    [SOLVED] Modbus TCP Master error
    4 Posts 2 Posters 5.1k Views 2 Watching
    • A Offline
      Aurelien
      Hello everybody,
      I want to use Modbus4J rather than Jamod. I use Modbus4J version 3.0.0.
      I'm trying to test the smallest possible example :
      package testModbus;
      import com.serotonin.modbus4j.ModbusFactory;
      import com.serotonin.modbus4j.ModbusMaster;
      import com.serotonin.modbus4j.code.DataType;
      import com.serotonin.modbus4j.ip.IpParameters;
      import com.serotonin.modbus4j.locator.BaseLocator;
      public class Main {
              IpParameters params = new IpParameters();
              params.setHost("localhost");
              params.setPort(502);
              ModbusFactory masterF = new ModbusFactory();
              ModbusMaster master = masterF.createTcpMaster(params, false);
              master.init();
              System.out.println(master.testSlaveNode(5));
              // Define the point locator.
              BaseLocator<Number> loc = BaseLocator.holdingRegister(1, 0, DataType.TWO_BYTE_INT_UNSIGNED);
              // Set the point value
              master.setValue(loc, 1800);
              // Get the point value
              System.out.println(master.getValue(loc));
      I have this error when I tryto execute the Java program :
      Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
      	at com.serotonin.modbus4j.ip.tcp.TcpMaster.<init>(TcpMaster.java:57)
      	at com.serotonin.modbus4j.ModbusFactory.createTcpMaster(ModbusFactory.java:69)
      	at testModbus.Main.main(Main.java:18)
      Caused by: java.lang.ClassNotFoundException: org.apache.commons.logging.LogFactory
      	at java.net.URLClassLoader.findClass(Unknown Source)
      	at java.lang.ClassLoader.loadClass(Unknown Source)
      	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
      	... 3 more
      With another bigger test, the error is the same.
      I don't know where is the real problem with the code, or configuration, ... ?
      Thanks you in advance for the help :-)
      Aurélien, France
        Hi Aurelien,
        That looks to me like you need a log4j.xml file somewhere on your classpath at runtime. You can just add the "-cp /path/to/log4j.xml" to the invocation of your program.
        • A Offline
          Aurelien
          Thanks ! :-D
          I have found the solution.
          It's necessary to add commons logging library.
          Download :
          http://commons.apache.org/proper/commons-logging/download_logging.cgi
            Nice! Thanks for sharing the solution!
            With your input, this post could be even better đŸ’—
