[SOLVED] SQL data source
I'm configuring a SQL point and it have one parameter called "Update statement" (attachment), how it works?
Can i create a UPDATE/INSERT using the value that the user set?
Example: user on watch list set a point to 25, how can i put this value on the SQL, i need to use some environment variable? like VALUE or TIMESTAMP?
update table set column1 = ?VALUE?, column2 = ?TIMESTAMP?
where column3 = "test"
Only the value is used, not the timestamp. Your insert/update statement might look like this:
update table set column1=? where column3='test'The '?' is the value parameter.
Thank you.
