    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 206.7k Views 3 Watching
      Upload your entire ma.log file. I also provided steps for trying again on a clean setup.
      A 1 Reply Last reply Reply Quote 0
      • A Offline
        arvand.owji @phildunlap
        @phildunlap [0_1500562677214_ma.log](Uploading 100%)
        Thanks. Are you able to see this file that i just uploaded? Thanks.
          Hi Arvand,
          No but I just changed something that might fix it. Can you try again?
          A 3 Replies Last reply Reply Quote 0
          • A Offline
            @phildunlap [0_1500564092507_ma.log](Uploading 100%)
            • A Offline
              @phildunlap said in Import javascript library:
              Hi Arvand,
              i odnt think its working. i can share it on google drive an send it to you privately.
              • A Offline
                Hi Arvand,
                Should i attempt to upgrade before trying clean?
                  I do not see Timer Already Cancelled errors in your log after you restarted Mango.
                  • A Offline
                    my bad. that was an old log. i sent you a newer one.
                      You ran out of memory using a large excel report. Are you using rollups? You should probably be watching the console output while you're developing your solution.
                      • A Offline
                        i dont understand. what i was developing is that simple httpget, unless that javascript load issue is causing issues up again.
                          ERROR 2017-07-19 13:31:23,974 (com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run:76) - Error in work item
                          java.lang.OutOfMemoryError: Java heap space
                          	at org.apache.xmlbeans.impl.store.Xobj$AttrXobj.newNode(Xobj.java:2780)
                          	at org.apache.xmlbeans.impl.store.Xobj.copyNode(Xobj.java:1112)
                          	at org.apache.xmlbeans.impl.store.Xobj.copy_contents_from(Xobj.java:2337)
                          	at org.apache.xmlbeans.impl.store.Xobj.copy(Xobj.java:2411)
                          	at org.apache.xmlbeans.impl.values.XmlObjectBase._copy(XmlObjectBase.java:169)
                          	at org.apache.xmlbeans.impl.values.XmlObjectBase._copy(XmlObjectBase.java:152)
                          	at org.apache.xmlbeans.impl.values.XmlObjectBase.copy(XmlObjectBase.java:122)
                          	at org.apache.poi.xssf.usermodel.XSSFRow.onDocumentWrite(XSSFRow.java:501)
                          	at org.apache.poi.xssf.usermodel.XSSFSheet.write(XSSFSheet.java:3357)
                          	at org.apache.poi.xssf.usermodel.XSSFSheet.commit(XSSFSheet.java:3321)
                          	at org.apache.poi.POIXMLDocumentPart.onSave(POIXMLDocumentPart.java:464)
                          	at org.apache.poi.POIXMLDocumentPart.onSave(POIXMLDocumentPart.java:469)
                          	at org.apache.poi.POIXMLDocument.write(POIXMLDocument.java:211)
                          	at com.infiniteautomation.mango.excelreports.rt.ExcelReportWorkItem.execute(ExcelReportWorkItem.java:527)
                          	at com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run(BackgroundProcessing.java:73)
                          	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                          	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                          if you are not using Excel Reports then delete whatever report this is and restart Mango.
                          • A Offline
                            thanks. i deleted it and it worked. Now i see the httpget running. but the issue is that it runs only the first time (when i enable the datasource). My update period is set to 2 min but i dont see the time stamp for the virtual DP to be ever updated after that initial enable toggle button clicked, Thanks.
                            • A Offline
                              arvand.owji @arvand.owji
                              @arvand.owji said in Import javascript library:
                              ok, just to be exact, it does seem that it actualy updates the DP but it doesnt do it every 2 minutes. I left it since the last post and I see the value time stamp is 13:50.
                              • A Offline
                                ok, so the problem was that the virtual data point was set to update every 10 min and the httpget was 2 minutes. I changed virtual dp to 2 min and now its working as expected. Thanks for the help :)
                                  Nice, glad you got it figured out!
                                  • A Offline
                                    arvand.owji
                                    Its been a while but i'm encountering a new issue that is very related to what we discussed here before. I developed the code and everything was working fine in the test box and i left it for few months. Didn't pay much attention until now.
                                    I have an HTTP Retriever that calls a local url (my file is in /opt/mango/web). This url, reads bunch of XIDs and then does some calculations and then sets bunch of other XIDs.
                                    My HTTP Retriever runs fine with no error (set on update every 2 minutes and I see it under Polls) but my values dont get updated. Its as if the code is not running. I dont see any errors in ma.log and so far i coudln't see any indication of an issue. Even when i enable/disable the data source, i still dont see the data being updated (in ma.log, i see the data source being disabled/enabled with no issue).
                                    To test the url for the http retriever, i manually ran it in a browser and it actually updated the values but if i do "curl" from the mango command prompt, i dont see the values being updated.
                                    Where can i see the actual result from HTTP Retriever, is there a log for it? Thanks.
                                      Hi arvand,
                                      It doesn't look like there's more logging to be enabled. Be sure to keep an eye on your events, as I would expect an event to be raised in Mango if there was an error. It's possible an error is escaping to stderr, but I wouldn't think so. You can launch Mango manually with /opt/mango/bin/ma.sh start and then trigger a poll to see if there's an exception escaping.
                                      More likely than not, if the checkmark on the data source fetches the data (unless your browser has some authenticating cookie), it's going to be a problem with a point of some kind. If you've made recent edits, I would try disabling those points, or all but one, and trying again.
                                      I do not know what you mean, "but if I do curl from the mango command prompt." I don't refer to anything as the Mango command prompt. Do you mean you SSH'ed into the device?
                                      • A Offline
                                        What imeant was that if i ssh to the box and run curl with the url, i still dont see the values being updated. The only case that it works is to run the url through a web browser.
                                          Running curl on the command line doesn't do anything to Mango.
                                          So, the checkmark opens the page successfully, the checkmark on the edit point for the value regex gets the right value, curl gets the data but it doesn't update in Mango (and was never supposed to), but when polling on its own the data source gets no values? Any chance you have an authentication cookie in your browser?
                                          You can email in your json for the Http retriever and a sample document to support@infiniteautomation.com or you can post it here and I'll look at it.
                                          • A Offline
                                            @phildunlap ok thanks. im trying it on a newer box now (version 3). If it doesnt work on this one either, i will let you know. It was working fine on the old box until it stopped.
