    Metadatasource - reference itself
    5 Posts 2 Posters 1.9k Views 1 Watching
      skiv71
      hi, i have a meta, with this as follows...
      [script to monitor number of mins that temp is above a certain limit]
      value=mon.value;
      if (temp.value>=(sp.value+offset.value)) value=value+1;
      else value=0;
      return value;
      this script is set to run at the start of each minute..
      basically....
      if temp >= setpoint + offset, increment meta point...
      then i have a binary meta which....
      if no. of mins >= delay mins, value=true, else false...
      this all works but the awkward bit if the first meta point referencing itself (necessary for the increment?)
      mainly because i cannot pick the meta "mon" until i've created the point and left and returned to meta point editing..
      is there another way i can reference the value?
      thanks
        skiv71
        i realise i can do this with an alarm trigger from a binary meta point based on temp, sp and offset... but i want to give the user the ability to alter the alarm delay, and so this needs to be a data point..
        and as far as i'm aware, i cannot link an alarm delay to a data point.
        thanks
          Can't you just use a high limit detector on the temp point?
            skiv71
            i could but i want to make it compare to a point variable instead of fixed value so that an end user can change the level.
