    How-to test SNMP Trap in Mango
    12 Posts 6 Posters 9.8k Views 4 Watching
    • N Offline
      narenblr
      Ensure that there is no other SNMP Trap service running on the Mango server except Mango SNMP Trap.
      You can see this on a Linux system by executing the following command.
      netstat -unatp |grep udp
      udp 0 0 :::162 :::* 18938/java
      There should be a UDP port listening on 162 and should be bound to java
      1. Create a SNMP Data Source
      2. Download TrapGen.exe from http://www.wtcs.org/informant/free_snmp_tools.htm
      3. Create Trap Gen Command and note down the OID (-v .1.3.1.4.1.2854.1.2)
      TrapGen.exe -d x.x.x.x -o .1.3.1.4.1.2854 -v .1.3.1.4.1.2854.1.2 INTEGER 20
      Note : x.x.x.x ( Mango server IP Address)
      1. Configure a Data Point with a SNMP Trap OID (.1.3.1.4.1.2854.1.2)
      2. Execute the TrapGen command
      1. You should see the Trap received in Watchlist.
      Note : Incase if the SNMP OID is not configured as in the trapgen command check the mango log file and you should see a warning like the one below.
      /mango/apache-tomcat-6.0.20/logs/mango.log:WARN 2009-10-08 09:31:24,070 (com.serotonin.mango.rt.dataSource.snmp.SnmpDataSourceRT.receivedTrap:236) - Trap not handled: 1.3.1.4.1.2854.2.2 = 200
        Anonymous
        This post is deleted!
          rbautomacao
          Hi all !
          When i enable a Data Source i got this message : 'SNMP TRAP': java.net.BindException: Permission denied.
          Somebody could help me ?
          Thanks !
          • N Offline
            narenblr
            Stop any other SNMP Trap service running already and you should not receive this error.
            • N Offline
              narenblr
              Are you running tomcat as a normal user and not as root. It will helps if you could let us know the OS on which mango is running. If you are running on a UNIX system ensure that mango runs as root to be able to accept SNMP TRAPS on UDP 162.
                Anonymous
                Yes, when i post it here at same instant i remember that was not running as root and now it's ok. Thanks !
                • ricardoR Offline
                  ricardo
                  Sorry for resurrecting an old post, but the current linux installation instructions specifically say not to run mango as root. If we follow the instruction and create a new user (e.g. mango), we will not be able to bind the snmp trap port, e.g we will get "'SNMP': Unable to bind to trap port. Permission denied.". What is the suggested work around?
                  • ricardoR Offline
                    ricardo
                    Any idea here?
                      Hi @ricardo you should use a program such as persistent iptables to route port 123 --> 1123. Then bind your data source to 1123.
                      • ricardoR Offline
                        ricardo
                        @CraigWeb Thank you for your reply. Sorry, can you provide more detail on how to do this?
                          @Ricardo there is some information here as to how to use iptables. I suggest you familiarize yourself with how they work as they are useful to redirect port I/O between privileged ports and non-privileged ports.
                          https://docs-v3.mango-os.com/linux-security
