    MangoES System': Captured value is not numeric: For input string: "Disk Percent Used: ##########RAM############"
    5 Posts 3 Posters 3.5k Views 3 Watching
    • C Offline
      craig
      After upgrading from 2.7.10 to 2.8.4 our customer is getting the following NONE level event every 20-30s.
      /opt/info/systemInfo.txt contains the following
      ##########CPU############
      CPU UserSpace Load: 2.2
      CPU Kernel Load: 1.9
      CPU Total Load: 4.1
      CPU Temp: 50.0
      ########DISK##########
      Disk Name: /dev/mmcblk0p2 /dev/mmcblk0p1
      Disk Total Size: Disk Space Used: Disk Space Left: Disk Percent Used: ##########RAM############
      Physical Memory Total: 2023
      Physical Memory Used: 1836
      Physical Memory Free: 187
      Swap Memory Total: 0
      Swap Memory Used: 0
      Swap Memory Free: 0
      ########SYSTEMTIME############
      SystemTime: Fri Dec  9 09:50:05 PST 2016
      #######UPTIME######
      UpTime:  09:50:05 up 233 days, 15:20,  1 user,  load average: 0.40, 0.48, 1.34
      mango@mangoES2147:/usr/sbin/systemInfo$uname -p
      unknown
      mango@mangoES2147:/usr/sbin/systemInfo$df -m
      Filesystem     1M-blocks  Used Available Use% Mounted on
      /dev/mmcblk0p2      7082  5169      1574  77% /
      udev                  10     0        10   0% /dev
      tmpfs                405    42       363  11% /run
      tmpfs               1012     0      1012   0% /dev/shm
      tmpfs                  5     1         5   1% /run/lock
      tmpfs               1012     0      1012   0% /sys/fs/cgroup
      /dev/mmcblk0p1       129    12       117  10% /boot
      tmpfs                203     0       203   0% /run/user/1000
      I edited /usr/sbin/systemInfo/diskInfo to include the line
      DiskInfo="/dev/mmcblk0p2"
      and it is happy now. I am pretty sure it didn't work before but I don't think there were any events generated in 2.7.10 from the error so I didn't care. This was a mangoES v2 I think.
      mango@mangoES2147:/usr/sbin/systemInfo$uname -a
      Linux mangoES2147 3.8.13.30 #1 SMP PREEMPT Wed Mar 4 17:26:56 BRT 2015 armv7l GNU/Linux
        Hi Craig,
        Thanks for sharing!
        Those systemInfo files were affected by a patch in the MangoES Configuration module. I suspect that is what changed during the upgrade.
          psysak
          I just ran into a very similar issue but it was happening before the latest upgrade, I'm sorry I don't know what versions. Now the system is being bombarded by errors say
          Value is no numeric: For input string: "1.5G"
            Hi psysak,
            That's odd. Can you cat /opt/info/systemInfo.txt? What's the regex for the point generating the errors?
            The disk info section should be generated from /usr/sbin/systemInfo/diskInfo and should all be df -m commands.
              psysak
              I'll try to check tomorrow when I'm back there
