
          I need to try it. How can i get the license for 30 days for 2 GUID.
          if you please me :)
            You could try it on a free 2.8.8 Mango, or you can email your two GUIDs in with some information about why you want a trial license, and then we can grant you that.
            • T Offline
              thirawad @phildunlap
              @phildunlap
              • T Offline
                thirawad
                Thank you very much.
                  JoelHaggar @thirawad
                  @thirawad You can also email your GUID support@infiniteautomation.com and request a trial license which will be sent back to you. You can find your GUID on under Administration > Modules.
                  • T Offline
                    thirawad @JoelHaggar
                    @joelhaggar
                    Thank your very much for your support.
                    let me prepare and send GUIDs for request a trial licese.
                    So back in to the main topic about Publisher data point type HTTP image
                    for now , i'm try to checking in publisher -> Mango Persistent TCP
                    on my mango unlicensed type :
                    modules core version 3.2.2+20171009170034
                    modules persistent version 3.2.1
                    I see the data source type numeric, binary but don't have image type to publish.
                    Let me show in picture below
                    Is depend on license or not?
                    or Mango persistent TCP still can't send the data point type image.
                      Hi thirawad,
                      Well, it looks like you may be the first person trying this in a long time.
                      I tried it, and I discovered the points are not in that table! They should be! I will fix this. However, you can still import the publisher with the XID for the image point, and so long as you don't use those tables to modify the points again (since the image will be missing), you should be fine. Here's the git issue: https://github.com/infiniteautomation/ma-core-public/issues/1152
                      I also discovered the data point details page errors if an image is from a type of data source other than HTTP image. But, you can correct this error by modifying or replacing Mango/web/WEB-INF/snippet/imageValueThumbnail.jsp to be the same as the latest in the repository: https://github.com/infiniteautomation/ma-core-public/blob/main/Core/web/WEB-INF/snippet/imageValueThumbnail.jsp
                      With these two steps, I was able to publish images through the Persistent Publisher.
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        Hi phildunlap
                        clever! and thank you very much for your tried.
                        so, because of your mango is very well, i'm very interesting.
                        let me checking by your suggestions.
                        • T Offline
                          Hi Phildunlan
                          it is very well, you are clever and make me happy.
                          so the mango persistent working good!
                          for clearly the step to publish HTTP image as below
                          step1: (mango in raspberry pi) add mango persistent TCP for get publish xid and setting Host, Port and Authorization key. this step we can add all data point except image
                          step2 (need only for add image to persistent) if we have data point xid of image already. go to Administration/configuration import/export and export.
                          setp3 copy code to text edit and insert xid of image directly with the same format.
                          copy all code and paste back to the configuration and import.
                          step4 modifying or replacing Mango/web/WEB-INF/snippet/imageValueThumbnail.jsp to be the same as the latest in the repository: https://github.com/infiniteautomation/ma-core-public/blob/main/Core/web/WEB-INF/snippet/imageValueThumbnail.jsp
                          with 4 step mango in raspberry pi well published to the host.
                          step5 (on PC) setup mango persistent TCP data source to receive. set some port and authorization same as on sender setting (raspberry pi) and test get status.
                          all data point form sender side add automatically in to your PC and we got image :)
                          Thank you Mr.Phildunlap again for your help.
                            Hi thirawad,
                            :D
                            Thank you for documenting the solution so clearly. Image points will appear in the publisher's table in 3.3, but this will be helpful until that is released, for sure!
