    Timeout to lock table systemsettings
    2 Posts 2 Posters 765 Views 2 Watching
    • Jdiaz-coJ Offline
      Jdiaz-co
      buenas,
      Estoy teniendo un problema. uso mango 3.7.7 y cada poco tiempo se me cae la aplicacion.
      El error que me aparece es este:
      ERROR 2025-10-27T08:26:50,187 (com.serotonin.m2m2.util.timeout.TimeoutTask.run:61) - Uncaught Task Exception
      org.springframework.dao.CannotAcquireLockException: PreparedStatementCallback; SQL [select settingValue from systemSettings where settingName=?]; Tiempo vencido intentando trabar (lock) la tabla "SYSTEMSETTINGS"
      Timeout trying to lock table "SYSTEMSETTINGS"; SQL statement:
      select settingValue from systemSettings where settingName=? [50200-199]; nested exception is org.h2.jdbc.JdbcSQLTimeoutException: Tiempo vencido intentando trabar (lock) la tabla "SYSTEMSETTINGS"
      Agradeceria cualquier ayuda.
      gracias
      • joeamiragliaJ Offline
        joeamiraglia
        @Jdiaz-co said in Timeout to lock table systemsettings:
        hello good,
        I'm having a problem. I'm using Mango 3.7.7 and the application crashes every so often.
        The error I'm getting is this:
        I would appreciate any help.
        thank you
        This error comes from the embedded H2 database: something is holding a lock on the SYSTEMSETTINGS table too long, so reads (like select settingValue from systemSettings…) time out and throw CannotAcquireLockException.
        Common causes:
        • Another process/tool (H2 console, external SQL client) connected to the same H2 DB while Mango is running.
        • Long-running DB operations (backups, purges, heavy writes) that keep the table locked.
        • Short default H2 LOCK_TIMEOUT (1s) causing normal contention to show up as errors.
        Things to try:
        • Make sure only Mango is connected to the H2 DB (no external tools while it’s running).
        • Increase H2 lock timeout in env.properties/mango.properties, e.g.
          db.url=jdbc:h2:${ma.home}/databases/mah2;LOCK_TIMEOUT=10000
        • Check logs around the crash time for other FATAL/DB errors that might be the real shutdown cause.
        If this is a production system (not just a test setup), I strongly recommend:
        • Migrating from H2 to MySQL (more robust under load and concurrency).
        • Upgrading Mango to a more recent supported version if possible, to benefit from DB and stability fixes.
