    A little help!!
    14 Posts 2 Posters 8.2k Views 1 Watching
    • J Offline
      Jkhar
      Hi!! I've been working with Jamod and i read in other forum that modbus4J is kind of based on jamod, so i was wondering if you could instruct me in modbus4J library or if you could show me some code examples of the features of modbus4J. Thanks
        Hi. Try looking at stuff in the src_test folder. There are a number of test programs in there which should give you some ideas.
        • J Offline
          Jkhar
          Thanks thats what i was looking for, it's a great library.
            Thank you!
            • J Offline
              Jkhar
              Hi mlohbihler(again). I'm trying to use the Listener and Master test classes (for a TCP slave an master) that you mention before but when i execute both at the same time (first listener then master) i get this exeption:
              Exception in thread "main" java.lang.NoSuchMethodError: com.serotonin.io.messaging.TestableTransport.<init>(Ljava/io/InputStream;Ljava/io/OutputStream;)V
              at com.serotonin.modbus4j.ip.tcp.TcpSlave$TcpConnectionHandler.<init>(TcpSlave.java:82)
              at com.serotonin.modbus4j.ip.tcp.TcpSlave.start(TcpSlave.java:46)
              at servermodbus.Main.main(Main.java:34)
              in both classes.
              Could you advise me? What am i doing wrong?
                Make sure seroUtils.jar is in your classpath.
                • J Offline
                  Jkhar
                  Sorry it is not teh same in both in salve is:
                  Java Result: 1
                  And in Master is:
                  Exception in thread "main" java.lang.NoSuchMethodError: com.serotonin.io.messaging.StreamTransport.<init>(Ljava/io/InputStream;Ljava/io/OutputStream;)V
                  at com.serotonin.modbus4j.ip.tcp.TcpMaster.openConnection(TcpMaster.java:113)
                  at com.serotonin.modbus4j.ip.tcp.TcpMaster.init(TcpMaster.java:44)
                  at otra.Main.main(Main.java:69)
                  Java Result: 1
                  Thanks for your help. :!: :!: :!: :)
                  • J Offline
                    Jkhar
                    Yes i have it in my class path
                      Should be fine then. Other users have had the same message, and it was always due to not having seroUtils in the classpath. Maybe check that the jar file isn't corrupt.
                      • J Offline
                        Jkhar
                        I think that maybe in the TCPSlave class there is something like this
                        transport = new TestableTransport(socket.getInputStream(), socket.getOutputStream());
                        But in the TestableTransport class in the library seroUtils the class TestableTransport needs 3 parameters and the one that is missing is the thread Name or what do you think that it might be.
                        Sorry if i bother you to much but i don't know waht to do
                        • J Offline
                          Jkhar
                          Or where can i download another version or the last update of seroUtils library??
                            Hmm, it's true that things may have gotten out of sync over time. To make sure, i've uploaded a version 1.02 of modbus4j to sourceforge. Try getting those versions and see if things are better.
                            • J Offline
                              Jkhar
                              Thanks, i will download the new version and check if it works fine. thanks again. :-)
