    Derby to mysql
    3 Posts 2 Posters 2.9k Views 1 Watching
    • Y Offline
      ywwtx
      INFO 2010-02-10 09:41:21,203 (org.springframework.web.context.ContextLoader.ini
      tWebApplicationContext:209) - Root WebApplicationContext: initialization complet
      ed in 344 ms
      INFO 2010-02-10 09:41:21,203 (com.serotonin.mango.MangoContextListener.contextI
      nitialized:73) - Mango context starting
      INFO 2010-02-10 09:41:21,453 (com.serotonin.mango.db.BasePooledAccess.initializ
      eImpl:54) - Initializing pooled connection manager
      WARN 2010-02-10 09:41:21,796 (com.serotonin.mango.db.upgrade.DBUpgrade.checkUpg
      rade:81) - Upgrading instance from 0.7.0 to 0.8.0
      INFO 2010-02-10 09:41:21,812 (org.springframework.beans.factory.xml.XmlBeanDefi
      nitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from class
      path resource [org/springframework/jdbc/support/sql-error-codes.xml]
      INFO 2010-02-10 09:41:21,859 (org.springframework.jdbc.support.SQLErrorCodesFac
      tory.<init>:128) - SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL
      , MySQL, Oracle, PostgreSQL, Sybase]
      2010-2-10 9:41:21 org.apache.catalina.core.StandardContext start
      ??: Error listenerStart
      ??: Context [/mango-1.8.0] startup failed due to previous errors
      INFO 2010-02-10 09:41:21,859 (com.serotonin.mango.MangoContextListener.contextD
      estroyed:101) - Mango context terminating
      INFO 2010-02-10 09:41:21,859 (com.serotonin.mango.db.BasePooledAccess.terminate
      :123) - Stopping database
      estroyed:121) - Mango context terminated
      INFO 2010-02-10 09:41:21,859 (org.springframework.context.support.AbstractAppli
      cationContext.doClose:816) - Closing org.springframework.web.context.support.Xml
      WebApplicationContext@19e15c: display name [Root WebApplicationContext]; startup
      date [Wed Feb 10 09:41:20 CST 2010]; root of context hierarchy
      INFO 2010-02-10 09:41:21,859 (org.springframework.beans.factory.support.Default
      SingletonBeanRegistry.destroySingletons:392) - Destroying singletons in org.spri
      ngframework.beans.factory.support.DefaultListableBeanFactory@193c0cf: defining b
      eans [CompoundEventsDwr,CustomViewDwr,DataPointDetailsDwr,DataPointEditDwr,DataS
      ourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingLists
      Dwr,MiscDwr,PointHierarchyDwr,PointLinksDwr,PublisherEditDwr,PublisherListDwr,Re
      portsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,loca
      leResolver,messageSource]; root of factory hierarchy
      2010-2-10 9:41:22 org.apache.coyote.http11.Http11Protocol start
      ??: Starting Coyote HTTP/1.1 on http-8080
      2010-2-10 9:41:22 org.apache.jk.common.ChannelSocket init
      ??: JK: ajp13 listening on /0.0.0.0:8009
      2010-2-10 9:41:22 org.apache.jk.server.JkMain start
      ??: Jk running ID=0 time=0/31 config=null
      2010-2-10 9:41:22 org.apache.catalina.startup.Catalina start
      ??: Server startup in 2142 ms
        You need to look in a file in Tomcat's logs directory usually called "localhost.yyyy-mm-dd.log" for the stack trace.
