    "Hello World" BACNet device
    7 Posts 3 Posters 7.3k Views 3 Watching
    • S Offline
      skodan
      Hi, I'm trying to get a minimum BACNet device going but it doesn't seem to respond. The code is as small as I could make it:
      LocalDevice dev = new LocalDevice(76, new DefaultTransport(new IpNetwork("192.168.2.255", 47808, "192.168.2.104", "255.255.255.0", 0, false)));
      BACnetObject obj = createAnalogValue(1);
      dev.addObject(obj);
      dev.initialize();
      When I try to "ping" it with a tool like:
      bacnet-stack-0.8.3/bin/bacwi
      nothing happens.
      I'm certain I'm doing something stupid but I can't find any example or even something similar to this in the test directory. Any help to get me started is appreciated.
      • S Offline
        ssimm
        bacnet-stack-0.8.3 is Steve Karg's C implementation of the BACNet protocol, if I'm not mistaken. It uses BACNET/IP as the transport layer and bacnet4j uses MS/TP as the transport layer. That might be why one doesn't see the other. I have both too and would also like to see them working together.
          BACnet4J supports both MSTP and IP
          • S Offline
            ssimm
            I like that answer even better.
            So, three questions (I'm using the bacnet4j library v3.2.4)
            Here is my initialization of a localObject:
            IpNetwork network = new IpNetworkBuilder().broadcastIp(broadcastIPString).localBindAddress(ipAddressString).port(port).subnetMask(subnetMaskString).build();
            DefaultTransport transport = new DefaultTransport(network);
            LocalDevice localDevice = new LocalDevice(deviceID, transport);
            1.Am I using MS/TP or BACNet/IP?
            2.Given an artibrary localDevice, how you do tell which of these two it is using?
            3.Whichever I'm using above, how do I initalize my localObject with the other protocol? (e.g. if the above is MS/TP, how do I change it to use BACNet/IP)?
            Thanks, much obliged.
              1. IP, hence the "IpNetwork" and "IpNetworkBuilder" instead of MstpNetwork
              2. if( localDevice.getNetwork() instanceof IpNetwork ) return "It's an IP network!";
              3. Create an MstpNetwork and pass it to new DefaultTransport( mstpNetwork );
              • S Offline
                ssimm
                Ah, so simple. Facepalm moment for me.
                Thanks for the tip!
                • S Offline
                  skodan
                  Thank you, will try this. Have moved forward with my project (simulation of offices/SCADA/ICS systems) but parked the BACnet connection, will work it into the backlog.
