    Error creating a new MySQL database - create H2 instead
    2 Posts 2 Posters 2.5k Views 1 Watching
      mlavelle42
      I setup the overrides file with /opt/mango/ as root. See all three found below.
      ./overrides/classes/properties/env.properties
      ./templates/env.properties
      ./classes/env.properties
      I then changed the /overrides/classes/properties/env.properties file as follows:
      Commented out H2
      #Default database settings, NOTE that on windows this must be an absolute path
      #db.type=h2
      #db.url=jdbc:h2:${ma.home}/databases/mah2
      #db.location=${ma.home}/databases/mah2
      #db.username=
      #db.password=
      #For web console
      #db.web.start=false
      #db.web.port=8091
      Then uncommented MySQL
      #MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
      db.type=mysql
      db.url=jdbc:mysql://localhost/mango
      db.username=validusername
      db.password=validuserpassword
      MySQL was running
      /opt/mango/overrides/classes/properties $ /etc/init.d/mysql status
      ● mysql.service - LSB: Start and stop the mysql database server daemon
      Loaded: loaded (/etc/init.d/mysql)
      Active: active (running) since Wed 2016-04-20 15:17:12 EDT; 2 days ago
      Process: 491 ExecStart=/etc/init.d/mysql start (code=exited, status=0/SUCCESS)
      CGroup: /system.slice/mysql.service
      ├─ 596 /bin/sh /usr/bin/mysqld_safe
      └─1004 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --log-error=/var/log/mysql/error.log -...
      *But mango built an H2 database in /opt/mango/databases
      7360512 Apr 22 15:20 mah2.h2.db
      Note: the /opt/mango/classes/env.properties file is the original, and unchanged, set to create H2 by default.
      Question: what did I do wrong?
        To override the env.properties file place it in overrides/properties
