    Problem with Read Property Request
    18 Posts 2 Posters 12.4k Views 1 Watching
    • D Offline
      decora
      Hi, i have a problem with ReadPropertyRequest. When i run my Java program, eclipse return an exception, precisely:
      Exception in thread "main" java.lang.NullPointerException
      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:216)
      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:432)
      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:422)
      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:415)
      	at Prova_B4J.main(Prova_B4J.java:143)
      My program is this:
      public class Prova_B4J {
      	private Prova_B4J(){}
      	public static void main(String[] args) throws IOException, InterruptedException, BACnetException, BACnetServiceException{
      		LocalDevice localDevice = new LocalDevice(1969,"172.16.4.14", "172.16.4.40");
      		localDevice.setPort(0xBAC0);
      		localDevice.getConfiguration().setProperty(PropertyIdentifier.segmentationSupported,Segmentation.noSegmentation);
      		RemoteDevice remoteDevice = new RemoteDevice(0, new Address(new byte[] { (byte) 172, (byte) 16, 4, (byte) 14 },0xBAC0 ), null);
      		localDevice.addRemoteDevice(remoteDevice);
      			localDevice.getEventHandler().addListener(new DeviceEventListener(){
      	            public void listenerException(Throwable e) {
      	                System.out.println("DiscoveryTest listenerException");
      	                e.printStackTrace();
      	            public void iAmReceived(RemoteDevice d) {
      	                System.out.println("DiscoveryTest iAmReceived");
      	                synchronized (this) {
      	                    this.notifyAll();
      	            public boolean allowPropertyWrite(BACnetObject obj, PropertyValue pv) {
      	                System.out.println("DiscoveryTest allowPropertyWrite");
      	                return true;
      	            public void propertyWritten(BACnetObject obj, PropertyValue pv) {
      	                System.out.println("DiscoveryTest propertyWritten");
      	            public void iHaveReceived(RemoteDevice d, RemoteObject o) {
      	                System.out.println("DiscoveryTest iHaveReceived");
      	            public void covNotificationReceived(UnsignedInteger subscriberProcessIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier monitoredObjectIdentifier, UnsignedInteger timeRemaining, SequenceOf<PropertyValue> listOfValues) {
      	                System.out.println("DiscoveryTest covNotificationReceived");
      	            public void eventNotificationReceived(UnsignedInteger processIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier eventObjectIdentifier, TimeStamp timeStamp, UnsignedInteger notificationClass, UnsignedInteger priority, EventType eventType, CharacterString messageText, NotifyType notifyType, Boolean ackRequired, EventState fromState, EventState toState, NotificationParameters eventValues) {
      	                System.out.println("DiscoveryTest eventNotificationReceived");
      	            public void textMessageReceived(RemoteDevice textMessageSourceDevice, Choice messageClass, MessagePriority messagePriority, CharacterString message) {
      	                System.out.println("DiscoveryTest textMessageReceived");
      	            public void privateTransferReceived(UnsignedInteger vendorId, UnsignedInteger serviceNumber, Encodable serviceParameters) {
      	                System.out.println("DiscoveryTest privateTransferReceived");
      				@Override
      				public void eventNotificationReceived(UnsignedInteger arg0,
      						RemoteDevice arg1, ObjectIdentifier arg2,
      						TimeStamp arg3, UnsignedInteger arg4,
      						UnsignedInteger arg5, EventType arg6,
      						CharacterString arg7, NotifyType arg8,
      						com.serotonin.bacnet4j.type.primitive.Boolean arg9,
      						EventState arg10, EventState arg11,
      						NotificationParameters arg12) {
      					// TODO Auto-generated method stub
      				@Override
      				public void reinitializeDevice(ReinitializedStateOfDevice arg0) {
      				@Override
      				public void synchronizeTime(DateTime arg0, boolean arg1) {
      	        localDevice.initialize();
      	        System.out.println("Sono pronto...");
      	        ReadPropertyRequest RPR= new ReadPropertyRequest(new ObjectIdentifier(ObjectType.analogOutput,11),new PropertyIdentifier(85));
      	        localDevice.send(remoteDevice,RPR);
      What is the problem?
      Thanks in advance!
        Did you initialize the local device?
        • D Offline
          decora
          Yes, I did...look at row 82...i used localDevice.initialize();
          PS: About the device that should receive the ReadPropertyRequest, I have simulated it with VTS
            The line numbers in the stack trace aren't lining up with my code. Are you using the latest version?
            • D Offline
              decora
              Yes, i'm using bacnet4j 1.2 downloaded form sourceforge project
                For fun, try this one...
                Attachment: download link
                • D Offline
                  decora
                  I tried using your library, and indeed it is different from mine, since I also had to add the commons-lang3.3.1.jar at the project to make it work.
                  Despite this, However, the problem is not solved :-(
                    Ok, but can you post the stack trace? I assume the line numbers are different now.
                    • D Offline
                      decora
                      Yes, the line numbers are different.
                      This is the stack trace:
                      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:226)
                      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:480)
                      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:470)
                      	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:463)
                        Your remote device has a segmentationSupported value of null. Normally you wouldn't instantiate your own RemoteDevice objects, BTW. An IAm (resulting from a WhoIs broadcast) is the typical means of instantiation. A "manual" way to get remote devices is to use the LocalDevice.findRemoteDevice method.
                        • D Offline
                          decora
                          I tried your solutions, but there are other problems.
                          If I use:
                          remoteDevice=localDevice.findRemoteDevice( new Address(new byte[] { (byte) 192, (byte) 168, (byte) 1, (byte) 112 },0xBAC0 ), null, 1);
                          eclipse return this exception:
                          Exception in thread "main" com.serotonin.bacnet4j.exception.BACnetException: java.lang.NullPointerException
                          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendImpl(IpMessageControl.java:377)
                          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:302)
                          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:248)
                          	at com.serotonin.bacnet4j.LocalDevice.findRemoteDevice(LocalDevice.java:1047)
                          	at Prova_B4J_2.main(Prova_B4J_2.java:57)
                          Caused by: java.lang.NullPointerException
                          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendImpl(IpMessageControl.java:374)
                          	... 6 more
                          If I use:
                          localDevice.sendBroadcast(0xBAC0,new WhoIsRequest(null,null));
                          eclipse return:
                          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendBroadcast(IpMessageControl.java:359)
                          	at com.serotonin.bacnet4j.LocalDevice.sendBroadcast(LocalDevice.java:520)
                          	at Prova_B4J_2.main(Prova_B4J_2.java:59)
                          	... 3 more
                            Did you initialize the local device before sending those requests?
                            • D Offline
                              decora
                              Perfect!! Thnak you very, but very very very much for the help!
                              I have only another questions...If I send an I-am message from VTS to instantiate the remote device in my java program, I have no problem ... but if I send it from another java program (always based on bacnet4j), eclipse returns this exception when I send the ReadPropertyRequest:
                              Exception in thread "main" com.serotonin.bacnet4j.exception.ErrorAPDUException: ErrorAPDU(choice=5, errorClass=Object, errorCode=Unknown object)
                              	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:489)
                              	at Prova_B4J_2.main(Prova_B4J_2.java:106)
                                Your BACnet4J device does not have the object you are looking for. You need to create a BACnet object with the correct properties, and then add it to the local device.
                                • D Offline
                                  decora
                                  Thank you mlohbihler! You have been my salvation!
                                    Glad to help. Buy a license. :)
                                    • D Offline
                                      decora
                                      :wink:
