    Problem with Read Property Request
    18 Posts 2 Posters 12.1k Views 1 Watching
    • D Offline
      decora
      I tried using your library, and indeed it is different from mine, since I also had to add the commons-lang3.3.1.jar at the project to make it work.
      Despite this, However, the problem is not solved :-(
        Ok, but can you post the stack trace? I assume the line numbers are different now.
        • D Offline
          decora
          Yes, the line numbers are different.
          This is the stack trace:
          Exception in thread "main" java.lang.NullPointerException
          	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:226)
          	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:480)
          	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:470)
          	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:463)
          	at Prova_B4J.main(Prova_B4J.java:143)
            Your remote device has a segmentationSupported value of null. Normally you wouldn't instantiate your own RemoteDevice objects, BTW. An IAm (resulting from a WhoIs broadcast) is the typical means of instantiation. A "manual" way to get remote devices is to use the LocalDevice.findRemoteDevice method.
            • D Offline
              decora
              I tried your solutions, but there are other problems.
              If I use:
              remoteDevice=localDevice.findRemoteDevice( new Address(new byte[] { (byte) 192, (byte) 168, (byte) 1, (byte) 112 },0xBAC0 ), null, 1);
              eclipse return this exception:
              Exception in thread "main" com.serotonin.bacnet4j.exception.BACnetException: java.lang.NullPointerException
              	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendImpl(IpMessageControl.java:377)
              	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:302)
              	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:248)
              	at com.serotonin.bacnet4j.LocalDevice.findRemoteDevice(LocalDevice.java:1047)
              	at Prova_B4J_2.main(Prova_B4J_2.java:57)
              Caused by: java.lang.NullPointerException
              	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendImpl(IpMessageControl.java:374)
              	... 6 more
              If I use:
              localDevice.sendBroadcast(0xBAC0,new WhoIsRequest(null,null));
              eclipse return:
              	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendBroadcast(IpMessageControl.java:359)
              	at com.serotonin.bacnet4j.LocalDevice.sendBroadcast(LocalDevice.java:520)
              	at Prova_B4J_2.main(Prova_B4J_2.java:59)
              	... 3 more
                Did you initialize the local device before sending those requests?
                • D Offline
                  decora
                  Perfect!! Thnak you very, but very very very much for the help!
                  I have only another questions...If I send an I-am message from VTS to instantiate the remote device in my java program, I have no problem ... but if I send it from another java program (always based on bacnet4j), eclipse returns this exception when I send the ReadPropertyRequest:
                  Exception in thread "main" com.serotonin.bacnet4j.exception.ErrorAPDUException: ErrorAPDU(choice=5, errorClass=Object, errorCode=Unknown object)
                  	at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:489)
                  	at Prova_B4J_2.main(Prova_B4J_2.java:106)
                    Your BACnet4J device does not have the object you are looking for. You need to create a BACnet object with the correct properties, and then add it to the local device.
                    • D Offline
                      decora
                      Thank you mlohbihler! You have been my salvation!
                        Glad to help. Buy a license. :)
                        • D Offline
                          decora
                          :wink:
