    MA-START ON WINDOWS hmmm..?
    1 Posts 1 Posters 2.2k Views 1 Watching
    • xbastekX Offline
      xbastek
      2.6.0-beta build 327
      D:\bin>ma-start
      Using D:\ as MA_HOME
      D:\overrides\classes;D:\classes;D:\overrides\properties;D:\overrides\lib*;D:\lib*
      Using Java at C:\Program Files\Java\jdk1.7.0_71\bin\java
      Usage: java [-options] class [args...]
      (to execute a class)
      or java [-options] -jar jarfile [args...]
      (to execute a jar file)
      where options include:
      -d32 use a 32-bit data model if available
      -d64 use a 64-bit data model if available
      -server to select the "server" VM
      -hotspot is a synonym for the "server" VM [deprecated]
      The default VM is server.
      -cp <class search path of directories and zip/jar files>
      -classpath <class search path of directories and zip/jar files>
      A ; separated list of directories, JAR archives,
      and ZIP archives to search for class files.
      -D<name>=<value>
      set a system property
      -verbose:[class|gc|jni]
      enable verbose output
      -version print product version and exit
      -version:<value>
      require the specified version to run
      -showversion print product version and continue
      -jre-restrict-search | -no-jre-restrict-search
      include/exclude user private JREs in the version search
      -? -help print this help message
      -X print help on non-standard options
      -ea[:<packagename>...|:<classname>]
      -enableassertions[:<packagename>...|:<classname>]
      enable assertions with specified granularity
      -da[:<packagename>...|:<classname>]
      -disableassertions[:<packagename>...|:<classname>]
      disable assertions with specified granularity
      -esa | -enablesystemassertions
      enable system assertions
      -dsa | -disablesystemassertions
      disable system assertions
      -agentlib:<libname>[=<options>]
      load native agent library <libname>, e.g. -agentlib:hprof
      see also, -agentlib:jdwp=help and -agentlib:hprof=help
      -agentpath:<pathname>[=<options>]
      load native agent library by full pathname
      -javaagent:<jarpath>[=<options>]
      load Java programming language agent, see java.lang.instrument
      -splash:<imagepath>
      show splash screen with specified image
      See http://www.oracle.com/technetwork/java/javase/documentation/index.html for more details.
      D:\bin>
