    StreamTransport null pointer exception
    6 Posts 4 Posters 6.3k Views 1 Watching
    • K Offline
      kelden
      I have been trying to implement a RTU slave application, I used the ListenerTest as a start with the necessary modifications to make it create a RTU slave instead of the TCP slave. However when I try to run it I get a NullPointerException at the SteamTransporter.
      run:
      Stable Library
      Native lib Version = RXTX-2.1-7
      Java lib Version   = RXTX-2.1-7
      com.serotonin.modbus4j.exception.ModbusInitException: java.lang.NullPointerException
              at com.serotonin.modbus4j.serial.SerialSlave.start(SerialSlave.java:51)
              at com.serotonin.modbus4j.serial.rtu.RtuSlave.start(RtuSlave.java:40)
              at kiwi.main$1.run(main.java:46)
              at java.lang.Thread.run(Thread.java:662)
      Caused by: java.lang.NullPointerException
              at com.serotonin.messaging.StreamTransport.start(StreamTransport.java:32)
              at com.serotonin.modbus4j.serial.SerialSlave.start(SerialSlave.java:48)
              ... 3 more
      I looked through the examples but couldn't find any that were very relevant except the listener one. Google didn't really turn up anything useful either. When I looked closer at the code I figured it might be something up with the name being passed to StreamTransport and fetched the thread and got it's name and passed that as a variable instead. That didn't make any difference though.
      Thanks in advance, hope I didn't miss anything painfully obvious :)
        There is a line in SerialSlave that should be removed.
                try {
                    serialPort = SerialUtils.openSerialPort(serialParameters);
                    transport = new StreamTransport(serialPort.getInputStream(), serialPort.getOutputStream());
                    transport.start("Modbus4J SerialSlave");  // &lt&lt&lt REMOVE THIS LINE
        The start method should be (and is) called in subclasses. I'm pretty sure this will fix the problem, but i don't have any equipment available to test on. Please let me know if it helps.
        • V Offline
          v8dave
          I've just come across this error from 2011 and I only downloaded the code a few days ago.
          Why was this error still present in the code?
          Anyway, the fix sorted the issue and I now have a working RTU slave.
            statisticblogs
              The line is not in the CVS code. Perhaps it still is in the src jar file. Try using the repo source instead.
