    MSTP WhoIs
    4 Posts 2 Posters 4.3k Views 1 Watching
    • K Offline
      kaltalen
      I'm trying to detect MSTP bacnet devices connected to a rs485-usb adapter and I'm having a problem reliably getting IAm responses.
      I get a response about once every five to ten WhoIs requests,
      This increases to about once every two to three tries if I change the MAC address between each request.
      Other than that I cannot find any patteren in the responses.
      Once I get a response(and save its details) i can reliably send requests to that device as much and as often as i want.
      This, combined with tests I've done with other software, leads me to believe its not the hardware I'm using.
      Originally I assumed it was my code, but once simplified as much as I could I still got the same problem.
      Is this a problem others have encountered? Is this a problem with the library? or am I using it wrong?
      Here is my simplified code:
      public static void main(String[] args) throws Exception
      	System.out.println("Loading Params");
      	SerialParameters params = new SerialParameters();
          params.setCommPortId("COM3");
          params.setBaudRate(9600);
          params.setDataBits(8);
          params.setStopBits(1);
          params.setParity(0);
          System.out.println("Creating Device");
          localDevice = new LocalDevice(1234, new Transport(new MstpNetwork(new MasterNode(params,(byte) 0x01,1))));
          try
          	System.out.println("Initilising");
              localDevice.initialize();
              localDevice.getEventHandler().addListener(new Listener());
              localDevice.sendGlobalBroadcast(new WhoIsRequest());
              System.out.println("Listening");
              Thread.sleep(20000);
              System.out.println("Done");
          finally
          	localDevice.terminate();
      static class Listener extends DeviceEventAdapter
          @Override
          public void iAmReceived(RemoteDevice d)
          	System.out.println("IAm received from " + d);
      Thanks for any help you can give,
      KT
        Can you try putting in a pause after initializing the local device, using "Thread.sleep(###)"? There may be a delay while the device waits to join the network, during which your requests might be timing out. Start with something like 10 seconds to see if this works, and then reduce the time as much as you can.
        • K Offline
          kaltalen
          That didn't fix it, I even went up to 30 seconds, same problem. the original program I had initialized them on startup then the user manually triggered the whoIs so there was usually a substantial delay between initialisation and broadcast anyway. I also tried this:
              try
                  Thread.sleep(10000);
                  for(int i=1; i<=20;i++)
                      System.out.println("Broadcast "+i);
              finally
          And got the following:
          Loading Params
          Creating Device
          Initilising
          Broadcast 1
          Broadcast 2
          Broadcast 3
          Broadcast 4
          Broadcast 5
          Broadcast 6
          Broadcast 7
          Broadcast 8
          Broadcast 9
          Broadcast 10
          Broadcast 11
          Broadcast 12
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=[7]], linkServiceAddress=null)
          Broadcast 13
          Broadcast 14
          Broadcast 15
          Broadcast 16
          Broadcast 17
          Broadcast 18
          Broadcast 19
          Broadcast 20
          Done
          I then did the same, but changed the mac address about 5 seconds before each broadcast and got the following:
          Loading Params
          Creating Device
          Initilising
          Broadcast 1
          Broadcast 2
          Broadcast 3
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=[9]], linkServiceAddress=null)
          Broadcast 4
          Broadcast 5
          Broadcast 6
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=[15]], linkServiceAddress=null)
          Broadcast 7
          Broadcast 8
          Broadcast 9
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=[11]], linkServiceAddress=null)
          Broadcast 10
          Broadcast 11
          Broadcast 12
          Broadcast 13
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=[f]], linkServiceAddress=null)
          Broadcast 14
          Broadcast 15
          Broadcast 16
          Broadcast 17
          Broadcast 18
          Broadcast 19
          IAm received from RemoteDevice(instanceNumber=9999, address=Address [networkNumber=0, macAddress=**], linkServiceAddress=null)
          Broadcast 20
          Done
          • K Offline
            kaltalen
            Any other Suggestions as to what it might be?
