    libjSSC-2.8_armsf.so no such a file
    6 Posts 2 Posters 3.3k Views 2 Watching
    • F Offline
      fidelg
      Hi people.
      Im getting this ERROR as mango starts up, my installation is on a Linux 3.10.104 with an armv7l:
      com.infiniteautomation.mango.io.serial.SerialPortConfigException: /root/.jssc/linux/libjSSC-2.8_armsf.so: cannot open the shared file: No such a file
      What is strange is the file it mentions is exactlly there!
      Obviosly I cannot open any serial connection ... so
      If anyone can provide some help on solving this issue would be grea!
        Hi fidelg,
        It could be a permissions issue. Can you share the result of
        ls -l /root/.jssc/linux/
        and the user under which Mango is running?
          Also check the armsf and armhf text closely. Is it really a soft float device? What's the platform?
          • F Offline
            fidelg
            Thanks 4 the reply, here u have:
            root@odroid-jessie# ls -l /root/.jssc/linux/
            total 11
            -rw-r--r-- 1 root root 10779 mar 13 17:57 libjSSC-2.8_armsf.so
            Im running the mango with the user: admin
            And here the result of my lscpu
            Architecture: armv7l
            Byte Order: Little Endian
            CPU(s): 4
            On-line CPU(s) list: 0-3
            Thread(s) per core: 1
            Core(s) per socket: 4
            Socket(s): 1
            CPU max MHz: 1824.0000
            CPU min MHz: 24.0000
              The user "admin" is the user within Mango. I am wondering what the operating system user Mango is running under is.
              I expect the answer to be root, because it is autodetecting the path into /root but root can definitely read the file so no permissions issue.
              I don't think that's enough information to determine if it's really a hard float or a soft float, but we can be reasonably confident the correct architecture is being detected (edit: actually, I bet the jssc library copies the .so out of itself based on the jvm version, but I don't know) so this is probably just a curiousity. You can figure out that from the list of supported features for a processor core if you cat /proc/cpuinfo
                Googling yeilded this thread:
                http://stackoverflow.com/questions/22085552/unsatisfied-link-error-runnable-jar-referencing-jssc-library
                It seems to suggest some people solved their issue by reinstalling java, and one purports to have snagged the armhf.so file out of the jssc jar, placing that into the .jssc/linux/ directory and that solved his problem.
                To unzip a jar you can:
                cd Mango/lib;
                mkdir jssc;
                cp jssc-* jssc;
                cd jssc;
                unzip jssc*;
                #Files should now be in libs/linux/ if you need to grab them
