    Slave and virtual device on same system
    7 Posts 2 Posters 4.3k Views 1 Watching
    • L Offline
      lefticus
      Hi, I'm wondering if it's possible to have both a virtual device and a slave device on the same computer.
      I have a server setup with 2 physical network interfaces on the same network. I would like my virtual device to be tied to one network interface (say eth0) and my slave device, running periodic scans of the bacnet network runnong on the other device (eth1).
      I've tried setting up bacnet4j with the appropriate broadcast and IP address to try and force it to bind to a specific network interface. Every time I try this the code simply fails to do anything. That is, no errors are generated, but the software never receives any responses.
      So, is it possible to actually run two different bacnet4j processes on the same computer, with two different interfaces?
      Jason
        I can't say that i've tried this scenario, nor do i have resources available at the moment to do so. Have you verified that the the interfaces work individually, i.e. in the absence of the other?
        • L Offline
          lefticus
          The only scenario that does not work is specifying the broadcast and IP address when constructing the LocalDevice. If I do not specify the IP address it works fine.
          -Jason
            Can you provide an example of how you are doing that?
            • L Offline
              lefticus
              Certainly.
              Taking the SlaveDeviceTest.java line 58
              If I do:
              LocalDevice localDevice = new LocalDevice(1968, "172.16.0.255"); // works
              LocalDevice localDevice = new LocalDevice(1968, "172.16.0.255", "172.16.0.4"); // does not work
              For what it's worth, I understand the issue now. I'm running on Linux. On Linux, if you bind to a specific address you will not receive broadcast UDP messages unless you are running as root with a raw socket and SO_BINDTOINTERFACE set.
              The issue is discussed from a Java on Linux perspective here: http://www.java.net/node/695514 and from a Linux C perspective here: http://developerweb.net/viewtopic.php?id=5722.
              Jason
                Good to know.
