    Mango fails to start with java error
    11 Posts 2 Posters 6.5k Views 2 Watching
    • A Offline
      agallo
      Fresh install of Debian 8.9 and jdk1.8.0_144
      Mango fails to start with the following error:
      <snip>
      Exception in thread "main" java.lang.UnsatisfiedLinkError: /usr/local/java/jdk1.8.0_144/jre/lib/i386/libawt_xawt.so: libXext.so.6: cannot open shared object file: No such file or directory
      <snip>
      however, the file exists:
      0:/opt/mango/bin# file /usr/local/java/jdk1.8.0_144/jre/lib/i386/libawt_xawt.so
      /usr/local/java/jdk1.8.0_144/jre/lib/i386/libawt_xawt.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=d6e0fd635954c4e417d1e2b0a6aa2bcf7d6e8449, not stripped
      And libXext.so.6 exists:
      0:/opt/mango/bin# find / -name libXext.so.6
      /usr/lib/x86_64-linux-gnu/libXext.so.6
      0:/opt/mango/bin# file /usr/lib/x86_64-linux-gnu/libXext.so.6
      /usr/lib/x86_64-linux-gnu/libXext.so.6: symbolic link to libXext.so.6.4.0
        Hi agallo,
        How did you install Java? Have you defined JAVA_HOME? Something like...
        JAVA_HOME=/usr/local/java/jdk1.8.0_144
        in /etc/environment then . /etc/environment and try to start it again.
          I wonder if you can try web.openBrowserOnStartup=false in your Mango/overrides/properties/env.properties or Mango/classes/env.properties file. What's the full output from ./ma.sh start?
          A 1 Reply Last reply Reply Quote 0
          • A Offline
            agallo
            Followed the instructions Linux Installation
            $JAVA_HOME is set
            0:/opt/mango/bin# echo $JAVA_HOME
            One thing I'll note about the instructions at the above link, one of the commands seems to be in the wrong format:
            sudo update-alternatives --install java /usr/bin/java /usr/local/java/jdk1.8.0_144/bin/java
            update-alternatives: --install needs <link> <name> <path> <priority>
            Use 'update-alternatives --help' for program usage information.
            I don't think that is causing my problem.
            Java seems to be working
            0:~$ java -version
            java version "1.8.0_144"
            Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
            Java HotSpot(TM) Server VM (build 25.144-b01, mixed mode)
            0:~$ javac -version
            javac 1.8.0_144
            Thank you
              Try it with web.openBrowserOnStartup=false (I think you were writing your last post when I was writing mine)
              • A Offline
                agallo @phildunlap
                @phildunlap said in Mango fails to start with java error:
                I changed web.openBrowserOnStartup to false in /opt/mango/classes.env.properties. Same results. Below is the full output from the startup
                0:/opt/mango/bin# ./ma.sh start
                MA_HOME is /opt/mango
                root@MangoAutomation-0:/opt/mango/bin# ma-start: MA started with Process ID:  7475
                INFO  2017-08-24T15:27:24,701 (com.serotonin.m2m2.Main.main:90) - Starting Mango 3.2.0+20170807191436 with Schema Version: 17
                INFO  2017-08-24T15:27:24,915 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sstGraphics', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,933 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'watchlists', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,957 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dataImport', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,962 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'meta', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,969 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'excelReports', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,972 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mangoApi', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,973 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mbus', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,976 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'reports', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,978 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'log4JReset', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,979 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'ssh', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,980 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sqlConsole', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,982 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'virtualDS', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,984 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pakbus', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,986 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'vmstat', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,989 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'onewire', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,990 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'maintenanceEvents', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,992 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'egauge', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,994 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'loggingConsole', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,996 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'serial', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,997 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'deviceConfig', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:24,998 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/deviceConfig/web/dox/manifest.xml
                INFO  2017-08-24T15:27:24,999 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mangoUI', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,000 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/mangoUI/web/dox/manifest.xml
                INFO  2017-08-24T15:27:25,019 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dashboardDesigner', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,020 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/dashboardDesigner/web/dox/manifest.xml
                INFO  2017-08-24T15:27:25,021 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'jsonFileImport', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,023 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dataFile', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,026 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pop3', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,028 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'TCPIP', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,030 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mqttClientDataSource', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,031 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'asciiFile', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,033 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'Haystack', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,035 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'snmp', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,043 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'envcands', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,044 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'controlcore', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,046 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'scheduledEvents', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,050 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'graphicalViews', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,061 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dnp3', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,063 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'http', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,068 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sstGlobalScripts', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,070 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'twilio', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,072 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sqlds', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,073 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'templateConfig', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,075 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'log4jDS', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,076 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'modbus', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,078 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'BACnet', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,080 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'scripting', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,082 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'opcda', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,082 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pointLinks', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:25,084 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'internal', v3.2.0 by Infinite Automation
                INFO  2017-08-24T15:27:26,083 (com.serotonin.m2m2.Lifecycle.initialize:192) - Initializing Spring Object Mapper
                INFO  2017-08-24T15:27:26,517 (com.serotonin.m2m2.Lifecycle.loadLic:508) - Checking license...
                INFO  2017-08-24T15:27:26,517 (com.serotonin.m2m2.Lifecycle.loadLic:594) - License file not found
                INFO  2017-08-24T15:27:26,620 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                INFO  2017-08-24T15:27:27,489 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 3.2.0+20170807191436, db 17
                INFO  2017-08-24T15:27:27,573 (com.serotonin.m2m2.rt.RuntimeManager.initialize:160) - Starting 0 Publishers...
                INFO  2017-08-24T15:27:27,573 (com.serotonin.m2m2.rt.RuntimeManager.initialize:172) - 0 Publisher's started in 1ms
                        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
                        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941)
                        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1824)
                        at java.lang.Runtime.load0(Runtime.java:809)
                        at java.lang.System.load(System.java:1086)
                        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1845)
                        at java.lang.Runtime.loadLibrary0(Runtime.java:870)
                        at java.lang.System.loadLibrary(System.java:1122)
                        at java.awt.Toolkit$3.run(Toolkit.java:1636)
                        at java.awt.Toolkit$3.run(Toolkit.java:1634)
                        at java.security.AccessController.doPrivileged(Native Method)
                        at java.awt.Toolkit.loadLibraries(Toolkit.java:1633)
                        at java.awt.Toolkit.<clinit>(Toolkit.java:1668)
                        at com.serotonin.m2m2.view.ViewGraphicLoader.loadDirectory(ViewGraphicLoader.java:109)
                        at com.serotonin.m2m2.view.ViewGraphicLoader.loadModuleGraphics(ViewGraphicLoader.java:56)
                        at com.serotonin.m2m2.view.ViewGraphicLoader.loadViewGraphics(ViewGraphicLoader.java:44)
                        at com.serotonin.m2m2.Lifecycle.imageSetInitialize(Lifecycle.java:1357)
                        at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:317)
                        at com.serotonin.m2m2.Main.main(Main.java:125)
                Thanks for your help
                  If you have an env.properties file in Mango/overrides/properties you will need to have changed that one (Edit: this is definitely not the problem). Can you get the full ouput again, but this time move Mango/classes/log4j2.xml to Mango/classes/normal-log4j2.xml and move Mango/classes/debug-log4j2.xml to Mango/classes/log4j2.xml and try starting again. That should give us more logging.
                  Edit: Nevermind, that stack trace will probably show me all I need... one moment please...
                    Googling the link error suggests you may have the wrong 32 bit / 64 bit version of Java installed. Can you check that? What's the name of the .tar.gz file you used and what's your uname -a
                    • A Offline
                      agallo
                      I made the following changes:
                      mv log4j2.xml normal-log4j2.xml
                      mv debug-log4j2.xml log4j2.xml
                      Also, I created a file /opt/mango/overrides/properties/env.properties with web.openBrowserOnStartup=false
                      The startup output is below. The web server does start, and reports 85% progress "Initializing Web Image Set" and displays the contents of logging/ma.log
                      INFO  2017-08-24T16:09:24,429 (com.serotonin.m2m2.Main.main:90) - Starting Mango 3.2.0+20170807191436 with Schema Version: 17
                      INFO  2017-08-24T16:09:24,659 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sstGraphics', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,679 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'watchlists', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,694 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dataImport', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,696 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'meta', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,699 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'excelReports', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,702 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mangoApi', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,704 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mbus', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,707 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'reports', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,709 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'log4JReset', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,710 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'ssh', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,712 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sqlConsole', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,714 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'virtualDS', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,716 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pakbus', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,718 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'vmstat', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,721 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'onewire', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,723 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'maintenanceEvents', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,725 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'egauge', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,727 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'loggingConsole', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,729 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'serial', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,730 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'deviceConfig', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,732 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/deviceConfig/web/dox/manifest.xml
                      INFO  2017-08-24T16:09:24,733 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mangoUI', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,734 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/mangoUI/web/dox/manifest.xml
                      INFO  2017-08-24T16:09:24,752 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dashboardDesigner', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,753 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: /opt/mango/web/modules/dashboardDesigner/web/dox/manifest.xml
                      INFO  2017-08-24T16:09:24,754 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'jsonFileImport', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,756 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dataFile', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,760 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pop3', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,762 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'TCPIP', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,764 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'mqttClientDataSource', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,766 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'asciiFile', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,768 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'Haystack', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,769 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'snmp', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,772 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'envcands', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,774 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'controlcore', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,775 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'scheduledEvents', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,777 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'graphicalViews', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,780 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'dnp3', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,782 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'http', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,785 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sstGlobalScripts', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,786 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'twilio', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,788 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'sqlds', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,790 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'templateConfig', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,792 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'log4jDS', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,794 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'modbus', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,796 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'BACnet', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,798 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'scripting', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,800 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'opcda', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,800 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'pointLinks', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:24,802 (com.serotonin.m2m2.Main.loadModules:544) - Loading module 'internal', v3.2.0 by Infinite Automation
                      INFO  2017-08-24T16:09:25,766 (com.serotonin.m2m2.Lifecycle.initialize:192) - Initializing Spring Object Mapper
                      INFO  2017-08-24T16:09:25,935 (org.eclipse.jetty.util.log.Log.initialized:192) - Logging initialized @2588ms
                      INFO  2017-08-24T16:09:26,043 (org.eclipse.jetty.server.Server.doStart:345) - jetty-9.3.11.v20160721
                      INFO  2017-08-24T16:09:26,101 (org.eclipse.jetty.server.AbstractConnector.doStart:270) - Started ServerConnector@c58fd0{HTTP/1.1,[http/1.1, h2c, h2c-17, h2c-16, h2c-15, h2c-14]}{0.0.0.0:8080}
                      INFO  2017-08-24T16:09:26,103 (org.eclipse.jetty.server.Server.doStart:403) - Started @2757ms
                      INFO  2017-08-24T16:09:26,177 (org.eclipse.jetty.server.handler.ContextHandler.doStart:781) - Started o.e.j.s.h.ContextHandler@1162e7{/,null,AVAILABLE}
                      INFO  2017-08-24T16:09:26,236 (com.serotonin.m2m2.Lifecycle.loadLic:508) - Checking license...
                      INFO  2017-08-24T16:09:26,237 (com.serotonin.m2m2.Lifecycle.loadLic:594) - License file not found
                      INFO  2017-08-24T16:09:26,345 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                      INFO  2017-08-24T16:09:27,276 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 3.2.0+20170807191436, db 17
                      INFO  2017-08-24T16:09:27,409 (com.serotonin.m2m2.rt.RuntimeManager.initialize:160) - Starting 0 Publishers...
                      INFO  2017-08-24T16:09:27,409 (com.serotonin.m2m2.rt.RuntimeManager.initialize:172) - 0 Publisher's started in 1ms
                      Thank you.
                      • A Offline
                        agallo
                        Java version was the problem. I had installed Linux x86: jdk-8u144-linux-i586.tar.gz instead of Linux x64: jdk-8u144-linux-x64.tar.gz
                        Thank you so much for your help.
                        And to provide a little more detail for anyone searching:
                        What is probably painfully obvious to most of you, but didn't have much meaning for me, x86 refers to 32-bit environments, with x64 is for 64-bit.
                        I can gripe about the naming convention being either confusing or inconsistent, but in talking to coworkers, this is reality.
                        Thank you, Phil!
                          Certainly! Glad you got it resolved!
