    MA fresh install works with Derby but not with mysql
    5 Posts 3 Posters 4.4k Views 1 Watching
      PCM
      $ sudo start mango
      mango start/running, process 29497
      $ cat /opt/mango/logs/ma.err
      Exception in thread "pool-1-thread-1" java.lang.NullPointerException
      at com.serotonin.m2m2.CoreLicenseDefinition$2.run(CoreLicenseDefinition.java:137)
      at com.serotonin.timer.sync.Synchronizer$TaskWrapper.run(Synchronizer.java:155)
      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
      at java.lang.Thread.run(Thread.java:679)
      $ **sudo status mango **
      mango stop/waiting
      I only tried Derby as a test. I need it working with mysql.
      Mango did create 36 tables under mysql, so it does have the permissions from the GRANT ALL command:
      mysql> use mango
      Reading table information for completion of table and column names
      You can turn off this feature to get a quicker startup with -A
      Database changed
      mysql> **show tables;
      | Tables_in_mango               |
      | compoundEventDetectors        |
      | dataPointUsers                |
      | dataPoints                    |
      | dataSourceUsers               |
      | dataSources                   |
      | eventHandlers                 |
      | events                        |
      | graphicalViewUsers            |
      | graphicalViews                |
      | mailingListInactive           |
      | mailingListMembers            |
      | mailingLists                  |
      | maintenanceEvents             |
      | mangoViewUsers                |
      | mangoViews                    |
      | pointEventDetectors           |
      | pointHierarchy                |
      | pointLinks                    |
      | pointValueAnnotations         |
      | pointValues                   |
      | publishers                    |
      | reportInstanceData            |
      | reportInstanceDataAnnotations |
      | reportInstanceEvents          |
      | reportInstancePoints          |
      | reportInstanceUserComments    |
      | reportInstances               |
      | reports                       |
      | scheduledEvents               |
      | systemSettings                |
      | userComments                  |
      | userEvents                    |
      | users                         |
      | watchListPoints               |
      | watchListUsers                |
      | watchLists                    |
      36 rows in set (0.00 sec)
      mysql>
        I was able to duplicate this error. I normally create the mango database and user through webmin or phpmyadmin and never had a problem.
        This time I created the user on the mysql terminal with these commands:
        mysql -u root -p
        mysql> CREATE DATABASE mangodb;
        GRANT ALL ON mangodb.* TO mangodb@localhost IDENTIFIED BY ' password';
        When I tried to start Mango I got the same error as you.
        I then created a second database user and permissions through webmin and it worked as it always does. In webmin I grant all permissions to the user and the database for the user.
        There may be a correct mysql command to use for this but I'm not experience with mysql so I'll leave that up to someone else to figure out.
        Joel.
          PCM
          Hi Joel,
          Thanks very much for recreating the issue. At the moment I only have ssh access, so I can't run phpmyadmin.
          Did you also enter the CREATE command as shown on line 14?
          anyuser$ mysql --user=root -pMyrootSQLpasswd # Log into MySQL monitor
          Welcome to the MySQL monitor.
          mysql> create schema mango; # create a schema/database for Mango
          mysql> show schemas; # show schemas for this MySQL instance
          | Database           |
          | information_schema |
          | mango              |
          | mysql              |
          | performance_schema |
          | test               |
          mysql> CREATE USER 'mangoUser'@'localhost' IDENTIFIED BY 'passwdformango';# Create a username & password for Mango:
          Query OK, 0 rows affected (0.00 sec)
          mysql> select user from mysql.user; # view user names
          | user             |
          | root             |
          | root             |
          | debian-sys-maint |
          | mangoUser        |
          | root             |
          | root             |
          mysql> GRANT ALL PRIVILEGES ON mango.* to 'mangoUser'@'localhost' WITH GRANT OPTION;
          Query OK, 0 rows affected (0.01 sec)
          mysql> exit
          Bye
          • C Offline
            CLee
            Hi
            I am having the same issue where mango seems to run on Derby but not mysql. We have a similar configuration on another machine that works, and comparing apples to apples, it all looks the same. This is the error I get:
            Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/comms/httpclient/Credentials at com.serotonin.m2m2.Main.main(Main.java:63)
            any clues?
            the db user created to access mysql has the GRANT ALL privileges so no access restrictions.
            Thanks!
