    Configuring Java Location Within Mango
    10 Posts 3 Posters 8.9k Views 1 Watching
    • U Offline
      urglik
      hi,
      newbius here. i'm excited about mango. new to scada/hmi.
      it seems like something i can to learn to make a computer interface
      to control my kiln. i'm a home hobbyist with some computer knowledge.
      i installed java sdk 7 to c:\program files\java\jdk and c:\program files\java\jre
      as the installer had two parts. it came from oracle at
      http://download.oracle.com/otn-pub/java/jdk/7u75-b13/jdk-7u75-windows-i586.exe?AuthParam=1424645324_69c58c0729181b3065b797c95fe61365
      when i start ma-start.bat the error is the location of the missing server file jvm.dll.
      mango is looking for it at c:\program files\java\jre\bin\server
      the install of java places it at c:\program files\java\jdk\jre\bin\server
      where within mango do i change this configuration?
      i checked ma-start.bat but found nothing definitive.
      is this involved?
      set EXECJAVA=java
      if "%JAVA_HOME%" == "" goto gotJava
      set EXECJAVA=%JAVA_HOME%\bin\java
      if i reinstall java entirely to c:\program files\java
      and restart i get this error
      Using Java at java
      Error: missing server' JVM at C:\Program Files\Java\bin\server\jvm.dll'.
      Please install or use the JRE or JDK that contains these missing
      now it's looking in a different location.
      i'm confused.
      adding an environment variable for java_home within windows 7 does not help.
      thank you,
      urg
        It's always great to hear about the variety of uses for Mango so tanks for posting.
        You may have already seen this but here is a link to tips on windows installations: http://infiniteautomation.com/wiki/doku.php?id=installation:windows
        I would double check your JAVA_HOME environmental properties and make sure it's set the same as in the video.
        If that doesn't work we can do a short one-on-one support session to get it figured out.
        • U Offline
          urglik
          thank you for the reply.
          the issue i've been having seems an odd one so i tried an install
          on an xp virtual machine according to the video.
          it works fine.
          i only installed the jdk and to the default location.
          i cut and pasted the environment variables.
          i went and did the same thing on my win 7 machine again and had another error.
          don't care why and don't want to know.
          thank you very much for your assistance and concern.
          mango can do a variety of things.
          i wish to be able to control the kiln temperature with set points over periods of time
          heating and cooling and be able to hold temps.
          is there any advice you can give me on how to approach learning how to do this with mango?
          • jeremyhJ Offline
            jeremyh
            Hey urglik,
            Just thought I would let you know, Mango can run on a Raspberry Pi, too, which is about USD$35. There is nothing particularly complicated about the installation (as long as you are a little bit familiar with Linux). It will not be incredibly fast, but would be more than enough for your purposes.
            This way, you could have a low-power, standalone appliance that runs your kiln, rather than running a PC 24/7.
            You can probably get good results just using bang-bang control (like a simple thermostat) implemented in Mango using point event detectors, but there is also a PID control module that you would be able to use to very accurately set temps.
            If you can describe exactly how you want your kiln to function then I'm sure we can help you figure it out.
            • U Offline
              urglik
              raspberry pi does sound interesting as do similar products on the market.
              i purchased a rs485 to usb module and planned on using a dell inspiron mini i have.
              the raspberry pi sounds like an inexpensive way to have a wifi scada-hmi with mango
              and my controller. that's cool.
              anyways, regarding what capabilities i would like to have, and you're generous offer to
              assist me in getting there, here is an example of a basic firing schedule for fusing glass.
              http://www.fusedglass.org/downloads/schedules/full_fuse_2_layer_schedule.pdf
              would it be appropriate to move the discussion to another part of the forum?
              thanks eh...
              • jeremyhJ Offline
                jeremyh
                Hi urglik
                It would probably be better to start a new thread, yes!
                After reviewing the firing schedule document it is quite a bit more complex than what I was thinking - you need to control not just temperate setpoints, the timing sequence, as well as controlling temperature rate of change!
                This isn't something that I have any idea how to do (particularly controlling rate of change) - I have only started to scratch the surface of Mango's control capabilities myself.
                I'm sure Joel or someone will be able to give you a point in the right direction though. Infinite Automation actually has a product called Brewer's Dashboard which does exactly that sort of thing.
                • U Offline
                  urglik
                  thank you for your interest.
                  while poking around for the best products to use i found solo controllers
                  which offer a free scada program which will work for now.
                  being geekish i would prefer to build my own scada.
                  i can take some time learning mango.
                  thanks for pointing me in the right direction.
                  • jeremyhJ Offline
                    jeremyh
                    Hey urglik,
                    I'm interested in this free SCADA software for the Solo controller, but couldn't find info about it online - do you have a link for it?
                    Other than the software, the controller looks very similar to any basic + cheap PID temperature controller eg:
                    http://www.dx.com/p/xmt7100-1-3-screen-pid-intelligent-temperature-controller-black-192851#.VPZjzLOUfiE
                    These will take a measurement (Pv) , compare it to a setpoint (Sv) and then turn the output on/off to achieve the desired setpoint, using a PID process algorithm.
                    They are very simple to set up.
                    I even installed one in my coffee machine:
                    The difficulty in your application will come not from controlling the Sv, but from controlling the rate of change of temperature, I think.
                    • U Offline
                      urglik
                      hi jeremyh,
                      i believe that the inexpensive pid controllers on ebay, etc. do not
                      have ramp/soak capability.
                      the cheapest i could find on ebay was 75.00 and the quality i could not verify.
                      omega has them for 85 and up. (good products)
                      i chose solo, 90 and up, because of the software which you can get from this link.
                      http://ftp.automationdirect.com/pub/slsoft.zip
                      i think it's reasonable to assume this software will work other controllers.
