    NoSQL requires license?
    13 Posts 4 Posters 3.1k Views 3 Watching
    • E Offline
      evranch
      Hi, I've been using Mango for years as the SCADA system on my farm.
      Recently I decided to convert to NoSQL as H2 was becoming a massive drag on the older computer that it runs on, consuming most of the RAM, grinding on swap and eating 60-80% of the CPU time.
      NoSQL turns out to be extremely performant compared to H2, consuming under 10% of RAM and 5% of CPU time on the same machine. Unfortunately it results in restarting Mango every 8 hours without a license. This was not listed as a limitation of the free licence?
      Does the NoSQL module require its own license, or is it part of the Enterprise version?
      If this is the case, it appears that connecting to MySQL is also an option, yet I could not find any documentation regarding configuration or converting the database.
      Thanks, Alex
        MattFox @evranch
        @evranch contact radix, they will be able to arrange a licence for you to purchase.
        Alternatively, if you're not on an ES or gt model, you could try leveraging a sql server instead... But note it's more performant than H2 but still less than nosql..
        • joeamiragliaJ Offline
          joeamiraglia
          Yes, the NoSQL license (General license not the Enterprise license) would be required to eliminate the restarts. In the ma.log file, when Mango starts, it mentions that it is running NoSQL in free mode and that it will restart in 8 hours. The documentation to convert an H2 database to MySQL is found here: Database Conversions. If you need further assistance, please let us know. Thanks!
          Joe Miraglia
          Service Application Engineer
          Radix IoT
          E 1 Reply Last reply Reply Quote 0
          • E Offline
            evranch @joeamiraglia
            Thanks, I saw this in the log but it would be nice if it was better documented that it would switch to this mode before I had migrated my database. It's not apparent if I can now migrate back from NoSQL to MySQL.
            Licensing appears to have changed quite a bit under Radix with licensing and pricing completely obscured, even for hardware, personally I liked the old model where you knew what you were buying.
            So I'll give MySQL a shot first for this application. For MySQL just set db.type=mysql in mango.properties and fill in the credentials?
            I was interested in trying out Mango under Docker anyways, so I will try to spin up a test container using MySQL before I trash my instance by accident.
            Do you happen to have a docker-compose.yml file ready for deployment with the appropriate bind mounts identified? All I could find was
            docker pull ghcr.io/radixiot/mango:latest
              MattFox @evranch
              @evranch The nosql module has always been a paid add on, all the way back to version 3, when it was infinite automation. If you were buying mangoES units, you would not have noticed because they came with an enterprise license.
              You can always do database migrations to move point data which mango does via the database migration option in the dashboard.
              I don't use docker compose and use actual hardware plus one virtual cloud instance.
              I believe there may have been someone on the forum who got help with it, I am not 100% certain though.
              Good luck with your tinkering
              • E Offline
                evranch @MattFox
                @MattFox Makes sense. This instance I run at home has been migrated since v3 and never had the NoSQL module installed until recently, when I realized "Hey, this thing is still running on H2"
                In any case Mango was incredibly easy to set up in Docker, and I have it working with PostgreSQL in another container. I pulled all the data off the slow PC onto my workstation, exported my configuration and my historical data into a massive CSV, and reimported it into another container. Tested it and then dropped it back onto the box. Docker is great at this sort of job and will make migrating instances between hardware effortless.
                Here is a docker-compose.yml for reference if anyone wants to set up a containerized system quickly using SQL. mangoNoSqlDatabase is mounted to an empty directory, as that's the simplest way to remove a module from a Docker image.
                version: "3"
                services:
                  mango:
                    image: ghcr.io/radixiot/mango:latest
                    container_name: mango
                    environment:
                      - TZ=America/Regina
                    volumes:
                      - ./mango-data:/opt/mango-data
                      - ./empty:/opt/mango/web/modules/mangoNoSqlDatabase
                    ports:
                      - 8080:8080
                      - 8443:8443
                    restart: unless-stopped
                    depends_on:
                      - postgres
                  postgres:
                    image: postgres
                    user: 1000:1001
                    environment:
                      POSTGRES_USER: mango
                      POSTGRES_PASSWORD: password
                    volumes:
                      - ./pg-data:/var/lib/postgresql/data
                then just connect to the database container with
                db.type=postgres
                db.url=jdbc:postgresql://postgres/mango
                db.username=mango
                db.password=password
                in your mango.properties
                Performance seems similar enough to NoSQL, at least for this ~100 point system. The Postgres container is barely consuming any resources, I'm surprised that H2 was so hungry for memory.
                MattFoxM Faucon NgandoF 2 Replies Last reply Reply Quote 1
                  MattFox @evranch
                  @evranch thanks for sharing your config. I am certain many others will find it useful
                  • Faucon NgandoF Offline
                    Faucon Ngando @evranch
                    Hi @evranch,
                    I too am trying to migrate to docker but I can't export and then import my old data into the docker instance.
                    Could you explain the procedure to me please?
                    Thank you.
                      MattFox @Faucon Ngando
                      @Faucon-Ngando he's using a docker-compose file to run both a postgres sql container and mango container inside a single network.
                      The volume property maps the directories inside the docker images to real directories on the host system.
                      For exporting you'll need to do a sql backup and a complete nosql backup (if applicable)
                      These outputs should appear inside you /opt/mango-data/backups directory.
                      If you're not using an external sql you should still be able to run using the same configs in that docker-compose file, minus the postgres related entry as all of your data and backups should exist in the mango-data directory...
                      Faucon NgandoF 1 Reply Last reply Reply Quote 0
                        Faucon Ngando @MattFox
                        @MattFox Thank you for your reply. I have installed a mariadb container that connects to mango.
                        How can I now convert my H2 data to SQL. I have added this code
                        db.type=mysql
                        db.url=jdbc:mysql://192.168.1.17/mango
                        db.username=mango
                        convert.db.type=h2
                        convert.db.url=jdbc:h2:/opt/mango-data/databases/mah2
                        #convert.db.username=${db.username}
                        #convert.db.password=${db.password}
                        in mango.properties but it is not working.
                          @Faucon-Ngando what version of mango?
                            @MattFox I have Mango V5.2 with enterprise license.
                              @Faucon-Ngando sounds like a bug, raise it with radix. Your property settings are correct.
                              Assuming you can log in to your MySQL db locally via the mango credentials
