    Ascii file source, read binary value in file
    6 Posts 4 Posters 2.7k Views 2 Watching
    • jeremyhJ Offline
      jeremyh
      I would like to read a file (on a linux filesystem) using the ASCII file data source. The file simply contains either a 0 or a 1 depending on a condition. No other characters or data are present in the file.
      I can't figure out how to get the ASCII file data source to read this. It is looking at the correct file but I am not sure about what I should put in the additional settings for point identifier, value index etc. Any hints?
      Cheers
      Jeremy
      • jeremyhJ Offline
        jeremyh
        Oops, I meant to post this in 'User help', although this is somewhat hardware related as I am trying to access the GPIO pins on a Raspberry Pi (if successful I will post the steps here/on the wiki for others).
        • jeremyhJ Offline
          jeremyh
          Well, after playing around with this - I (mostly) have a solution using python, but it's pretty ugly and inefficient.
          I would really like it if I could read the bit directly into mango as above.
          Again, the file just contains a single bit; a zero or a one, which changes as the input changes.
          @phildunlap, perhaps you have some idea about how to do this?
          • AldoRamosA Offline
            AldoRamos
            Also looking to implement similar data points for GPIO.
            I have resorted to a "grep" and using the filename as a point identifier, which is ugly in itself, but the real problem is getting the binary data ("1" or "0") to be properly read into the regex. What I seem to be getting is a 1 if the regex matches, not the actual value of the regex pattern. Are there any examples for regex patters for binary data such as the GPIO values?
            Thanks in advance.
            Aldo
              Puckfist
              This post is deleted!
                Hey guys, sorry I never saw this... I took a bit of a hiatus.
                Yes you can do this with the ASCII file data source. Simply point the datasource at the file, configure a data point as follows:
                Point Identifier:
                Point Identifier Index: 2
                Value Index: 1
                Value Regex: (0|1)()
                So the trick here is to leave the point identifier totally empty and then capture an empty group at some point in our regex.
