    Not being able to configure CORS
    3 Posts 3 Posters 3.0k Views 3 Watching
    • J Offline
      jmpy
      Hi, i'm trying to read mango data from python using the rest api. I read all I could find in the forum, but still the cors looks like it's not working. I tried adding as many headers to "Access-Control-Allow-Headers", and send as little headers as possible from my python code. I tried with GET and POST. Please. Any help will be appreciated.
      the debugging console in python (you can see that mangoApiHeaders is loading just fine):
      send: 'GET /rest/v1/login/admin?password=admin HTTP/1.1\r\nHost: 127.0.0.1:8087\r\nAccess-Control-Allow-Origin: *\r\nX-Requested-With: XMLHttpRequest\r\nAccept-Encoding: gzip, deflate\r\n\r\n'
      reply: 'HTTP/1.1 406 Not Acceptable\r\n'
      DEBUG:requests.packages.urllib3.connectionpool:"GET /rest/v1/login/admin?password=admin HTTP/1.1" 406 0
      header: Date: Wed, 10 Feb 2016 16:33:05 GMT
      header: Access-Control-Max-Age: 3600
      header: Access-Control-Allow-Headers: X-Requested-With,Content-Type,Accept,Origin, X-XSRF-TOKEN, Set-Cookie, Expires, Connection, User-Agent, Accept-Encoding, Host , LOGOUT, PASSWORD
      header: Access-Control-Allow-Origin: *
      header: Access-Control-Allow-Credentials: true
      header: Access-Control-Allow-Methods: PUT, POST, GET, OPTIONS, DELETE
      header: Set-Cookie: MANGO8087=1ekrvt78inh341m02r56n06vu8;Path=/
      header: Expires: Thu, 01 Jan 1970 00:00:00 GMT
      header: messages:
      header: errors: Invalid login
      header: Content-Length: 0
      header: Server: Jetty(9.2.12.v20150709)
      send: 'POST /rest/v1/login/admin?password=admin HTTP/1.1\r\nHost: 127.0.0.1:8087\r\nX-Requested-With: XMLHttpRequest\r\nAccess-Control-Allow-Origin: *\r\nCookie: MANGO8087=1ekrvt78inh341m02r56n06vu8\r\nAccept-Encoding: gzip, deflate\r\nContent-Length: 0\r\n\r\n'
      DEBUG:requests.packages.urllib3.connectionpool:"POST /rest/v1/login/admin?password=admin HTTP/1.1" 406 0
      My files:
      overrides/web/override-web.xml
      <?xml version="1.0" encoding="UTF-8"?>
          Copyright (C) 2015 Infinite Automation Systems Inc. All rights reserved.
          @author Terry Packer
      <web-app xmlns="http://java.sun.com/xml/ns/javaee"
          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
          xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"
          version="2.5">
          Filter definitions.
        <filter>
          <description>Filter to allow custom headers to be added to the REST API responses</description>
          <filter-name>customHeadersFilter</filter-name>
          <filter-class>com.serotonin.m2m2.web.mvc.rest.v1.CustomHeadersFilter</filter-class>
        </filter>
        <filter-mapping>
         <url-pattern>/rest/*</url-pattern>
        </filter-mapping>
      </web-app>
      /web/modules/mangoApi/classes/mangoApiHeaders.properties
      Access-Control-Allow-Origin=*
      Access-Control-Allow-Methods=PUT, POST, GET, OPTIONS, DELETE
      Access-Control-Allow-Credentials=true
      Access-Control-Max-Age=3600
      Access-Control-Allow-Headers=X-Requested-With,Content-Type,Accept,Origin, X-XSRF-TOKEN, Set-Cookie, Expires, Connection, User-Agent, Accept-Encoding, Host , LOGOUT, PASSWORD
      Re: REST API access custom software
        Hi jmpy,
        I believe the way that will have long term support is the GET with the password as a header field (probably why you get that 406). That you got a 'Set-Cookie' back would imply the login worked (Edit: I was corrected, you have an anonymous session before you have a user session, but you should still use the cookie given when login is successful). You will need to return the value of that cookie in all subsequent requests under the header X-XSRF-TOKEN=1ekrvt78inh341m02r56n06vu8
        • terrypackerT Offline
          terrypacker
          Make sure you set the 'Accepts' header to application/json. It's possible that Mango can't figure out what type of response you want.
