    "BUILD FAILED" when build "MBus module" -- mbus-ds:jar:1.1.3 not found
    7 Posts 2 Posters 4.4k Views 2 Watching
    • mebiusM Offline
      mebius
      Hi supporter,
      We met this kind of error when ant-build MBus-module's build.xml. Could you please help?
      BUILD FAILED
      F:\ma-proj\ma-modules-public\MBus\build.xml:4: The following error occurred while executing this line:
      F:\ma-proj\ma-core-public\Core\module-build.xml:34: Unable to resolve artifact: Missing:
      1. com.infiniteautomation:mango:jar:2.7.10
      Try downloading the file manually from the project website.
      Then, install it using the command:
      mvn install:install-file -DgroupId=com.infiniteautomation -DartifactId=mango -Dversion=2.7.10 -Dpackaging=jar -Dfile=/path/to/file
      Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=com.infiniteautomation -DartifactId=mango -Dversion=2.7.10 -Dpackaging=jar -Dfile=/path/to/file -Durl= -DrepositoryId=[id]
      Path to dependency:
      1) com.infiniteautomation.mango:mbus-ds:jar:1.1.3
      2) com.infiniteautomation:mango:jar:2.7.10
      1 required artifact is missing.
      for artifact:
      from the specified remote repositories:
      central (http://repo1.maven.org/maven2)
        Hi mebius,
        cd /path/to/ma-core-publc
        mvn install
        Then try again. Maven manages dependecies in our projects.
        mebiusM 1 Reply Last reply Reply Quote 0
        • mebiusM Offline
          mebius @phildunlap
          @phildunlap
          Hi phildunlap,
          Command "mvn install" succeeded but ant-build for Mbus still failed due to:
          for artifact:
            Hi mebius,
            That's not the entire output of the build failure. What is it failing on now?
            • mebiusM Offline
              mebius @phildunlap
              @phildunlap
              Hi phildunlap,
              Here is the console output.
              Buildfile: F:\ma-proj\ma-modules-public\MBus\build.xml
              [mvn:dependencies] Downloading: com/infiniteautomation/mango/2.7.10/mango-2.7.10.pom from repository central at http://repo1.maven.org/maven2
              [mvn:dependencies] Unable to locate resource in repository
              [mvn:dependencies] [INFO] Unable to find resource 'com.infiniteautomation:mango:pom:2.7.10' in repository central (http://repo1.maven.org/maven2)
              [mvn:dependencies] Downloading: com/infiniteautomation/mango/2.7.10/mango-2.7.10.jar from repository central at http://repo1.maven.org/maven2
              [mvn:dependencies] [INFO] Unable to find resource 'com.infiniteautomation:mango:jar:2.7.10' in repository central (http://repo1.maven.org/maven2)
              [mvn:dependencies] An error has occurred while processing the Maven artifact tasks.
              [mvn:dependencies] Diagnosis:
              [mvn:dependencies]
              [mvn:dependencies] Unable to resolve artifact: Missing:
              [mvn:dependencies] ----------
              [mvn:dependencies] 1) com.infiniteautomation:mango:jar:2.7.10
              [mvn:dependencies]
              [mvn:dependencies] Try downloading the file manually from the project website.
              [mvn:dependencies]
              [mvn:dependencies] Then, install it using the command:
              [mvn:dependencies] mvn install:install-file -DgroupId=com.infiniteautomation -DartifactId=mango -Dversion=2.7.10 -Dpackaging=jar -Dfile=/path/to/file
              [mvn:dependencies]
              [mvn:dependencies] Alternatively, if you host your own repository you can deploy the file there:
              [mvn:dependencies] mvn deploy:deploy-file -DgroupId=com.infiniteautomation -DartifactId=mango -Dversion=2.7.10 -Dpackaging=jar -Dfile=/path/to/file -Durl= -DrepositoryId=[id]
              [mvn:dependencies]
              [mvn:dependencies] Path to dependency:
              [mvn:dependencies] 1) com.infiniteautomation.mango:mbus-ds:jar:1.1.3
              [mvn:dependencies] 2) com.infiniteautomation:mango:jar:2.7.10
              [mvn:dependencies]
              [mvn:dependencies] 1 required artifact is missing.
              [mvn:dependencies]
              [mvn:dependencies] for artifact:
              [mvn:dependencies] com.infiniteautomation.mango:mbus-ds:jar:1.1.3
              [mvn:dependencies]
              [mvn:dependencies] from the specified remote repositories:
              [mvn:dependencies] central (http://repo1.maven.org/maven2)
              [mvn:dependencies]
              [mvn:dependencies]
              [mvn:dependencies]
              BUILD FAILED
              Path to dependency:
              for artifact:
              Total time: 10 seconds
              thanks
                This looks like the mvn install of the Core didn't actually succeed.... Hmmm....
                Can you try....
                cd /path/to/ma-core-public
                mvn install
                cd Core
                mvn install
                Then try again? Can you check your user's local maven repository for the mango-2.7.10.jar file? It will be at C:\Users\Username\.m2\repository\com\infiniteautomation\mango\2.7.10\ (or maybe F:\ by the looks of your output).
                Are you sure the 'mvn install' succeeded on all build targets?
                • mebiusM Offline
                  mebius @phildunlap
                  @phildunlap
                  Hi phildunlap,
                  I use the code from zip file instead of cloning code from git, module build works fine now with the same steps.
                  Thank you very much for your kind help.
