    Configuring MS SQL as a Data Source
    6 Posts 2 Posters 5.5k Views 1 Watching
    • J Offline
      jmd
      Hi all-
      I'm attempting to use an MS SQL database as a data source in Mango M2M2. Normally to connect to SQL using a database browser I only need the servername/IP, userid and password. Mango has a couple of other properties that I'm not certain as to what needs to be entered or if additional setup is required to use SQL as a data source.
      For the driver class name, I'm using the standard com.microsoft.jdbc.sqlserver.SQLServerDriver. For the connection string I have Server=10.165.3.192;Database=ExternalLog;User Id=dcstats;Password=xxxxxx;
      When I start the data source, I get this error: 10:35:30: 'VISU': java.lang.ClassNotFoundException: com.microsoft.jdbc.sqlserver.SQLServerDriver
      What does the classnotfound exception mean? Am I missing something in the java setup? Thanks,
      Jordan
        Your classname should be com.microsoft.sqlserver.jdbc.SQLServerDriver. (Reverse jdbc and sqlserver.)
        • J Offline
          jmd
          Thanks Matt! That allowed the software to get past the driver class loading. It now generates an error for the next line, connection string.
          10:59:46: 'VISU': java.sql.SQLException: No suitable driver found for Server=10.165.3.192;Database=ExternalLog;User Id=dcstats;Password=xxxxxx;
          I also tried the trusted connection string example, Server=10.165.3.192;Database=ExternalLog;Trusted_Connection=True; and it generated a similar error.
          11:07:32: 'VISU': java.sql.SQLException: No suitable driver found for Server=10.165.3.192;Database=ExternalLog;Trusted_Connection=True;
          I got the connection string from this [url=http://www.connectionstrings.com/sql-server-2008]SQL connection string example page.
          Is there a different connection string I should be using? Thanks for your help,
          Jordan
            That's not a JDBC connection string. Try here instead: http://msdn.microsoft.com/en-us/library/ms378956.aspx
            • J Offline
              jmd
              The information in your link appears to have allowed me to connect with a slight change. I had to change integratedSecurity to false, when it was true I got the error com.microsoft.sqlserver.jdbc.SQLServerException: This driver is not configured for integrated authentication.
              For others out there who may be attempting to connect to a MS SQL (in this case 2008), here are the settings that worked for me.
              Driver class name: com.microsoft.sqlserver.jdbc.SQLServerDriver
              Connection string: jdbc:sqlserver://10.165.3.192;database=ExternalLog;integratedSecurity=false;
              Username: database login UID
              Password: database login PW
              Of course, you'll have to customize the connection string to your database server name/IP and database name.
              Thanks Matt!
