    How to anyone connect watchport/h host sensor via mango
    User help
    2
    4
    1.7k
    • E
      edmond
      Hi.
      I?have a watchport/H host (digi .com) sensor .for temperature and humidity test.
      the com port is com12.
      what have I try:
      have a script and test it can received the data during 20minutes.
      what I?expect: How can it run always.
      Below is use "device Monitoring studio" to view the data .
      00000001 12.09.2014 17:30:06.476 PnP Event: Connect DOWN 0x00000000 5c 00 3f 00 3f 00 5c 00 45 00 64 00 67 00 65 00 53 00 65 00 … .?.?..E.d.g.e.S.e.…
      00000002 12.09.2014 17:31:17.237 +70.761 IRP_MJ_WRITE DOWN 0x00000000 54 T
      00000004 12.09.2014 17:31:18.209 +0.969 IRP_MJ_WRITE DOWN 0x00000000 0d .
      00000007 12.09.2014 17:32:00.772 +40.704 IRP_MJ_WRITE DOWN 0x00000000 49 I
      00000009 12.09.2014 17:32:02.028 +1.254 IRP_MJ_WRITE DOWN 0x00000000 0d .
      00000011 12.09.2014 17:32:02.068 +0.037 IRP_MJ_READ UP 0x00000102 57 00 61 00 74 00 63 00 68 00 70 00 6f 00 72 00 74 00 2f 00 … W.a.t.c.h.p.o.r.t./.…
      00000031 12.09.2014 17:35:55.002 +0.737 IRP_MJ_READ UP 0x00000102 2b 33 30 2e 36 32 35 30 43 0d +30.6250C.
      00000033 12.09.2014 17:36:25.185 +30.182 IRP_MJ_WRITE DOWN 0x00000000 48 H
      00000035 12.09.2014 17:36:26.159 +0.971 IRP_MJ_WRITE DOWN 0x00000000 0d .
      00000037 12.09.2014 17:36:27.297 +1.137 IRP_MJ_READ UP 0x00000102 34 32 25 0d 42%.
      Thanks in advance..
      • E
        edmond
        Above the script display like this .
        But I use hyperminal is received data .and I type "T" and get temperature value .Type "H" and get humidity.
        9? 18 17:09: 'WatchportHSDS': Read failed because port is not configured correctly
        Urgent9? 18 17:09: 'WatchportHSDS': Serial Port COM12 failed with error jssc.SerialPortException: Port name - COM12; Method name - openPort(); Exception type - Port busy.
        Urgent9? 18 10:22: 'WatchportHSDS': Read failed because port is not configured correctly
        Urgent9? 18 10:22: 'WatchportHSDS': Serial Port COM12 failed with error jssc.SerialPortException: Port name - COM12; Method name - openPort(); Exception type - Port not found.
        Urgent9? 18 00:51: 'WatchportHSDS': Read failed because port is not configured correctly
        Urgent9? 18 00:51: 'WatchportHSDS': Port COM12 is in use
        Urgent9? 18 00:48: 'WatchportHSDS': Read failed because port is not configured correctly
        Urgent9? 18 00:48: 'WatchportHSDS': Port COM12 is in use
        Urgent9? 18 00:45: 'WatchportHSDS': Read failed because port is not configured correctly
        Urgent9? 18 00:45: 'WatchportHSDS': Port COM12 is in use
        What is wrong with it ? I have close hyperminal .
        any suggestion?
        Thank in advance.
        • jeremyhJ
          jeremyh
          Your port is busy.
          You can use a tool like portmon to tell you what application is using the serial port:
          http://technet.microsoft.com/en-us/sysinternals/bb896644.aspx
