    Mbus update causes errors
    Mango feedback
    2
    5
    2.8k
    • S
      stensma
      My M-bus communication have been very stable in the past but now it has started to fail.
      This was triggered by the latest update where there was a M-bus sw update.
      I have the same setup as before but now I get following error messages in the log file:
      "FATAL 2016-08-19 11:09:11,461 (com.serotonin.m2m2.mbus.MBusDataSourceRT.doPoll:142) - too many dataBlocks found"
      And in the alarms page the message is:
      "High priority task: com.serotonin.m2m2.util.timeout.TimeoutTask@136986e was rejected because it is already running"
      • A
        apl
        I changed the behavoir of the m-bus datablock detection.
        I recommend to:
        1. make a new discovery of your m-bus.
        2. note the (new) index of the datablock you are interested in.
        3. Use the edit function to set the noted index of step 2.. - It should now work.
        Can you give me the manufacturer/medium of the meter? - maybe some specs as well?
        Arne
        • S
          stensma
          undefined0_1471762586317_Mbus.tiff
          You mean the "Datablock Index" ?
          This and the only I could find "index" are set to -1 on all my data points.
          Even so, a new way of detection should not affect the existing already defined data sources in a sw upgrade ?
          I will give it a try.
          Is the timeout alarm connected to this? it showed up at the same upgrade.
          /Per
          • S
            stensma
            I have now redefined all my data points under Mbus.
            it seams to have solved my problems.
            Data-block index was "-1 " on all data points in the earlier definition, now they show up as different index values.
            /Per
            I am lucky to only have 10 data point under Mbus....
            • S
              stensma
              Model and so...:
              Actaris CF ECHO II Qp 2.5
              0_1471819501872_CFECHO-II-15mm-50mm.pdf
              // Per
