    How get/set value from my device ?
    BACnet4J general discussion
    3
    11
    7.6k
    • V
      Valter Henrique
      Hi everyone,
      i'm trying BACNet4J, and i have to say great job!
      I ran Test2.java from 'test' package, and everything was fine, but now i'm trying to get and set value from my device, so i'm trying to run CommandPriority.java but with no sucess .
      Here is my code: http://pastebin.com/Bwp9qbcA
      Could someone help me ?
      Thanks for you attention.
      Valter Henrique.
      • M
        Is this the same problem as your previous post?
        • V
          Valter Henrique
          I think it is.
          I really need to know how to write some value in my object, could anyone help me with that ?
          I'm trying a lot of example but nothing works for me.
          Could anyone, please, help me ?
          Valter Henrique.
          • G
            Guven_Ulu
            The simulation environment to work Bacnet4j without real Device
            Hi all,
            I am vey new bacnet. I want to learn basic needs to work or develop custom application by using bacnet4j. I have not a bacnet device yet but I will develop a application by using bacnet4j. Can we tell how to make a test environment with VTS (Virtual Test Shell), create these devices which is defined in VTS and connect to them by using bacnet4j ? I only want to learn how it can be possible to work on bacnet4j library if you have not real bacnet device ?
            we will be appreciated if you reply this.
            • M
              You can use VTS in the way you describe, yes. You could also have two or mroe instances of BACnet4J communicating with each other. There is code in the test source that should indicate how this can be done.
              • G
                Guven_Ulu
                Thanks for your reply..
                My custom application has such a scenario like this.. We are getting alarms info from a software by using its web services..We will take alarms info by using web services and send this information to bacnet device..Is this possible to make a application for a such scenario..
                • G
                  Guven_Ulu
                  There is a issue in VTS..I defined a device with port and I push send button but VTS is shut down..When I click its icon again, it is opening and closing immediately...Could you help me about this?
                  • G
                    Guven_Ulu
                    I found the issue what it is..The issue is MCAFEE antivirus program..?t is blocking bacnet package and closing VTS ..
                    I need help to use bacnet4j library ...Could you help anyone ? My application should listen bacnet packet and read/write values to bacnet device ? I really appricated if you help me..
                    Thank you..
                    • V
                      Valter Henrique
                      Thank you..
                      I create this class dude, maybe this help you:
                       * To change this template, choose Tools | Templates
                       * and open the template in the editor.
                      package com.autolife.devices;
                      import com.serotonin.bacnet4j.LocalDevice;
                      import com.serotonin.bacnet4j.service.acknowledgement.ReadPropertyAck;
                      import com.serotonin.bacnet4j.service.confirmed.ReadPropertyRequest;
                      import com.serotonin.bacnet4j.service.confirmed.WritePropertyRequest;
                      import com.serotonin.bacnet4j.type.Encodable;
                      import com.serotonin.bacnet4j.type.constructed.SequenceOf;
                      import com.serotonin.bacnet4j.type.enumerated.ObjectType;
                      import com.serotonin.bacnet4j.type.enumerated.PropertyIdentifier;
                      import com.serotonin.bacnet4j.type.enumerated.Segmentation;
                      import com.serotonin.bacnet4j.type.primitive.ObjectIdentifier;
                      import com.serotonin.bacnet4j.type.primitive.UnsignedInteger;
                      import java.io.IOException;
                      import java.net.InetAddress;
                      import java.net.InetSocketAddress;
                       * @author Valter
                      public class Light {
                          private static LocalDevice localDevice;
                          private boolean state;
                          public boolean getState() {
                              return state;
                          public void setState(boolean state) {
                              this.state = state;
                          public void active(){
                              localDevice = new LocalDevice(101, "192.168.1.255");
                              localDevice.setPort(47808);
                              try {
                                  localDevice.initialize();
                                  // Find the device
                                  if (localDevice.getRemoteDevices().isEmpty()) {
                                      System.out.println("No remote devices responded");
                                  getObjectList(localDevice, "192.168.1.149", 0xBAC0, 101, state);
                              } catch (IOException ex) {
                              } catch (Exception ex) {
                              localDevice.terminate();
                          private static void getObjectList(LocalDevice localDevice, String ip, int port, int deviceId, boolean state) throws Exception {
                              InetSocketAddress addr = new InetSocketAddress(InetAddress.getByName(ip), port);
                              ReadPropertyRequest read = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.device, deviceId), PropertyIdentifier.objectList);
                              ReadPropertyAck ack = (ReadPropertyAck) localDevice.send(addr, null, 1476, Segmentation.segmentedBoth, read);
                              System.out.println("IP: " + ip);
                              SequenceOf<ObjectIdentifier> oids = (SequenceOf<ObjectIdentifier>) ack.getValue();
                              int i = 0;
                              for (ObjectIdentifier oid : oids) {
                                  System.out.println("--------  " + oid.getInstanceNumber());
                                  //System.out.println();
                                  //1 : not allow to write
                                  //2 : allow to write
                                  //3 : not allow to write
                                  //4 : allow to write
                                  if (i == 4) {
                                      for (int k = 1; k <= 16; k++) {
                                          setPresentValue(addr, read, oid, new com.serotonin.bacnet4j.type.primitive.Boolean(state), k);
                                  i++;
                          private static void setPresentValue(InetSocketAddress addr, ReadPropertyRequest read, ObjectIdentifier objectIdentifier, Encodable value, int priority) throws Exception {
                              WritePropertyRequest wpr = new WritePropertyRequest(objectIdentifier, PropertyIdentifier.presentValue, null, value, new UnsignedInteger(priority));
                              localDevice.send(addr, null, 1476, Segmentation.segmentedBoth, wpr);
                      • G
                        Guven_Ulu
                        Thanks for your code
                        Actually I need to understand the classes of Bacnet4j..
                        I am seeing bacnet packages in Wireshark when I sent bacnet packets from Virtual Test Shell. ..
                        What must I write the argument of LocalDevice class to capture these package in Bacnet4j lib in java? WireShark and VTS is in my local computer so do I must write localhost in LocalDevice as a argument?
                        All I want is to manage and control the bacnet device from Bacnet4j lib ...
                        I am beginner of these library and there is no document to study on, so I need to understand and learn what it is going on..
