    Problem on startup only load till 40% only
    2 Posts 2 Posters 1.8k Views 2 Watching
    • K Offline
      KHAIRUL
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\sql
      Console\RELEASE-NOTES (The system cannot find the path specified)
      at java.io.FileOutputStream.open0(Native Method)
      at java.io.FileOutputStream.open(FileOutputStream.java:270)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
      at com.serotonin.m2m2.Main.writeFile(Main.java:667)
      at com.serotonin.m2m2.Main.openZipFiles(Main.java:223)
      at com.serotonin.m2m2.Main.main(Main.java:98)
      INFO 2016-04-15 22:57:24,698 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module sqlds
      WARN 2016-04-15 22:57:24,700 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-sqlds-1.6.2.zip. Is this module built for the core
      version that you are using? Module ignored.
      ds\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,704 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module ssh
      WARN 2016-04-15 22:57:24,706 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-ssh-1.1.1.zip. Is this module built for the core ve
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\ssh
      INFO 2016-04-15 22:57:24,714 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module sstGlobalScripts
      WARN 2016-04-15 22:57:24,716 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-sstGlobalScripts-1.5.1.zip. Is this module built fo
      r the core version that you are using? Module ignored.
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\sst
      GlobalScripts\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,721 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module sstGraphics
      WARN 2016-04-15 22:57:24,736 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-sstGraphics-1.1.1.zip. Is this module built for the
      Graphics\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,741 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module TCPIP
      WARN 2016-04-15 22:57:24,742 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-TCPIP-1.1.4.zip. Is this module built for the core
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\TCP
      IP\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,749 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module templateConfig
      WARN 2016-04-15 22:57:24,751 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-templateConfig-1.0.8.zip. Is this module built for
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\tem
      plateConfig\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,755 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module twilio
      WARN 2016-04-15 22:57:24,757 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-twilio-1.1.2.zip. Is this module built for the core
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\twi
      lio\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,764 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module virtualDS
      WARN 2016-04-15 22:57:24,766 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-virtualDS-1.5.1.zip. Is this module built for the c
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\vir
      tualDS\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,771 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module vmstat
      WARN 2016-04-15 22:57:24,772 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-vmstat-1.5.1.zip. Is this module built for the core
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\vms
      tat\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:24,784 (com.serotonin.m2m2.Main.openZipFiles:181) - Insta
      lling module watchlists
      WARN 2016-04-15 22:57:24,788 (com.serotonin.m2m2.Main.openZipFiles:242) - Error
      while opening zip file m2m2-watchlists-1.7.4.zip. Is this module built for the
      java.io.FileNotFoundException: C:\Program Files\Mango Automation\web\modules\wat
      chlists\RELEASE-NOTES (The system cannot find the path specified)
      INFO 2016-04-15 22:57:25,033 (com.serotonin.m2m2.Lifecycle.loadLic:464) - Check
      ing license...
      INFO 2016-04-15 22:57:25,034 (com.serotonin.m2m2.Lifecycle.loadLic:544) - Licen
      se file not found
      INFO 2016-04-15 22:57:25,106 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42)
      • Initializing H2 connection manager
        FATAL 2016-04-15 22:57:26,609 (com.serotonin.m2m2.db.DatabaseProxy.initialize:19
        • Unable to connect to database of type H2
          org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Co
          nnection; nested exception is org.h2.jdbc.JdbcSQLException: Error while creating
          file "C:/Program Files/Mango Automation/databases" [90062-181]
          at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(Dat
          aSourceUtils.java:80)
          at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:
      1. at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:68
      2.  at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:71
      3.  at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:72
      4.  at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJ
      dbcTemplate.java:39)
      dbcTemplate.java:63)
      at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:244)
      at com.serotonin.m2m2.db.DatabaseProxy.newDatabaseCheck(DatabaseProxy.ja
      va:204)
      at com.serotonin.m2m2.db.DatabaseProxy.initialize(DatabaseProxy.java:106
      at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:602)
      at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:280)
      at com.serotonin.m2m2.Main.main(Main.java:116)
      Caused by: org.h2.jdbc.JdbcSQLException: Error while creating file "C:/Program F
      at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
      at org.h2.message.DbException.get(DbException.java:179)
      at org.h2.message.DbException.get(DbException.java:155)
      at org.h2.store.fs.FilePathDisk.createDirectory(FilePathDisk.java:274)
      at org.h2.store.fs.FileUtils.createDirectory(FileUtils.java:42)
      at org.h2.store.fs.FileUtils.createDirectories(FileUtils.java:309)
      at org.h2.store.FileLock.lockFile(FileLock.java:345)
      at org.h2.store.FileLock.lock(FileLock.java:135)
      at org.h2.engine.Database.open(Database.java:631)
      at org.h2.engine.Database.openDatabase(Database.java:266)
      at org.h2.engine.Database.<init>(Database.java:260)
      at org.h2.engine.Engine.openSession(Engine.java:60)
      at org.h2.engine.Engine.openSession(Engine.java:167)
      at org.h2.engine.Engine.createSessionAndValidate(Engine.java:145)
      at org.h2.engine.Engine.createSession(Engine.java:128)
      at org.h2.engine.Engine.createSession(Engine.java:26)
      at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.jav
      a:347)
      at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:108)
      at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:92)
      at org.h2.Driver.connect(Driver.java:72)
      at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:190
      at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:353)
      at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:3
      85)
      at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.j
      ava:227)
      at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java
      :199)
      at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(D
      ataSourceUtils.java:111)
      aSourceUtils.java:77)
      ... 12 more
      ERROR 2016-04-15 22:57:26,614 (com.serotonin.m2m2.Main.main:120) - Error during
      initialization
      615)
      0)
      2)
      2)
      va:204)
      a:347)
      85)
      ava:227)
      :199)
      ... 12 more
      INFO 2016-04-15 22:57:26,617 (com.serotonin.m2m2.Lifecycle.terminate:344) - Man
      go Lifecycle terminating...
      Exception in thread "high-pool-1-thread-1" java.lang.NullPointerException
      at com.serotonin.m2m2.CoreLicenseDefinition$2.run(CoreLicenseDefinition.
      java:149)
      at com.serotonin.timer.sync.Synchronizer$TaskWrapper.run(Synchronizer.ja
      va:155)
      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.
      java:1142)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor
      .java:617)
      INFO 2016-04-15 22:57:26,670 (com.serotonin.m2m2.Lifecycle.terminate:446) - Man
      go Lifecycle terminated.
      INFO 2016-04-15 22:57:26,671 (com.serotonin.m2m2.Lifecycle.terminate:344) - Man
      C:\Program Files\Mango Automation\bin>
        Hi Khairul,
        1. Some of your modules are not the right versions for your core. Once you get it to start, you can update your modules and/or Mango from the modules page.
        2. You have what appears to be a permissions problem creating a databases directory. Perhaps you can manually create the directory so Mango only has to try and create the H2 database? Or you could run it in C:\Users\[MyUser]\
        3. I don't really enjoy reading stack traces without having at least a little thinking done on your part as to what you want me to be looking for. You are most welcome here, but i'm more likely to read something if a human took the time to say it AND provided me the machine's opinion on the subject too.
