    How do I create a datasource using the Mango API?
    5 Posts 2 Posters 3.2k Views 2 Watching
    • G Offline
      gary
      Swagger shows some details of two API end points that potentially could be used. I'm not sure if I need to PUT to /rest/v1/data-sources/{XID} or POST to /rest/v1/data-sources . I have spent most time trying the PUT option as it is conceptually more appropriate but I get the same result either way.
      My attempts have been met with 500 Server Error because I have not uploaded a correctly specified JSON object. I need an explanation of the JSON schema to upload. I tried to create a copy of an existing datasource by uploading the exported JSON for the original with a modified parameter values. The format is not the same as the Swagger documentation specifies so I wasn't surprised I didn't get it to work.
      The swagger documentation doesn't make it obvious how to specify that it is a HTTP listener that I wish to create. There are parameters specific to this type that I want to set including IP white list and device ID white list.
      Can anyone fill in the gaps please?
      Gary
        Hi Gary,
        I think the problem you're experiencing is probably that there was a bug preventing the HTTP Receiver from being created or saved through the API. I fixed this and released a new version of the module, 1.6.2.
        If you've got that version, the easiest / best way to get the JSON model is by doing a GET for a data source you've made through the UI. But, here's the JSON for a an HTTP Receiver from my testing:
          "xid": "httpReceiver2",
          "name": "HTTP Receiver",
          "enabled": false,
          "modelType": "HTTP_RECEIVER",
          "validationMessages": [],
          "deviceIdWhiteList": [
          "setPointUrl": "",
          "ipWhiteList": [
          "editPermission": "",
          "purgeSettings": {
            "override": false,
            "frequency": {
              "periods": 1,
              "type": "YEARS"
          "alarmLevels": {
            "SET_POINT_FAILURE": "URGENT"
        One must use the POST /rest/v1/data-sources to create data sources, and the PUT /rest/v1/data-sources/[XID] to update existing data sources.
        Thanks for bringing that bug to our attention!
        G 1 Reply Last reply Reply Quote 1
        • G Offline
          gary @phildunlap
          @phildunlap Thank you. I will give it a try.
          • G Offline
            gary
            It works :)
              Glad to hear it!
